ProView CY-765 Monitor takes many tries to turn on.
  • thestigp11gt
    • Jun 2013
    • 30
    • Scotland
    I have had this monitor since 2004, and never given me any bother until now.
    (with PC running - and does it with other PC also).
    When I press the power button, the orange light changes to green, you hear a short click, and then the light goes back to orange. (same light as stand by). I press the power button about 20-30 times before the screen finally comes on, and when it does it is perfectly fine (using it now)
    Once it has been on for a while, I can turn off the monitor and put it on again with no problems,
    I had the back off it already but did not see any bulging caps or anything, not to say they are not dodgy of course.
    Once thing I have notices that all the components inside the monitor are made by Samsung, if that makes any difference.
  • selldoor
    Slow Learner
    • Dec 2010
    • 7870
    Re: ProView CY-765 Monitor takes many tries to turn on.
    Hi still need pictures- even though caps may not look bulged or leakey
    they do dry out with time and Heat.
    This has all the look of bad caps - As a first step when the set is cold
    try and switch it on. - nothing?
    Get a hair drier and warm ( Not too hot) the caps on the power supply board.
    Try and switch on again?
    If you look at the beginning of this forum - just click on "troubleshooting
    computer displays" (above middle) there is an excellent guide to troubleshooting 2 secs to black by retired caps - start at post19.
    Then you will be set to go when you get a new meter.
    • thestigp11gt
      • Jun 2013
      • 30
      • Scotland
      I will give this a try, The monitor is intact at the moment so will try and get the other one working first before I get wired into this.
      • thestigp11gt
        • Jun 2013
        • 30
        • Scotland
        Just another little update this morning, Monitor came on okay, however what I have noticed is until it warmed up, there was some faint strange diagonal lines which were moving about the screen,
        • kc8adu
          • Nov 2003
          • 8832
          • U.S.A!
          open up the power brick and replace the caps inside.
          • selldoor
            Slow Learner
            • Dec 2010
            • 7870
            ^^^Yes, ^^^hadnt realised it was an external power supply.
            • thestigp11gt
              • Jun 2013
              • 30
              • Scotland
              Had a look in the adapter, caps all look perfectly fine, got some weird copper paper shield around everything.
              I think I have a power supply with the same rating, I might try that and see how it goes with the monitor.
              • selldoor
                Slow Learner
                • Dec 2010
                • 7870
                Good plan here is the schematic
                the link is almost as long as the schematic!!! There are also a few threads on badcaps refer to this set.
                • thestigp11gt
                  • Jun 2013
                  • 30
                  • Scotland
                  Had the same issue with the other power supply, Monitor would not switch on,
                  I then looked to take out the hair drying, a 10 second burst inside the monitor, made it all warm, and then switched on with no problems. Not even interference through the screen.
                    The ESR of the cap goes down when heated up, so you do have bad caps.
                    • thestigp11gt
                      • Jun 2013
                      • 30
                      • Scotland
                      I will look to have them replaced then and see how she goes,
                      I am waiting on my LCD screen coming for my Arduino, I plan on making a little test matrix for caps.
                        by momaka
                        03-15-2023, 10:17 PM
                      • wattage
                        by wattage
                        Hello Badcaps Community,
                        07-13-2025, 04:41 PM
                      • ant3202
                        HP 27es - LED monitor - Monitor Flashing On - Off
                        by ant3202
                        Hi Everyone
                        Lately I am experiencing the deja-vu incident on one of the led monitor like this.
                        https://www.badcaps.net/forum/troubl...lashing-on-off
                        The monitor is HP 27es LED Monitor
                        https://h30434.www3.hp.com/t5/Deskto...e/td-p/6804692
                        The monitor will randomly blackout and display no signal and will recover again.
                        Sometimes need to power and off again to restore the display but...
                        03-20-2025, 07:30 PM
                      • Rick_1234
                        by Rick_1234
                        Good evening, gentlemen.
                        Things I tried
                        06-22-2024, 04:44 PM
                        Wise Wing F199 19'' LCD monitor - recapped
                        by momaka
                        Looking through my repair pictures and notes, it's been a long time since I posted anything in the LCD monitors section. So here goes that.
                        I'm dedicating this thread to one of the very first LCD monitors I repaired (if not the first one), which was more than 10 years ago now. The monitor is a Wise Wing, model F199. It's a 19” CFL-backlit LCD. I got it for free off of Craigslist in 2009 from a guy, who said he bought it for cheap from Wallmart and the monitor worked only for a little less than 2 years before quitting.
                        When I saw the Craigslist post, I wasn't...
                        08-24-2020, 10:58 AM
