bad cap with proper capacitance?
  • rswails
    • Jul 2013
    • 7
    Is this possible? I've searched around some and I get get a straight answer on this.
    I have a 50v 22uF cap on my hp 22" LCD power plus inverter board that I was wondering about. I replaced that cap with same one from another of the same exact LCD and one of the caps works on the display and one doesn't. Both caps test within tolerance capacitance of 21.X uF. There is no bulging. Could one of these be bad? Can the capacitance test ok but you still have a bad cap? If not I guess it could be a bad solder, but the solder looked good to me. If this has been answered before then please share the link, or let me know how to find the link and I'll put it here.
  • LLLlllou
    • May 2011
    • 201
    Re: bad cap with proper capacitance?
    It's not terribly common, but it does happen. Electrolytics are strange animals. Assuming it is actually a bad cap, ESR is probably through the roof. Putting the "bad" cap back in will tell you if it was just a bad solder joint.
    • rswails
      • Jul 2013
      • 7
      Forgive me I left out another problem. I didn't want to mess with those traces anymore because one of the holes in the trace by the cap lead started to lift off the PCB and I'm not sure how many more times I can resolder caps in that spot. I guess I could drill a new hole since its a wide metal contact portion of the PCB if I ruin that spot. I take it there isn't any other way to test that cap without and ESR tester, or just trying it on a board?
      • LLLlllou
        • May 2011
        • 201
        You could check it for leakage. Apply voltage to the cap from a battery or PSU, with a DMM in series to measure current. You might want to put a 1K resistor in series, in case it's a dead short.
        Without an ESR meter that's about all the info you can get from a cap.
        • rswails
          • Jul 2013
          • 7
          Good info. Thank you very much. I'll try that and maybe this too http://www.edaboard.com/thread39728.html#post180196 which I found after you told me about leakage.
            master hoarder
            • May 2008
            • 12175
            Is this possible?
            you bet!
            I have more than a few like that in my junk/tinker bin. Most of these just have ESR that is too high.
            Now get this, you can also have caps that show fairly okay capacitance and ESR. The only caps I've seen this happen to is Nichicon HM that were built within their problematic period between 2001 and 2004.
            My guess for this would be that these caps develop high internal leackage, hence fooling the ESR meter into thinking they are low ESR.
            Thus, another method I often perform (with caps removed from the circuit) is to charge the caps up and then short their terminals too see if they'll throw a spark. Most good caps above 470uF will/should.
            • Pentium4
              CapXon Be Gone
              • Sep 2011
              • 3741
              Yeah, have seen a 22uF 50V cap read 21.1uF and 33.6 ohms of ESR, in this case it was the startup cap and the monitor would not turn on (Ltec in a Viewsonic)
                master hoarder
                • May 2008
                • 12175
                33 Ohms ESR? ...
                Not as bad as a 50V 4.7 uF HEC cap I have. That one was in a gutless J&C PSU with a feedback-less self-oscillating 5VSB circuit. When it went, it took out the 5VSB with plenty of burn marks on the board. Burned itself up quite badly too. The sleeve was supposed to be light blue, but instead it was dark gray . And ESR?... 110 Ohms!
                Confirmed another case of this today. This one is different from the problematic Nichicon HM and HNs.
                The capacitor in question was a 16V 1500 uF Panasonic FL out of an Xbox 360. Last week, I pulled a bunch of them off of dead 360 boards. This one was from a "slightly mishandled" board, so some of the caps got bent enough to pull from their leads on one side. The lead on this cap was only very slightly pulled, so I marked it as questionable and proceeded to remove it. Good thing I didn't put it in my "reuse" jar, because this cap is obviously bad. The ESR Micro showed good capacitance and good ESR, but the cap failed the "spark test" I mentioned in my post above. I've tested many of these 16V 1500 uF caps with that test. When I charge them with a 9V battery, then remove the battery and short the terminals of the cap against a metal surface, a spark always results. If it doesn't, then the cap has become either high ESR or developed too high of an internal leakage.
                • chth96
                  How Can I test PWM DM0365R?
                  by chth96
                  Hello
                  I have power adaptor(220V/input, 12V 1.2A/output) which has symptom of fluctuating output DC voltage between 11.5V-12.2V.
                  So I opened its plastic case and when switched it on, I heard constant tik tik sound from inside its PCB.
                  I measured DC voltage between negative and positive pin of the largest capacitor(400v 10uf) and it was measured contant 300V.
                  I also measured ESR value of all capacitors and I noticed that one of capacitor(KMG 16v 470uf), which located in the secondary side, have high ESR value(10 ohm),So I replaced it with same specification NXH capacitor....
                  06-18-2025, 04:14 PM
                • langbaobao
                  DIY 3D-Printer WSON8 Pogo Pin Adapter
                  by langbaobao
                  Hi.
                  I'm posting this here in part as a memo to self as well as to describe the procedure I used in case anyone else found it useful. I found a lot of the necessary information to make this work on this forum and I figured I would give something back. If this is not the appropriate place to post this, I don't mind it being deleted but I hope it can help other people.
                  I got an admin password locked HP Elitebook 840 G5 recently that I wanted to unlock. I'm a relative newcomer to reprogramming and unlocking firmware. The only previous experience I had was unlocking a BIOS...
                  01-08-2024, 05:58 PM
                • khelane
                  test active pfc power with lamp test
                  by khelane
                  Hello
                  I have a big problem and that is that in some cases when repairing active pfc power supplies I cannot work with a test lamp. I can only get help with 5 volts standby and for starting and starting I have to work without a lamp and this way there is a possibility of parts exploding and other parts being added.
                  Sometimes with a multimeter test the problems can be reduced to some extent, but I had several cases that had to be tested on and online and recently two varistors exploded. They had terrible resistance because the power supplies were over 800 watts.
                  Is there a way...
                  06-03-2025, 01:00 AM
                • chronic519
                  Mats / mods: detected and repaired GPU fault. Cant seem to test after!
                  by chronic519
                  Hello.
                  GPU came in, green lines. Spent lots of time using to get the Mats / mods drive working (found on youtube).
                  Found issue with a RAM block
                  Replaced, green lines gone.
                  Trying to test again, assuming getting the false positive. Originally had over 1K on a single bank. Now getting tosses low between banks.
                  Used a good card to test and same results low errors 32+.
                  I am just search for some form of command to do a full test on the GPU.
                  I just ran the mats command with my good GPU and passed after roughly 40 min.
                  The repaired one, ran...
                  05-20-2025, 07:56 PM
                • ttmi100x
                  HANNSG Hi221 -- 2 secs to black feat. CCFL flicker & "burn" marks on power board
                  by ttmi100x
                  Greetings everyone,
                  I have a HANNSG Hi221 monitor that exhibits two seconds to black issues (backlight goes off, display is still on as confirmed by shining a flashlight on it) with some additional oddities...
                  The monitor failed on me with a standard "2 seconds to black" some time ago prompting me to initially replace most of the electrolytic capacitors (some of them were bulging/leaking).
                  Things kinda sorta worked for a night, then the problem returned along with some flickering and "buzzing" noises.
                  Upon closer inspection...
                  07-31-2024, 06:36 PM
