Dell 2007FPb cannot stay on
+ More Options
Posts
  • gengtian
    • Apr 2013
    • 18
    I picked up a Dell 2007 FPb from someone else. Its symptom is after power on (press the on/off button), the initial Dell logo animation just shows up for less than half second and then black screen. The power led stay green and with flashlight at 45 degree I can't see any image. After reading a few threads about this monitor, I guess it is somewhere on the inverter board but could find any obvious defect part. So I took pictures for all the four boards and try to see whether expert here can give me some suggestion. Thanks a lot.
  • selldoor
    Slow Learner
    • 7870
    Re: Dell 2007FPb cannot stay on
    In the last picture there is a small yellow torpedo fuse - test it. Should be ok as you do get a flash. Next test the secondary windings on the 3 transformers on that same board.
    • gengtian
      • Apr 2013
      • 18
      Sorry. I was away for a week from my office. I test the resistence of the yellow fuse by multimeter, seems to be OK. How to check the transformer? Should I put the four boards together and plug in? Thanks.
        https://www.badcaps.net/forum/showth...fpb#post335335
        Check the inverter transformer secondary side resistance.
        If you search the '2007fpb', you will get lots of threads.
        • gengtian
          • Apr 2013
          • 18
          I did checking according to the post:
          https://www.badcaps.net/forum/showth...pb+transformer
          The resistence between 5 and 6 is out of my multimeter reading range for all the three transformers, between 7 and 8 is something around 9 Milliion om for all three of the them. When I hook up all the four boards together and plug in the the inverter connector in to A,B,C,D separately, I could not see the screen was lit up after turn on the power. How to see the "lamp flash briefly"?
          Thanks.
            Pin 8 and the bottom pin where the dot is that is one high voltage winding for the left side of the transformer, pin 5 and the bottom right pin is for another winding, it should be around 1000 Ohms.
            Same pin out as this one:
            http://s807.photobucket.com/user/bud...tml?sort=3&o=2
            • gengtian
              • Apr 2013
              • 18
              I checked the resistence, all six pairs are about 1060 ohms except the right most (ie the pair for the pin 5 as labelled) is 1389 ohms. Do you think this reading ok?
              Thanks.
              • retiredcaps
                • Apr 2010
                • 9271
                No, it (1389 ohms) is bad. The readings should be within 3% of each other.
                --- begin sig file ---
                --- end sig file ---
                  2nd that.
                  • gengtian
                    • Apr 2013
                    • 18
                    Thanks for both of you. What "keyword" shall I use to find a replacement on those website such as digikey.com or newark.com? The label on top of them is 1J.26061.001 4001R 613003
                    • retiredcaps
                      • Apr 2010
                      • 9271
                      I don't see any replacement parts for a 4001R on ebay or http://lcdparts.net/T.aspx.
                      • retiredcaps
                        • Apr 2010
                        • 9271
                        BTW, everything you have described and tested is in the FAQ "2 seconds to black" starting with post #19 (latest revision).
                        https://www.badcaps.net/forum/showthread.php?t=10419
                        • retiredcaps
                          • Apr 2010
                          • 9271
                          I forgot that an USA member might also have the 4001R transformer from a repair gone bad. If you are interested, I can send him an email to see if he still has one and put you two in contact?
                          • gengtian
                            • Apr 2013
                            • 18
                            Thank you very much for your generous offer and very nice helps. I found the inverter board sold on a Chinese ebay site and decided to jump into there. Thanks.
                            • gengtian
                              • Apr 2013
                              • 18
                              Just to update. I finally received the inverter board from the Chinese ebay store and now the monitor works. Thank all you guys very much for the helps.
                              One more thing, just found on ebay this inverter board is also available now for $20 from a US seller.
                              • Bowline
                                by Bowline
                                06-11-2025, 10:13 AM
                              • Akhlz001
                                by Akhlz001
                                09-20-2025, 07:15 PM
                              • ckom26
                                Dell 2007FPB compatible boards
                                by ckom26
                                Hello, folks.
                                Please, forgive this dumb question but I own a 2007FPb whose logic board is FUBAR (really). Obtaining a replacement is not easy any more (or unreasonably expensive) so I was wondering if replacing the logic board with one from the same line (e.g. 1708FP or 1907FP) would bring it back to life. Are the resolution capabilities for each one "hardcoded" into the main GENESIS chip or auto-sensed and applied? Has anyone tried something similar?
                                07-04-2025, 07:02 AM
                              • master3112
                                by master3112
                                07-29-2025, 01:55 PM
                              • totalgearhead
                                Dell 2007FPB Component ID Help please!
                                by totalgearhead
                                Hi All, I need help identifying a replacement for D1 (same as D2 through D5) on the Dell 2007FPB board please? The board ID is an LG Philips LM201W01-SLC1-F11. Thank you for any help! It popped under power while troubleshooting, oops!
                                03-11-2024, 07:19 PM
