DynAudio DBM50 Monitor Speaker - loud hissing noise
  • dicky96
    Sun Seeker
    • Mar 2017
    • 1825
    • Spain
    Hi guys
    I have a DynAudio DBM50 here - it makes a loud hissing noise.
    It sounds just like an FM radio with no antenna (or tuned off-station). The volume of the hissing fades up and down, sometimes drops to almost nothing then comes back loud. It occasionally makes a loud bump noise too.
    It does this even with nothing connected to the audio input XLR
    Any suggestions?
    Follow me on YouTube
    Learn Electronics Repair
  • madan1
    • Nov 2016
    • 726
    • Bulgaria
    Re: DynAudio DBM50 Monitor Speaker - loud hissing noise
    If it is not constant, I would put my money on bad solder joints and/or connectors.
    Other thing could be failing capacitors.. they tend to change parameters with temperature change.
      by momaka
      03-15-2023, 10:17 PM
    • keepread
      Dell monitor PSU vs Dell laptop PSU
      by keepread
      Hi there!
      Someone gave me their old monitor, it's Dell S2715ht.
      The owner was using it when his PSU began to smell and then to smoke. It literally began to melt. He turned the monitor off, pulled the PSU, and ditched it because it was smelly even after it cooled. So I got the monitor but not the plug.
      Now, I tried to bring the monitor back to life, by plugging one of my many Dell laptop PSUs. They are of the same 19.5V, and the wattage of the laptop PSU is higher than that which the monitor is rated for. Visually, the socket on the monitor seems compatible, and the plug plugs...
      10-30-2025, 04:45 PM
    • eliemgh
      lenovo t14 i7 10 gen : I press the power button and there is a loud fan noise
      by eliemgh
      lenovo t14 i7 10 gen : I press the power button and there is a loud fan noise for about 3 seconds and power light is on. Nothing on display screen. i have removed the battery and bios battery still the same. i have put yesterday on update and charger ,i have leave and back and see this problem. Any One Can help Me ?
      09-27-2024, 02:40 AM
    • wattage
      AOC AG493UCX 49-inch monitor - Firmware request
      by wattage
      Hello Badcaps Community,
      The problem is that it will not display a picture on any of its inputs. And the on-screen menu does not appear. The power button works properly. It powers on with the remote as well. But the on-screen menu does not appear, even when not connected to any...
      07-13-2025, 04:41 PM
    • badcappo
      Dead Thinkpad E15, hissing noise from BQ25710
      by badcappo
      Hello there, got a Thinkpad E15 on the bench, almost no vital signs. Only things: Power button white LED flashes several times when USB-PD gets connected (number of flashes varies from three up to twelve times, sometimes no reaction at all). Battery charge indicator LED stays orange. Most interesting is hissing / whining sound from Battery Charge Controller IC BQ25710 on the keyboard side of the main pcb. Board fuses tested and intact, no shorts found so far. BQ25710 is also the only thing on the board to become warm in thermal image (below 70 °C). Thanks for any hint.
      03-09-2025, 08:23 AM
