Dell e173FPf
+ More Options
Posts
  • mgabriel74
    • Feb 2013
    • 14
    Dell e173FPf
    Hi ALL,
    I have a dell E173FPf, but the power LED is yellow, but screen is black; when connected to a laptop, the laptop recognizes the monitor model right away. I read ALL the "dell E173FPf" related posts, but I was unable to find a post with this specific issue. All caps "looks" good, but I read that even when caps might look OK they might be dry and wont work as they should. I was wondering if any of you recommends to replace ALL the caps with a "repair kit" available at eBay, for this specific model. Thanks in advance,
    MGabriel74
  • Rtech
    • Jul 2010
    • 1095
    Re: Dell e173FPf
    If the Power Led is yellow then the Screen will be Black !! It will only come on when the Led switches to Green when it gets a signal from the Computer.If the Power Led goes to Green AND still no image on the screen then normally with this model the 2 Caps near to the Inverter transformers need to be changed.These 2 caps always look normal but are a regular cause of the fault.
    • mgabriel74
      • Feb 2013
      • 14
      Re: Dell e173FPf
      RTech,
      Thanks a lot for your prompt response and support.
      That's the thing, the power led does not turn to GREEN when connected to the computer. however, the monitor "should" display a "floating" window message saying "No video signal" or something similar. I'll go ahead and replace those 2 caps (C6 & C26) that you recommend me and will update you all with the results.
      Can somebody suggest me where I can buy these 2 caps??; at eBay there is a full set for this specific model, but I prefer to buy these 2 specific caps, rather than the full set, since it might not need them all.
      Thanks again,
      MGabriel74
      • selldoor
        Slow Learner
        • 7870
        Re: Dell e173FPf
        While the set is apart we would normally suggest replacing at least all the middle size caps. Usually from badcaps.net digikey mouser or farnell.
        Cant suggest as you dont give the values v/uf.
        There have been a few bad experiences with kits off ebay and there seems to be some fakes about. If you just replace two then find you need more you double the postage -which can be more than the caps.
        • Rtech
          • Jul 2010
          • 1095
          Re: Dell e173FPf
          When initially switching the Monitor on, the Led should go to Green then switch back to Amber when no signal is detected,IF that does not happen then those caps are not to blame.Everything for this monitor is on one Board,so no separate PSU/Inverter or Logic Board.I have seen problems with the voltage regulators U801 and/or U802, which could be the problem,AND on two occasions where the Video part of the part only does not work.
          • mgabriel74
            • Feb 2013
            • 14
            Re: Dell e173FPf
            Rtech,
            I just received the caps (C6 & C26), and will replace them soon; Can you please let me know the specs or part number of the voltage regulator (U801), just in case the caps are not the problem; THANKS ALL for your responses and support!
            • selldoor
              Slow Learner
              • 7870
              Re: Dell e173FPf
              Can you not read the part numbers off yours? try cleaning them with a little isopropyl alcohol. U 850 can also be a problem and R852
              • Rtech
                • Jul 2010
                • 1095
                Re: Dell e173FPf
                Does the LED change from Amber and Green, as asked before ????????If you have any power at all then U850 cannot be faulty.
                • mgabriel74
                  • Feb 2013
                  • 14
                  Re: Dell e173FPf
                  Rtechm
                  I just re-connected all back, but the LED stays in AMBER color, no GREEN at all.No green when I connected to the power outlet.
                  How about the MOSFET? could that be the problem?
                  Thanks ALL again for your support...
                  • mgabriel74
                    • Feb 2013
                    • 14
                    Re: Dell e173FPf
                    Originally posted by mgabriel74
                    Rtech,
                    Caps were replaced!. Without luck!
                    • Rtech
                      • Jul 2010
                      • 1095
                      Re: Dell e173FPf
                      As advised,if no green led then no screen..the next step IF you do get the Amber light,is to test U801 and U802.Switch your multimeter to DC Volts,on range 20v if possible,and put the Black probe on the metal of the Blue VGA connector and with the red probe meausre the voltage on the two pins and the Tab of each Regulator,when the Amber led is on,and advise.
                      • mgabriel74
                        • Feb 2013
                        • 14
                        Re: Dell e173FPf
                        Rtech,
                        Voltage values are 5.00 Vdc (between the vga metal & the leg/pin of the left side) and 3.49 Vdc (between the vga metal & the leg/pin of the center), 0.0Vdc (between the vga metal & the leg/pin of the right side). This board just have U801. Please advise.
                        • selldoor
                          Slow Learner
                          • 7870
                          Re: Dell e173FPf
                          I think we have reached the point where we need to be able to see your boards
                          We can help a lot more if you please post good clear pictures of the whole chassis, and then pictures of each board, front and back (in the same orientation) and close up of connectors, (max resolution 2000x2000 and 2MB) using the manage attachments button, which is found by clicking "go advanced" under quick reply.
                          Examples of what is needed
                          https://www.badcaps.net/forum/attach...7&d=1280167246
                          https://www.badcaps.net/forum/attach...6&d=1280167246
                          https://www.badcaps.net/forum/attach...4&d=1280167246
                          • retiredcaps
                            • Apr 2010
                            • 9271
                            Re: Dell e173FPf
                            3.49 Vdc
                            If U801 is 3.3 fixed voltage regulator, then with a reading of 3.49, it is likely bad because it is out of spec (5.75% too high).
                            --- begin sig file ---
                            --- end sig file ---
                            • mgabriel74
                              • Feb 2013
                              • 14
                              Re: Dell e173FPf
                              I re-measured (with a better voltmeter) and reading is 3.304 Vdc. So, I assume this component is not the problem either.
                              I read once that Q850 (a MOSFET??) is also a common component to get bad; What should be the expected values on that one??
                              • Rtech
                                • Jul 2010
                                • 1095
                                Re: Dell e173FPf
                                Q850.is a Mosefet which drives the Board in association with U850 which is the smps chip...BUT as you have 5v on the board then this part of the circuit is fine...if it was not good then you would not get the 5v !!!.My board components are numbered the same as yours therefore moving up the Board from the VGA socket you should find U802,,this is the other Voltage regulator,that you say you cannot find !!
                                • mgabriel74
                                  • Feb 2013
                                  • 14
                                  Re: Dell e173FPf
                                  Sorry, my bad. I found and measured U802, and here are the values obtained:
                                  0.000 Vdc (between the vga metal & the leg/pin labeled #1 on the board)
                                  1.804 Vdc (between the vga metal & the leg/pin located at the middle)
                                  3.304 Vdc (between the vga metal & the leg/pin labeled #3 on the board)
                                  Please advise
                                  • Rtech
                                    • Jul 2010
                                    • 1095
                                    Re: Dell e173FPf
                                    Those look good,so based on what I have seen with these boards,I suspect you will need to replace the board completely.
                                    • mgabriel74
                                      • Feb 2013
                                      • 14
                                      Re: Dell e173FPf
                                      What????.... Will you think that replacing ALL the caps "might" be a possibility?. If (based on your knowledge and what we have already done so far) you think that replacing ALL the caps will not solve the problem, please let me know; Once again, thanks a lot for all your support and time!!! Greatly appreciated!
                                        Re: Dell e173FPf
                                        Any pictures of the main/logic board?
                                        • nick3092
                                          Mid/late 80's Nichicon Yellow Caps
                                          by nick3092
                                          I recently acquired a set of Bose Roomate speakers from the mid to late 80's. Basically the right speaker cabinet is completely passive, and the left one has the power transformer and amplifier circuit in it. Out of curiosity, I opened it up to see what the circuit looked like. Looks like they used all Nichicon VX (2x 4700uF/16v for smoothing off the bridge rectifier), a couple random Nichicon SE series sprinkled on the board, and what really caught my eye - 2 yellow sleeved Nichicon caps (both 1uF/50v with no real series marking. Below are pictures of the caps. The only thing not shown in these...
                                          08-28-2022, 03:56 PM
                                        • Bowline
                                          by Bowline
                                          06-11-2025, 10:13 AM
                                          by momaka
                                          03-12-2025, 03:42 PM
                                        • multimesut
                                          Dell 2007FPB Yellow Light Problem
                                          by multimesut
                                          Hello friends,
                                          A yellow light was flashing on my monitor. It was like it was constantly cutting power. When I opened it up, I saw that the big capacitor in the high voltage line was leaking. I replaced it. When I turned it on for the first time, it had the same problem again. But then, interestingly, it got better. The yellow light was on steady. But the monitor wouldn't turn on. When I examined them with a thermal camera, I saw that the Fli5961-LF reached 50 degrees Celsius and the EM636165TS next to it reached 100 degrees Celsius and was drawing high current on the motherboard....
                                          11-13-2024, 07:00 AM
                                        • huzo
                                          DELL Latitude 3500 no image, fan max speed, caps lock frozen
                                          by huzo
                                          Dell latitude 3500
                                          Board BOLT-L UMA MB
                                          17938-1
                                          FW8G6$LA
                                          when i press the power, fan goes full speed, power button lights up , and caps lock light is on, the screen polarises, goes dark,no backlight...All voltages present, except PL4701, but that's probably for GPU power later....
                                          I've tried a few dumps from posts, it always acts the same, so i thin it's not a bios issue...
                                          No shorts found on the board...
                                          What should i try next?
                                          10-06-2024, 02:15 AM
