I've got a Dell U2311H, which will operate for some amount of time, and then turns off and becomes completely unresponsive (no LED, no voltage on the power supply lines) until you unplug it for awhile, and plug it back in.
A picture of my board:
What I've done:
1. Checked all the caps with an esr meter, they measure fine (but presumably could still be the issue with the below symptom?)
2. Tracked what is happening, but not the actual cause, down to the IC protection circuit (tea1530):
The voltage on the protect pin of the IC quickly goes up to about 2v, and then slowly increases to >2.5v at which time the IC latches into protection mode and will not resume operation until the Vcc drops below 4.5 volts (as per the datasheet, only will occur after removing the mains).
3. The longer the monitor is unplugged seems to effect how long it operates before shutting down. If it is only disconnected long enough to reset the IC operation, the protection hits 2.5v fairly quickly (seconds) after plugging it back in.
4. I have no idea what the protection circuit is doing or is meant to do
Thoughts? Should I just replace all the caps anyway?
What I've done:
