Im having trouble uploading better pics due to size. Not sure how to make them the right size. lol
Try Fotosizer. You drop in an image, specify a new size either in percentage of the original or in pixels, and it resizes it either replacing your original or saving it to another place (or the same place with another name). It is what I sometimes use when I have to meet size (either in Kb or in pixel dimensions) reqs.
Eduardo
I use Hamrick Software's Vueprint. (http://www.hamrick.com/upg.html) It makes cropping and reducing resolution of pictures easy. I'm sure there are other products that work as well or better; it's the one I'm familiar with.
I have a Dell E173FPs. Symptoms: Green power light just flashes quickly. No picture at all. I found 2 swollen caps and replaced them, still same thing. Green light just flashes quickly. The Power and Inverter board is model # IP-35135A (photo attached.) Anyone have any ideas what may cause this? I am looking for cold solder joints in the meantime. I have found it a good idea to just go ahead and resolder the transformers anyway as cold solder joints are so common. Srry if this is considered hijacking the thread.
Suspect shorted transistors in the inverter. A picture (larger if possible) of the bottom of the board will help us identify them. I'm curious, please post the picture even if you locate them yourself.
I have just aquired an E153FPb which was showing a green light but no display. After reading this thread I tried the fuse PF751 and that has brought the backlights on. However there is no display. Enthused by moving a stage forward I did a bit more googling to see if I could find any similar experiences and came across the folowing:- http://www.elbase.ru/files/cd/monito.../BENQ%20FP531/ This is an index of Benq technical sheets, diagrams and fault finding flowchart for the Benq FP531. The E153FPb is based on the Benq FP531 (denoted by the b). There are some variations depending on the LCD manufacturer (eg. LG, AU) This may prove useful to anyone visiting here in the future. I am currently trying to source the components I need locally and if the thread is still running when I've got them I will leave an update.
Welcome Geordieboy
Badcaps does not close Threads its always glad to recieve new Info at any time
Look forward to your update
bob
I second that. And for helping us, you can help all of the members & readers just posting your experiences. Your experience here might provide advice to new members, or not so new members that had not fixed this particular model. I guess that would be enough.
Thank you for the info. I tested and found bad transistors. I ordered a few kits from Ebay and after repair the Monitor is working just fine. A friend gave me 2 more 19" monitors and I have also repaired them. I found several cold solder joints too and fixed those also. Thanks to all of you who helped and if I can ever do anything for you just ask. I will try my best.
What is the proper way to test the Transistors? I noticed they have 3 legs each. I tested with my Ohm meter and there are differences but I would like to know specifically what Im looking for and how to properly test to determine defective ones.
Testing out of circuit with MM set on Diode Check
Red probe on B and Black on C, Should read about 600
Red probe on B and Black on E, Should read about 600
Testing for shorts between pins set MM to Buzzer and check
B + C
B + E
C + E
Probes both ways
They are either C5707s or 6s
Read the front of one, (you may need magnifying glass)
You can replace 7s with 6s if doing all four, but there are plenty of both on ebay (type in search box 2SC5607)
You can get kits with 4 transistors + 2 fets fu9024n and a 2 or 3 amp p/fuse
Thank you very much, I found the kits on Ebay and have a few on the way. I appreciate the continued quick replies. You guys really do rock!
If I want to order the 4 transistors on Inverter = Q739, Q740, Q759, Q760
for replacement, what would I ask for?
