Westinghouse L1928NV
  • keiser
    • Nov 2013
    19 inch monitor began to flicker slightly. Annoying.
    I replaced 4 CapXon capacitors that were buldging with Rubycons.
    Still had the slight flicker. No hissing.
    I wiggled the Chi Mei branded screen apart.
    One lead of the CCFL immediately fell off.
    I assume this was the problem. Bulb not blackened so I made a splint for
    the short stub on the CCFL and resoldered the lead.
    Reassembeled but no joy.
    Unit fires up, the inverter hisses and goes to protected mode in a few seconds.
    Testing individually, the bulbs light for a few seconds as well. No hiss from inverter with single bulb.
    So I think bulb is now good.
    I'm guessing load is imbalanced.
    The leads emerge through a small opening in the metal casing. I wrapped in
    tape but the fit is tight. Maybe excessive leakage?
    Should I just redo this and hope for a better result?
    Suggestions?
    Thanks.
  • Lumberjack777
    • Dec 2010
    • 464
    Re: Westinghouse L1928NV
    Suggestions?
    Thanks.
    Yes, I'd redo it. The high voltage from the inverter is always looking for a place in the wiring to short and arc. That's a very common problem. What you can do is attach the bulbs after you have it apart again. Then fire it up and see what happens. Might need to resolder that wire, or another wire. At least by testing with the bulbs out, you'll have a better idea of the problem.
    • keiser
      • Nov 2013
      A snap to disassemble now. But separating the leads made no difference.
      About all I could observe is that 1 tube is ever so slightly dimmer than the other 3. Swapping leads did not change which tube was dimmer.
      [The dimmer tube is not the one that had the broken lead.]
      The connections "sounded" good [no hiss at the joint] but since they are buried in a block of rubber, to go further would be destructive.
      The "hum" comes from [one of] the inverter transformer[s].
      Might that be enough imbalance to set off protected mode?
      I read a hunt that there is a way to defeat protected mode. Anyone care to share so I can test further?
      Thank you,
        You can try Swapping the transformer location, also compare the resistance reading on the high voltage winding side of both transformers.
        • Lumberjack777
          • Dec 2010
          • 464
          Thank you,
          You can test the secondaries of the inverter transformers with a digital multimeter. http://preher-tech.com/documents/tes...ormersinlcdtvs
          Around here, most people say that a difference of 3% or more in ohms indicates a bad inverter transformer.
          I'm a little confused because it only started humming after you "fixed" the wiring of that one bulb. Is the inverter humming from the side with the dimmer bulb? If so, that's probably it. Especially if the inverter transformers passed the test. The ccfl's are normally very bright.
          **Edit** Thanks budm. You always did type faster than me
          • keiser
            • Nov 2013
            While there was annoying occasional flicker I heard no hissing.
            And never went into protected mode.
            That all started after I resoldered the bulb.
            I have a DMM and an ESR. I will recheck next week when I have some free time.
            The dim bulb remain dims when I swap connectors so I am thinking that rules out one of the inverter transformers. The dim bulb is NOT the one I resoldered. I suppose I should dissect that connection next.
            Thnak you for your comments. I will report back soon.
              The dimming or half-way lit is the indication of the lamp not getting full voltage to the lamp so it can be bad connection at the socket (bent pin) on the board or the connector of the lamp wire, poor solder connection at the lamp ends, bad high voltage winding, bad ballast cap, or what ever that can cause the lamp not to get the full voltage to the lamp.
              • repair-it
                TOSHIBA DLP 52HM95 How to reset timer module on bulb
                by repair-it
                I replaced the bulb only on my Toshiba DLP The bulb is a TB-25. This is the first time I've done a bulb only replacement. Supposedly there is a timer module that needs to be re-calibrated or reset. I don't know where the module is located. I see some vendors selling the bulb with the housing stating module included which leads me to think the module is located inside the enclosure the bulb mounts in, but I didn't see it. Maybe it's inside the plug attached to the bulb?
                Anyway - I am seeking information on how to reset this so called module so that the lamp will operate. Apparently...
                10-11-2023, 07:18 PM
              • ezenia
                LUMIMAN Smart Bulb IC ID?
                by ezenia
                I have a LUMIMAN Smart Bulb that suddenly stopped lighting one day. The bulb is still detected in the app, but won't light. I've probed around and nothing seems to look off with any of the diodes, caps or resistors. The Bluetooth/Wi-Fi module seems to be working as it's still detected in the app. I even tried deleting and re-pairing the bulb (it didn't light, but I was still able to follow the pairing instructions), it re-paired fine, but still no light.
                In diode mode, the LEDs all light up when probed so I'm guessing this means the LEDs themselves are OK. I was expecting...
                04-28-2025, 05:56 PM
              • x_orange90_x
                Vizio E55-E1 bad backlights or bad inverter?
                by x_orange90_x
                I just got this tv today and it appeared to have no backlight on. After taking off the rear cover and checking again in the dark I can see that MAYBE one quadrant is lit.. But still it's quite dim. I was going to check the LEDs with my tester, and I found LED 1 and LED 2 + pins on the wire from the inverter, but I couldn't identify a ground. Nonetheless I tried using a mounting screw on the inverter board and also the chassis as ground but regardless my tester reads 300 which is what it reads when there is no voltage draw.
                I don't know how exactly to test the inverter itself. Is it...
                01-29-2025, 09:24 PM
              • Gentian
                APSINT3636VR 3600W APS INT Series 36V DC 230V AC Inverter/Charger schematic
                by Gentian
                I have a tripp-lite aspint 3636vr inverter charger which blow some of mosfet transistors. I replaced them repaired also the driver circuit and tested but the mosfets burn again.
                It work very well as inverter and also as charger if I let the rear switch in auto mode (inverter) and charger only(charging) but in auto when I connect the feed line 220V AC first time it pass ok to line and start charging the batteries but when I remove the feed line it pass to inverter mode and if I do it again the second time when passing from charging to inverter the Main transformer start making a...
                03-06-2023, 07:07 AM
              • valvashon
                Insignia NS-LCD19-09 (PS OK, Inverter problem?)
                by valvashon
                For some reason I'm just not going to let this 19" TV defeat me. I guess because I have a schematic to work from I feel like I'm oh so close.
                History- while adding a turn-on circuit I let a small screw roll under the power board. Worked through all of that circuitry, probably replacing a MOSFET and PWM controller that were not bad but I was following the service manual. Finally figured out that the power supply is in working order when the inverter section (for the backlights) is disconnected. When the +12 supply to the inverter is disconnected the +12 and +5 will come up...
                01-04-2024, 01:44 PM
