Dell monitor 2007FPb will not stay on
  • ngutman
    • Dec 2013
    • 9
    I have a Dell monitor 2007FPb connected to my laptop using a VGA cable. The monitor stays ON for about 30 seconds then goes OFF, comes back ON for 30 seconds, goes OFF and so on.
    It did same when it was connected to another computer via a DMI cable.
    What might be the problem and how to fix it?
    Thanks,
    Nathan
  • Davi.p
    Hobbist Tech
    • Sep 2009
    • 4367
    • Italy - Milan
    Re: Dell monitor 2007FPb will not stay on
    Hi, what it does with the led lights? Try to open it and make it work without covers, when it is warm (switched off since 1 min) use an hardryer on all the psu board to warm it up then power on, does it stay on? If yes retry warming the main logic board.. if yes retry on the tcon board..
    • ngutman
      • Dec 2013
      • 9
      The lights come off and come back on when the monitor restarts.
      What is the warming suppose to show?
      • vinceroger69
        • Mar 2012
        • 6714
        if there are bad capacitors on the boards heating them can tempory lower the esr and some times the psu etc will work.
        • Davi.p
          Hobbist Tech
          • Sep 2009
          • 4367
          • Italy - Milan
          Update: if the leds came off maybe psu outputs goes low when mon. stops, try to test them for sure, if yes you can concentrate the heating job whithin this board. The only components i think are sensible to the heat are alluminium caps and NTC (or PTC i don't remember).
          • ngutman
            • Dec 2013
            • 9
            Can someone kindly tell me what PSU board, TCON bord, NTC or PTC stand for.
            How do I identify those boards when I open the monitor. Are they labeled in any way?
            Thanks,
            Nathan
            • Davi.p
              Hobbist Tech
              • Sep 2009
              • 4367
              • Italy - Milan
              psu board is the bigger board that you see inside and has the 220/100VAC connector, NTC is a small round/flat component with 2 legs coloured in black or green near the previous connector, the tcon is another board but it doesn't matter now.
              • newtothis
                • Mar 2013
                • 1556
                • england
                the PSU is the Power Supply Unit, Will have a large capacitor on it. Its the one the has a cable that goes to your mains plug
                Even for me reading this it is confusing :S Sorry Davi.p
                Open the back up and take a picture of the entire back so we can see all the boards and connectors, then take one of each board closer up.
                • ngutman
                  • Dec 2013
                  • 9
                  I opened it up and see the PSU but what is the trick to take it out. I removed the three screws and can wiggle the board but it will not separate from the power socket and it does not come out with the socket.
                  So how do I get it out?
                  The board is 5D*L2J02001 0211 612 GUND48D 297741 if this means anything to you.
                  Photo of all the boards is attached. I point to the PSU with a red arrow.
                  Thank you for helping.
                  Nathan
                  • Davi.p
                    Hobbist Tech
                    • Sep 2009
                    • 4367
                    • Italy - Milan
                    There's a black plastic clip well visible, with a flat screwdriver you have to press it from the bottom side until it pops out in the upper side (as from your picture)
                    • ngutman
                      • Dec 2013
                      • 9
                      Thanks I got it. Am able to see all components now. Don't see any leaking or bulging capacitors. From reading this forum I understand that the capacitors on the PSU board are often the problem. Should I just replace the five capacitors and hope for the best? The problem was that the monitor was cycling on/off about every 30 seconds.
                      Photo of three board components is attached. The fourth little board has just two USB ports and two more ports which I don't recognize.
                      Thanks again,
                      Nathan
                      • Davi.p
                        Hobbist Tech
                        • Sep 2009
                        • 4367
                        • Italy - Milan
                        Can you make me a new photo of a particular area around IC702? it's a 3 leg smd chip on the PSU board in the bottom side near the big transformer.. i have to read the markings on the resistors and see their position..
                        • ngutman
                          • Dec 2013
                          • 9
                          Is this the area that you are looking for?
                          Nathan
                          • Davi.p
                            Hobbist Tech
                            • Sep 2009
                            • 4367
                            • Italy - Milan
                            NO, i mean here:
                            The reason for why i asked this is that i want to find the normal output voltage so you can test the monitor with an external psu, but if you feel not good to do this type of test try to buy those capacitors (low ESR types) and hope, i don't like that way..
                              The power supply is a single output power supply, you can verify the DC output right at the two leg of the cap C711, it should have about 19VDC when the monitor is plugged in, the power supply is an always on power supply. There are Buck regulator switching power supplies on the USB board for dropping the 19V down to 5v, 3.3V, etc.
                              So monitor the 19v output.
                              There are more than one version of this 2007 monitor.
                              Your version is not the same but still uses the same setup.
                              http://s807.photobucket.com/user/bud...?sort=3&page=1
                              • Davi.p
                                Hobbist Tech
                                • Sep 2009
                                • 4367
                                • Italy - Milan
                                So budm, we want assume that the psu has 19v? I wanted to tell him to search for a laptop psu with 19v to supply the monitor..
                                  Yes, it is 19VDC, you will need about 4A minimum (monitor spec is 55Watts, so use higher rating for head room)
                                  • ngutman
                                    • Dec 2013
                                    • 9
                                    I replaced the 5 capacitors on the PSU board. The monitor performed a little better but still continued rebooting every few minutes. Eventually it went off and it will not turn on. Pressing the power button does nothing.
                                    Is there anything that I can still do to revive it or is it ready for the landfill?
                                    I posted the PSU board. I am just an amateur tinkerer so please be specific about what component to replace and where to get it.
                                    Thank you all for holding my hand so far.
                                    • selldoor
                                      Slow Learner
                                      • 7870
                                      What make/series caps did you use - they are the same color in that pic as in the first one?
                                      • ngutman
                                        • Dec 2013
                                        • 9
                                        The photo shows the old capacitors. I got the new ones from a reputable US company.
                                        Nathan
                                        • Borse2008
                                          Seeking Advice: Repairing Dell U3425WE Monitor with Faulty USB-C/Thunderbolt Ports
                                          by Borse2008
                                          Looking for some advice or opinions on what to do with a monitor issue I’ve run into. Apologies in advance is this crossovers a few forum categories.
                                          I have a Dell U3425WE, which I've recently replaced with another model. That said, the original unit is still fully functional in terms of the display — it works perfectly over HDMI and DisplayPort. However, the USB-C and Thunderbolt 4 ports have stopped functioning correctly. The Issue:
                                          • The 90W Thunderbolt 4 port (circled in the photo) no longer charges or powers any device, including laptops or MacBooks.
                                          • There’s
                                          07-15-2025, 04:55 AM
                                        • Bowline
                                          by Bowline
                                          06-11-2025, 10:13 AM
                                          by momaka
                                          03-15-2023, 10:17 PM
                                        • Jesus Coder
                                          Issues Reviving Old Dell 2408WFPb Monitor
                                          by Jesus Coder
                                          I have been having some difficulties reviving an old Dell 2408WFPb PC monitor that I received for free. When I first acquired it, the backlights of the display were on but alas no image was showing. After extensive research on the topic, I went ahead and purchased a new t-con board for the monitor. After installing the board, I was then presented with a new screen that was half black and half green (more so black). I have been unable to figure out what to do next as I have limited knowledge of display electronics. Might anyone on this forum have an idea of what may...
                                          06-25-2023, 02:33 PM
                                        • ChristianBr01
                                          Dell 34 inch U3419W Monitor with thin stripes on partial screen
                                          by ChristianBr01
                                          I have a Dell U3419W Monitor that has some thin stripes on a part of the screen since Tuesday.
                                          This lines cover about a third of the screen and appear for 2 seconds before disappear for another 2 seconds.
                                          This repeats the whole time. I have not opened the case yet cause I had no time, but will try to fix it on this weekend. For me, it looks like a problem on the TCon... Am I right?
                                          Does someone have seen this before?...
                                          05-23-2025, 06:06 AM
