Hanns G HG281D Monitor Problems
  • Pootarts
    • Oct 2013
    As the title says I'm having trouble with my Hanns G HG281D monitor. The monitor will display picture but it takes some time. With the monitor on and my computer on the light will go from orange to blue and stay blue when it has signal. After about 10 mins with signal (black screen the whole time) the picture will blink in for a split second then go black for a while and continue to do this for 5-10 min until the picture stays. Once the picture stays, the monitor is just fine (picture quality). After picture is on, every 30 min the monitor will flash black then back to the picture.
    I just replaced all the caps on the power supply board (none looked bad but better be safe on this board) and it looked to work at first glance but instantly went back to doing the blinking. Also after i changed the caps the buttons to control the interface do not work. I may have pulled one of the wires so ill check that.
    My question is does this sound like a problem that can be fixed with changing the caps on the logic board? Also if I didn't pull a wire what could be bad with the buttons? Any input would be really appreciated.
  • jpb7875
    • Nov 2013
    Re: Hanns G HG281D Monitor Problems
    I had this same problem and was able to find a post buried on this forum that helped me fix the problem. I thought I would post my findings and hopefully it will help others with this same issue.
    My HG281D monitor would turn on and then blink and flash the image for about 10 minutes and then finally start working fine. I would occasionally see the amber light or artifacts on-screen during this warm-up phase, but after the monitor warmed-up, there would be no issues until I turned it off again.
    The problem is not on the power board.
    The problem was bad capacitors on the interface or main board. This is the board that has the HDMI and VGA sockets. I replaced all of the 100uf capacitors on this board and the monitor is now working perfectly.
    I posted an image of the board. The capacitors I replaced are labeled 1-5 in purple. The capacitors can be bought from anywhere, but I purchased these on ebay as a "HG28D1 main board repair kit". I'm certainly no expert when it comes to soldering.The final product was a little sloppy to say the least, but it works! I hope this helps.
      You need to replace C80, 83 (100UF 16V) on the main board.
      https://www.badcaps.net/forum/showth...=11329&page=26
      http://s807.photobucket.com/user/bud...ml?sort=3&o=14
        by momaka
        03-15-2023, 10:17 PM
      • Schwoin
        Philips 243v5lhsb00 Monitor Picture too bright
        by Schwoin
        Hey everyone,
        the picture on my philips monitor looks way too bright so that black appears grey and colors also seem too bright.
        While i tried to tilt the screen a little bit while it was displaying a picture, i´ve noticed, that there appeared some purple pixels. In the following picture
        you can see them on the top half of the photo.
        At a certain point during the tilting, the picture looked normal again but as soon as i laid it back down, the purple pixels were gone and the picture was bright again.
        03-21-2023, 12:40 PM
      • RetroComputingGrotto
        Hanns.G Hi221 Monitor - Works For A Second & Then Blank Display
        by RetroComputingGrotto
        I've got a Hanns.G Hi221 Monitor that works for a moment and then the display goes off but the power LED indicator remains on. If you power it off and back on again it does the same thing, it comes on and then the display goes blank. From a cold start it takes 10 seconds or so before the display goes blank but if you turn it off and then back on again after it already being on it goes blank a lot quicker so I'm assuming something is getting hot which is causing the display to go off.
        I've uploaded a video of it happening on YouTube:
        I've taken the monitor...
        01-11-2024, 05:37 AM
      • eurgenca
        EGT monitor with bad picture. Help please.
        by eurgenca
        Hello.
        I am struggling with EGT LED monitor. Panel is made from AUO.
        I have 1/4 good and 3/4 bad pictures like you can see from the pic.
        So far I checked power supply and it is ok. I cleaned connection from panel to LVDS and LVDS to digital board. No luck.
        What is the problem with this LCD?
        Pannel, LVDS or digital board. I have no idea so please help me someone.
        Regards, Sebastijan....
        07-26-2025, 06:10 AM
      • ant3202
        HP 27es - LED monitor - Monitor Flashing On - Off
        by ant3202
        Hi Everyone
        Lately I am experiencing the deja-vu incident on one of the led monitor like this.
        https://www.badcaps.net/forum/troubl...lashing-on-off
        The monitor is HP 27es LED Monitor
        https://h30434.www3.hp.com/t5/Deskto...e/td-p/6804692
        The monitor will randomly blackout and display no signal and will recover again.
        Sometimes need to power and off again to restore the display but...
        03-20-2025, 07:30 PM
