Dell E153FPB Back Light problem
+ More Options
Latest Activity
  • PlainBill
    replied
    Re: Dell E153FPB Back Light problem
    Originally posted by freakytiki4u
    ok will do, the picture is attached of the Inverter Board.
    Great picture!! I've marked it up. The four transistors circled in red should be checked with an ohmmeter. We are looking for differences between one pair and the other.
    Also, two transformers were circled in blue. Resolder the leads on all of them.
    PlainBill
  • freakytiki4u
    replied
  • PlainBill
    replied
    I justy replaced the Pico Fuse again and its working again. What would cause the Pico Fuse to keep burning out? Please be very descriptive about location and part description as Im just a beginner board level repair newbie.
    Probably a leaky transistor. Provide GOOD pictures of the inverter board and we can identify twhat to test.
    PlainBill
  • freakytiki4u
    replied
  • freakytiki4u
    replied
    I replaced the PF751 Pico Fuse and the monitor worked for a solid week. Now it just blinks on and off repeatedly.
  • EGuevarae
    replied
    The Flat Panel I fixed has stopped working again. Now it just blinks on and off. Any ideas anyone? I was so excited to have it working.
    What did you replace in the unit (and with what)?
  • freakytiki4u
    replied
  • freakytiki4u
    replied
    Update.......I ordered the wrong type of fuse . What I ordered were not axial (no legs) they were just square as if they were meant to be popped in. They were the correct voltage and amperage so I decided to solder some legs on and put it in. It works perfectly! I have thrown out sooooo many flat panels with bad inverters that I most likely could have fixed /sigh
    Thank you guys so much for this thread.
  • freakytiki4u
    replied
    Wow, very fast reply from a few of you. I like this forum! Thank you very much. I actually just got off the phone with Digikey and have ordered what I need. Ill post if it works when I receive the parts. You guys rawk! I repair computers for a living and dable in electronics repair so if you ever need anything just ask.
  • PlainBill
    replied
    Where can these Mini Pico Fuses be purchased?
    Mouser, Digikey both carry them.
    PlainBill
  • freakytiki4u
    replied
    Originally posted by Nama
    Yet another PF751 bad. Monitor has been on now for 3 hours with no problem. Thank you for you follow up Brianh. Jacob
  • simpyborgs
    replied
    Mr Brianh...... i ask how thin is the wire you jumpered in replace with the MS 2A? or what other devices i can replace with that device? can i replace it ordinary fuse?with 2A on its spec?
  • Bobdee
    replied
    Originally posted by Bubii
    Hi Guys! I own Dell E153FPB and it has backlight problem. It works for a few secs and than the backlights turn off. The pictuire is there but no backlight. I did change pf751 and resoldered the transformers' contacts and it worked for about 20 mins (I tought it was fixed) and now it is just the same. I know it's easier to trow it in a trash but I spent so much time on research on this s##t...It was said that the problem might be the SG6841S High-integrated Green-mode PWM Controller but before I buy it I wanna know what you suggest. Help...Help...Plz.
    Thanks.
    Check out the 4 transistors on Inverter = Q739, Q740, Q759, Q760
    You are looking for shorts between the pins, if they check out okay then check there solder joints to board of the transistors with about a 10X magnifying glass looking for ring crack or any bad solder joint to resolder
    Do the same to the 2 mosfets as well Q743, Q759
    also check the rest of the board for ring cracks or bad solder joints, Benq boards always have bad solder joints
  • Bubii
    replied
    Thanks.
  • Nama
    replied
  • Bobdee
    replied
    Originally posted by choodan007
    hii bobdee ...thanx 4 ur support tatz by wrong i mention ter circuit tatz actuallyn u 850.near to that SMT on power section .itz a 8 leged ic.
    Hello again
    Your part number is SG6841S, Its a PWM controller,
    A link to part may help,
    http://cgi.ebay.co.uk/SG6841S-High-i...3286.m63.l1177
    bob
    you might want to check that mosfet and resistor by there, mine were gone
  • choodan007
    replied
  • Bobdee
    replied
    Hello choodan0007
    I have the new version E153fpf board
    (inverter/power suppy/video all on one board) in front of me, cant see a u580.
    If you have old version, is the part on the video board, if so post board number of that board, also picture if you can that may help in cross reference,this may help you,
    there are a few good pics of old inverter/powe supply on badcaps
    bob
  • choodan007
    replied
    HII somebody help me .i hav a dell E153FPf monitor itz one ic got burned i cant read that ic noumber also ,itz circuit noumber u580......plsss post that ic noumber if any one having that
  • MegaOne302
    replied
    I found an E153FPB last weekend on my way home, but when I plugged it in, it was DOA. After opening it up and checking things like the caps and fuses I couldn't find the problem. I totally past up fuse PF751 because in didn't look like a fuse; this was the first time seeing this type. The P in front means that it's a mini Pico Fuse. So Yep that was all, a bad Pico fuse PF751... I just dropped in a 2A Slow Blow from my parts box and boom, she's back to life.
    And may I ask why you put in a 3A? If the fuse blows, that's a good thing; it means it just saved the circuitry from frying or from burning down your house. So please tell me why you think it's ok to override a safety measure?
    Here's a thinker for you.
    If a fuse/breaker blows in your house, do you say hey, it was only a 20amp? I'm going to put a 30amp in so that never happens again… ?
    Thank god Spring β€˜s coming. lol
    Thanks all,
    Joe
    Lift Master Garage Door wall switch display / motion sensor controller display disappeared no back light
    by sam_sam_sam
    This happened last Saturday and today I finally had time this morning before I went to work to replace two non brand capacitors
    I will let you be the judge weather or not these are bad or not according to the blue ESR meter that I am using
    I am comparing them to a brand new one that I installed
    The display came back on and the programming was not lost which I was surprised by I would have thought that when the display went blank that so did the memory as well
    I going to let it run for several days before I remount back on the wall next to the...
    09-05-2024, 06:48 PM
  • multimesut
    Dell 2007FPB Yellow Light Problem
    by multimesut
    Hello friends,
    A yellow light was flashing on my monitor. It was like it was constantly cutting power. When I opened it up, I saw that the big capacitor in the high voltage line was leaking. I replaced it. When I turned it on for the first time, it had the same problem again. But then, interestingly, it got better. The yellow light was on steady. But the monitor wouldn't turn on. When I examined them with a thermal camera, I saw that the Fli5961-LF reached 50 degrees Celsius and the EM636165TS next to it reached 100 degrees Celsius and was drawing high current on the motherboard....
    11-13-2024, 07:00 AM
  • boyebaran
    hisense 65k560 back light problem
    by boyebaran
    hi to all
    tv turn on and show logo(backlight on)than backlight turn off than red led in front blinking 7 time. the tv remote control working fine (sound on no picture).backlight changed same problem
    in 65k560 how to remove protection of backlight? picture of inverter and sockets attached .
    please advise me tnx
    05-20-2025, 07:11 AM
  • SDNarcia
    Dell 15R-5521 keyboard problem (KBC?)
    by SDNarcia
    Hello, I have a Dell 15R-5521, with the problem that the Ctrl, Alt, Shitf and Num Lock keys do not work, I tested the keyboard with a keyboard tester and it is functional, I also got another new keyboard and the computer has the same problem with the same keys. Check continuity between the ZIF connector from the keyboard to the KBC and all pins are correct. I cleaned the ZIF connector and the KBC and I still have the same problem. I reinstalled windows just in case, and it didn't work. I updated the BIOS to the latest version A16 and there were no changes.
    As additional information,...
    07-20-2024, 10:47 PM
  • Achille15
    Dell N5110 problem
    by Achille15
    so, I have this laptop Dell Inspiron N5110 with a heating problem on both CPU (I7-2680qm) and GPU (GT 525m), I tried many solutions, like changing thermal paste every month, using thermal pads on CPU and GPU, even using thermal pads on CPU nearby coils; but nothing worked, just minutes after booting the laptop shuts itself down so I thought it might be a short problem, so I decided to check what's going on, so I went online and some tutorial (general one) said to check inductors in order to find the shorted circuit, after checking (CPU removed), I found the culprit to be...
    03-29-2025, 04:41 PM
