Fujitsu Siemens 23" LCD Scaleoview
  • bibilit
    • May 2013
    • 20
    • Montrouge
    I collected this display for free yesterday, was advertised as a non working unit.
    The previous owner explained that the display stopped working, now only showing a white screen.
    I have removed the back cover, and the power supply has 3 bulging caps
    The bads ones are Xunda brand, so probably a chinese poor quality product.
    (2 x 220 µf 25 v and 4 x 680 µf 25v)
    Also two Su Scon caps on the same board (taiwan ?) (470 µf 25 v)
    I will probably remove all those and try a recap.
    What capacitors will do the job ?
  • Rtech
    • Jul 2010
    • 1095
    Re: Fujitsu Siemens 23" LCD Scaleoview
    Panasonic FR range should be good.Make sure that the Physical sizes of the new caps are similar to the original,if there is a cover over the top etc.
    • bibilit
      • May 2013
      • 20
      • Montrouge
      Thanks,
      No no cover over the top, the board is connected upside down.
      I have found a set of Rubycon XYG but those are 330 µf 35 v and 680 µf 35 v
      will those be suitable ?
      • sabre504
        • May 2010
        • 449
        • United Kingdom
        Hi i would change all the ones mrked in red
        and stay with the same uf but you can go up in voltage as long as they are the correct size and fit
        • bibilit
          • May 2013
          • 20
          • Montrouge
          Hi, thanks,
          Most of them already removed, will let you know.
          • bibilit
            • May 2013
            • 20
            • Montrouge
            So just a quick update, i removed all advised caps, collected the required units and soldered back (Panasonic FR)
            And the display came back to life
            ps: sorry for the bad pics
            • sabre504
              • May 2010
              • 449
              • United Kingdom
              Well done
              • 0burn0
                • May 2014
                • 16
                • Serbia
                i have the same problem with my Scaleoview 23" monitor
                but i dont see any bulging caps do you have any suggestions?
                • selldoor
                  Slow Learner
                  • 7870
                  They dont have to be bulging to be bad - if you have the same caps they
                  are not a good brand so a good start would be to replace them.
                  • 0burn0
                    • May 2014
                    • 16
                    • Serbia
                    ok i will buy today all caps
                    i checked voltage from PSU and it is showing correct voltage dont have any voltage drop
                    14v and 5v
                    but when display goes to sleep its showing 19v on 14v output
                    • bammbammfran
                      • Apr 2014
                      • 476
                      Capacitors might not be your problem if the voltages are stable !!
                      Pictures of your board would help !
                      Does the power button turn on and off the power led indicator ?
                      Does the screen flash on for a second ?
                      • 0burn0
                        • May 2014
                        • 16
                        • Serbia
                        Display is not flashing for a second its white and lights are working
                        i cant see menu when i press menu button its just white screen
                        heres photo of PSU
                        • 0burn0
                          • May 2014
                          • 16
                          • Serbia
                          yes power button turn on and off led indicator
                          its not flashing i got constant white screen
                          • bammbammfran
                            • Apr 2014
                            • 476
                            ok
                            You are going to need to post pictures for any further help
                            One picture should show the entire back of the screen with the boards in place
                            and then at least one of the main input board and one of the power supply
                            I think that the power from the main input board is not getting to the lcd panel
                            • 0burn0
                              • May 2014
                              • 16
                              • Serbia
                              • 0burn0
                                • May 2014
                                • 16
                                • Serbia
                                ok
                                Thanks for your help
                                if you need more photos i will post
                                  heres photo of PSU
                                  Can we see the screen shot of this symptom?
                                  • 0burn0
                                    • May 2014
                                    • 16
                                    • Serbia
                                    Originally posted by budm
                                    can we see the screen shot of this symptom?
                                      It looks like the T-CON board on the LCD panel is dead due to not getting the power from the main board, the connector (LVDS) is not installed corectly, blown fuse on the T-CON. Please recheck your works.
                                      • 0burn0
                                        • May 2014
                                        • 16
                                        • Serbia
                                        here is panel psb screenshot's
                                        • Thermaltake
                                          Fujitsu Siemens Amilo Xa 3530
                                          by Thermaltake
                                          Hi, I got this Fujitsu Siemens Amilo Xa 3530 Model: MS2244. from a friend and it is powering On, but only functional keys lights up, fan spins and nothing else, screen is black no backlight, and it's staying like that forever. I tried other memory that I know is working, I tried to empty capacitors by holding power button without battery but still nothing. I didn't try new cmos battery, need to disassemble it first to try that. But I don't think even if cmos battery is dead it would give some backlight and picture...I kind of think it's chipset or gpu dead.
                                          I read something on google that...
                                          02-01-2024, 12:34 PM
                                          Fujitsu LIFEBOOK LIFEBOOK U7511 Notebook U Specification for Upgrade or Repair
                                          This specification for the Fujitsu LIFEBOOK LIFEBOOK U7511 Notebook can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the LIFEBOOK U7511 boardview and LIFEBOOK U7511 schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties that any specification, datasheet,...
                                          09-07-2024, 03:40 AM
                                          Fujitsu LIFEBOOK LIFEBOOK U7411 Notebook U Specification for Upgrade or Repair
                                          This specification for the Fujitsu LIFEBOOK LIFEBOOK U7411 Notebook can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the LIFEBOOK U7411 boardview and LIFEBOOK U7411 schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties that any specification, datasheet,...
                                          Fujitsu LIFEBOOK LIFEBOOK U9311 Notebook U Specification for Upgrade or Repair
                                          This specification for the Fujitsu LIFEBOOK LIFEBOOK U9311 Notebook can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the LIFEBOOK U9311 boardview and LIFEBOOK U9311 schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties that any specification, datasheet,...
