Dell E153FPB Back Light problem
  • jschiefer
    replied
    Re: Dell E153FPB Back Light problem
    I am back, sorry i have been away for awhile. I replaced all four of the 5707's on my power board and its still not working. I am still having the problem with the monitor going on blinking white and then black. It does that a couple times and then stays black. With a flash light, i see nothing.
    I turned toward the diode trouble shooting. I have the board unpowered and was using a diode check, then reversing the leads. On some of them (all but two) i got a reading with the probes in both directions. What are the chances of all of these being bad. Thanks again for the help.
  • FredW
    replied
    Just to say thanks for the info,was given a Dell E153FPB with the indicator light flashing and got the c5707's off the interweb thingy,pulled the case apart as per your comments the inverter board was clean no burn marks but found that a couple of joints were very dry,dropped the transistors and replaced all 4 then reflowed all the joints areound the inverter,put the monitor back together and oh joy it worked been on test now for 48hours.
  • freakytiki4u
    replied
    Originally posted by Bobdee
    Have a couple of days off it then have think about it
    Good Luck
    Bob
    I wont throw it away, just set it off to the side. lol, I found a place that I can buy a refurb inverter board for $40.00 and thats not a bad price but it doesnt compare to the rewards of learning to repair my own stuff.
  • freakytiki4u
    replied
    What temparatures do you all use when soldering on these inverter boards? I think I may have used a lil too much. I use 800 degrees F and i get in and out as quickly as I can so I dont put too much heat to the board. I use a radio shack soldering station ( i know I know, LOL) and 840 degrees Farenheit is its max temp.
  • Bobdee
    replied
    Originally posted by freakytiki4u
    You are correct. I just pulled the C5707's out and checked them with my MM and 1 was bad again. I replaced all 4 just to be sure but now 1 of the legs on one of the C5707's refuses to take any solder. I cleaned the area and am using rosen core solder but it will not take solder. I think that spot has just be soldered too many times. Im going to scrap this monitor also. Thank you for your assistance Sir
    Good Luck
    Bob
  • freakytiki4u
    replied
    The Power LED Just blinked repeatedly.
  • Bobdee
    replied
    The Flat Panel I fixed has stopped working again. Now it just blinks on and off. Any ideas anyone? I was so excited to have it working.
    Hello freakytiki4u
    What did you mean in the above old post, did LED blink on/off or the screens B/Lights
  • freakytiki4u
    replied
  • Bobdee
    replied
    The Dell E173FPB I repiared is at it again. When I plug it in I see the Dell Logo for just a split second and it goes dark. Using a flashlight I can see the Dell Logo is still there, just not lit up. I have replaced the Pico Fuse and all 4 of the C5707's and it worked for a few weeks. Now its back to doing the same thing. I have resoldered every connection that even looked funny. I paid particular attention to the spots reccomended on the forums. Any other idea's or things I can test? Thanking you in advance.
    Pictures are attached
    If you resoldered all 4 Inverter Transformers then it is possible that you have a failing CCFL
    Its is probable that you now have a failed C5707 again due to the initial fault being missed
  • freakytiki4u
    replied
  • PlainBill
    replied
    Originally posted by jschiefer
    Thank you PlainBill, I will upload pictures tomorrow. In the mean time I tested the transistors again and I'm getting continuity between the collector and emitter, which means they are bad right?
    Define 'continuity'. If you mean 10 ohms or less, you are exactly right. This is a fairly common problem with these boards. Here's what you do:
    Check for C-E shorts on all four transistors (circled in red). If only one of a pair is shorted, replace both. Check the FETs for shorts (circled in blue). Replace if shorted, natch. IMPORTANT: Resolder all terminals on the transformers, even if they look good.
    The parts can be found on eBay. You can buy kits of all parts, or if all you need are just the transistors you can buy them.
    PlainBill
  • jschiefer
    replied
  • PlainBill
    replied
    Yes they all were. Its a cheap meter so i thought they were find.
    I also looked at my LCD with a flashlight to see if i can see the image after it flashes white and i cant see an image. What does this mean?
    It means something isn't working; probably either the logic card or the panel.
    Take a good quality picture of both the top and bottom of the power supply / inverter. Don't use someone else's picture this time. There are at least two different versions of this monitor. Attach it to your next post.
    PlainBill
  • jschiefer
    replied
    Different brands of meters give different results. Were the results the same for all transistors?
    PlainBill
  • PlainBill
    replied
    I tested mine and got about 426 is that too far off?
    PlainBill
  • jschiefer
    replied
    Testing out of circuit with MM set on Diode Check
    Red probe on B and Black on C, Should read about 600
    Red probe on B and Black on E, Should read about 600
    Testing for shorts between pins set MM to Buzzer and check
    B + C
    B + E
    C + E
    Probes both ways
  • PlainBill
    replied
    So I read pretty much the entire thread and im afraid im still not sure where to start. I have the Dell E153FPB. When i turn on the LCD screen it flashes white for a second and then goes black. I cannot see any image on the screen but the LED power light stays on.
    I tested the fuse PF751 with an ohm meter and it has resistance, so im thinking its not that.
    I also flipped the board over and didnt see any cold solder joints, fixed a couple that were debatable.
    Sorry if this is a double post. I couldnt look any longer lol
    Start with post 31 of this thread and follow the same advice.
    PlainBill
  • EGuevarae
    replied
    How do i test capacitance of the caps? I have a multimeter...
    I was referring to the specs of the actual caps installed, not the actual capacitance of the caps. If they are a known bad brand , suggestions of replacements would start flowing all over the place. That would be the first step for troubleshooting the board. Not all the problems are related to bad caps, but then again, bad caps can cause problems and interfere with troubleshooting, and as a general rule, if you are going to spend sometime with an open unit, it is usually viewed as a preventive measure, even if the caps are not failing but are of a brand that, under that conditions (heat and poor ventilation) would fail.
    Also, again, look for bad solder because that units tend to have that problem, even if it is not easily visible with the naked eye.
  • jschiefer
    replied
  • EGuevarae
    replied
    Used a flashlight to see if the panel is on and image is displayed (you would not see it clearly if the CCFLs are off but if you don't have an image, it's not the inverter or tubes.
    Post series/brand/capacitance of caps, and test each of the four c5707s in there.
    Lift Master Garage Door wall switch display / motion sensor controller display disappeared no back light
    by sam_sam_sam
    This happened last Saturday and today I finally had time this morning before I went to work to replace two non brand capacitors
    I will let you be the judge weather or not these are bad or not according to the blue ESR meter that I am using
    I am comparing them to a brand new one that I installed
    The display came back on and the programming was not lost which I was surprised by I would have thought that when the display went blank that so did the memory as well
    I going to let it run for several days before I remount back on the wall next to the...
    09-05-2024, 06:48 PM
  • multimesut
    Dell 2007FPB Yellow Light Problem
    by multimesut
    Hello friends,
    A yellow light was flashing on my monitor. It was like it was constantly cutting power. When I opened it up, I saw that the big capacitor in the high voltage line was leaking. I replaced it. When I turned it on for the first time, it had the same problem again. But then, interestingly, it got better. The yellow light was on steady. But the monitor wouldn't turn on. When I examined them with a thermal camera, I saw that the Fli5961-LF reached 50 degrees Celsius and the EM636165TS next to it reached 100 degrees Celsius and was drawing high current on the motherboard....
    11-13-2024, 07:00 AM
  • boyebaran
    hisense 65k560 back light problem
    by boyebaran
    hi to all
    tv turn on and show logo(backlight on)than backlight turn off than red led in front blinking 7 time. the tv remote control working fine (sound on no picture).backlight changed same problem
    in 65k560 how to remove protection of backlight? picture of inverter and sockets attached .
    please advise me tnx
    05-20-2025, 07:11 AM
  • SDNarcia
    Dell 15R-5521 keyboard problem (KBC?)
    by SDNarcia
    Hello, I have a Dell 15R-5521, with the problem that the Ctrl, Alt, Shitf and Num Lock keys do not work, I tested the keyboard with a keyboard tester and it is functional, I also got another new keyboard and the computer has the same problem with the same keys. Check continuity between the ZIF connector from the keyboard to the KBC and all pins are correct. I cleaned the ZIF connector and the KBC and I still have the same problem. I reinstalled windows just in case, and it didn't work. I updated the BIOS to the latest version A16 and there were no changes.
    As additional information,...
    07-20-2024, 10:47 PM
  • Achille15
    Dell N5110 problem
    by Achille15
    so, I have this laptop Dell Inspiron N5110 with a heating problem on both CPU (I7-2680qm) and GPU (GT 525m), I tried many solutions, like changing thermal paste every month, using thermal pads on CPU and GPU, even using thermal pads on CPU nearby coils; but nothing worked, just minutes after booting the laptop shuts itself down so I thought it might be a short problem, so I decided to check what's going on, so I went online and some tutorial (general one) said to check inductors in order to find the shorted circuit, after checking (CPU removed), I found the culprit to be...
    03-29-2025, 04:41 PM
