Hanns-G HG281D 'column shimmer' and start up problems
  • LexGoyle
    • Feb 2012
    • 5
    Heya!
    Finally getting around to trying to fix this monitor that's having some issues. I had taken it apart initially after finding this forum last year. There were no visibly bad capacitors and to be honest I wasn't sure about checking the ESR because I wasn't too keen on the idea of working near an exposed power supply and didn't feel confident with that.
    I feel it important to note that this monitor was also sent in to Hanns-G for repair after a loud 'pop' it made and wouldn't come on. When it came back there was no documentation as to what they did but the controls were different and I actually had an option to choose from fit/full aspect ratio. The logic board I believe was replaced as it listed some revision 4 something on it and the HDMI port was tighter and easier to keep the cable plugged in.
    The screen worked fine for about a year and a half afterward.
    Here's what happens on the monitor now:
    Upon powering on, it would come on. Then about 5-10 seconds later or so (the time varies) the screen would go off, then come on, off again a second later, back on for a second, off for about 10 seconds, then on again. The pattern and interval of this is random and lasts anywhere between 30 seconds to around a minute at worst. If it helps there is no sort of 'clicking' sound with it that at one point happened with this screen when it would change resolution for example.
    After it goes through that fit it will stay on just fine and will do it again upon a cold start. The picture is as expected with this monitor with the exception of one detail. In seemingly random columns there is this 'shimmer' effect like random blocks of pixels along that column change color tones to something slightly brighter than the color in that area.
    It's hard to explain but it's hard to see overall but it catches your eye and is more apparent with certain colors. So it's like it's adapting to color but just those pixels go brighter or darker or something. I've attached a picture I snagged that shows it. It's a bit of large image which was needed so you can see what I'm talking about. Please pardon the spelling error in the pic. :P
    I've tried this on different computers, different video cards in the same systems with different HDMI cables that are known to work fine. So right now I'm at a loss. Any help would be appreciated.
    Last edited by LexGoyle; 06-15-2013, 02:45 PM. Reason: fixing up the post to include details about the attachment.
  • leapius
    • Aug 2012
    • 60
    Re: Hanns-G HG281D 'column shimmer' and start up problems
    From the symptoms you describe I would suggest it is bad capacitors on the PSU causing this. Remember bad capacitors might not show any visual signs (indeed ones causing intermittent problems like this are more likely to be still working but on their way out). Your best bet is to test the voltages coming from each pin outputting from the PSU when it is on (be careful!) and reporting them here for the experts to see. But the black probe on a grounded screw and the red probe on each output pin and note the voltage. Take special note of any pins producing fluctuations in voltage. The artifacts could be from a voltage ripple to the a/v board and/or tcon.
    • Lumberjack777
      • 464
      Correct, in fact in this monitor the small capacitors in the power supply tend to dry out with no signs of bulging.
      Hey Lex. If your power supply looks like this you need to replace the 3 caps circled in red on my attached photo.
      Then on the main board replace the 2 caps budm suggests in this photo.
      http://s807.beta.photobucket.com/use...62664929957295
      That should take care of both problems you are having. Fixed 4 of these. The problem was always the same 5 capacitors. 3 on the power supply and 2 on the main board.
      • 1supertech
        • Apr 2012
        • 384
        I would also change caps in red under heatsink
        • lexwalker
          • Feb 2011
          • 307
          • Malaysia
          Possible badcaps somewhere. Also check the inverter transformer section, especially the transformer...
          Seen this before. Besides possible badcaps, the most obvious source of this problem is the LVDS section. Try cleaning the FFC/FPC connectors (on both Tcon and Dscaler board side) and contacts on the LVDS cables first.
          Example of a severe dirty LVDS connection (see attachment). On areas with lots of identical colors, the effect is not apparent. The shimmers and noise becomes more apparent as they appear randomly and gets worse on lines/rows with more picture details (e.g. more color changes per pixel, fine lines, dithering patterns, etc). That's an old ancient Acer AL1717B, by the way...
            The two caps on the main board when they are bad will get bad pictures with noise and lines running on the screen, when put on native resolution it will black out, turns itself off, but it will look normal and will stay on if you put it in lowest resolution. I would replace those two caps on the main board first.
            • LexGoyle
              • Feb 2012
              • 5
              Thanks for all the replies. My power supply appears to be a different model than the one pictured. I'll try doing a voltage test and get some caps ready to be ordered. I'll post an update and let you all know how it turns out.
              • LexGoyle
                • Feb 2012
                • 5
                Thanks again for the help everyone! I've replaced the two capacitors on the logic board as Budm suggested and the problem is gone. So far it's been running for 3 hours and still no 'shimmer' or troubles with the start up like before.
                On a side note desoldering.... pain in the butt. :P The wick I used I guess was too narrow or something because it didn't work out as easily as it showed in the videos online. Ah well. Saved the monitor for basically a few bucks and gained some experience.
                  Glad to hear the problem is fixed, you may want to look into a set of caps for the power supply board next.
                  • jean luc ferre
                    laptop hp g72 b52sf screen problems
                    by jean luc ferre
                    on this laptop hp g72 b52sf i have screen problems as you can see with the photo joined in attachments.
                    the used graphic card is "intel hd graphics" and the id of the integrated screen is : "monitor/SEC3354".
                    i verified the driver of the péripherals and they are ok. i verified the definition and settings of the graphic card and of the screen : definition 1600x900 and refreshment frequency :60hz. (they are the sames for the graphic card and the screen).
                    i don't understand the reasons of the white stripe at the bottom of the screen below the task...
                    06-07-2025, 03:27 PM
                  • Hondaman
                    USB problems?
                    by Hondaman
                    Recently I discovered my SSD died (OCZ/Toshiba 240 GB). It was in a USB enclosure, attached to the Linksys WRT-AC1200 router. Since then I removed the USB enclosure and attached it to my Win7 PC (AMD 8150 CPU, 970 chipset, 64 GB RAM). I also gathered one or two other USB enclosures to figure out what is going on.
                    (I suspect that I lost quite a few MP3 and FLAC files I recently ripped from my audio CDs, I think I lost very little un-replaceable stuff.)
                    I think it is IMPOSSIBLE for Win7 to have any problems with a USB enclosure as long as Win7 knows how to speak to the...
                    08-12-2024, 03:26 PM
                  • clabr
                    Lenovo 11e problems (any sata hdds are not recognized, sleep battery drain)
                    by clabr
                    Need help to solve some problems with this laptop.
                    After working in bed with it one night and heating up too much (probably the cause of this problems) the sata HDD OS windows froze
                    After restart the original Sata HDD was not recognized anymore (but works fine in other laptops or PCs)
                    Tried connecting other good Sata 2.5 HDDs but not one is working in this laptop anymore (not the original nor others)
                    Before this had happened I observed some other problems:
                    When I tried replacing original mecanical HDD with a SSD HDD could not get them...
                    12-02-2021, 08:09 AM
                  • jean luc ferre
                    display screen problems after changing motherboard
                    by jean luc ferre
                    First on my laptop i had a motherboard with a pentium 6100 processor. Installing w11 i was blocked on the 23h2 version...impossibility to upgrade toward 24h2 because the SSE4.2 functionnality of the cpu was missing. About displaying and screen looking all was perfect.
                    I changed of motherboard with an intel I3 processor...and now i don't find the previous aspects of the displaying.
                    Now i have a veiled screen and pixels are missing though the graphics parameters have not changed.
                    Desinstalling and reloading the drivers in the same time on the graphic card (intel hd...
                    09-11-2025, 10:28 AM
                  • rumpumpel1
                    Lenovo X13-Yoga Gen 1: hibernation problems
                    by rumpumpel1
                    I have a Lenovo X13-Yoga Gen 1 that has problems with hibernation mode. When the laptop goes to hibernation mode - either via the start menu or after a time-out - after a short period of activity where the power-on LED flashes, the power consumption should go down to almost 0 and the LED should go out. Most of the time, however, the power consumption indicates further CPU activity and the power LED remains on, but there is no image. Sometimes the CPU activity stops after a few minutes, sometimes not at all. If the laptop enters this state, it can only be brought back to life by a long press on...
                    11-03-2024, 12:31 AM
