troubleshooting DAC 19M008 power supply
    Re: troubleshooting DAC 19M008 power supply
    That would explain the no 5v i dont suppose you have another you can replace it with
      no, do you know of a place here in the USA that has this fuse?
        found a few on Ebay for $2 to $5
        I'll give it a try and post the results. Thanks much for the help so far.
        TTFN!
          There is a company on ebay called coreweave in Kaukauna, Wisconsin
          They do a kit for this board that includes the fuse all the caps you need and new mosfets item 220620219872
          Or just do a search DAC-19M008 on there and it will come up with several
          Checkout this site in the sales bit they may have a kit or could supply the parts you need
          You can use the list of parts to buy stuff individually .
          Whatever you do i would change the caps that you have not changed yet that way they are all done and you wont have to open it up again in a few months and do some more .
          The fuse is a 4amp smd fuse
            That's who the Ebay listing was. It's $1.50 and free shipping
              Ok good well let us know how you get on
              good luck
                How sensitive is this fuse to the heat, is there a chance I could fry it while installing it?
                  Just solder new one on top of the old one that will cut down the amount of time and heat you put into it
                    Excellent idea. Thanks
                      Installed new fuse, tested before applying power, tested dead short. After applying power fuse tests at 210 ohms. Still no green light. What could have caused the new fuse to fail?
                        You need to check the two MOSFET'S that drive the inverter transformers for shorts.
                          tested pin to pin on all pins, no shorts other than pins 5,6,7 and 8 on both MOSFETs, since they are all grounded
                            Please see the diagram and retest the MOSFETs, the circuit is setup as a bridge drive, 5,6,7 and 8 should never be at ground, if they are, they are shorted, only pin 1 is grounded.
                              sorry, 5,6,7,8 all connected together but not grounded
                              where can I find the diagram?
                                post #3
                                  both MOSFETs: pins 1 to 2 measures 29 M Ohm, 1 to 3 is 7 M Ohm, 2 to 3 is 35 M Ohm, 3 to 4 and 3 to 5 is 30 M Ohm, everything else is open (except for 5,6,7,8)
                                    How about Source (1) and Drain (5/6/7/8)?
                                    By the way, what resistance do you get at the either end of the fuse F102 and Ground? You still have short circuits in the main board.
                                      VA1912WB service manual
                                        pins 1 to 5,6,7,8 is open
                                        from the outboard end of the fuse to ground is 300 k Ohm, inboard side is 2 k Ohm
                                          already got it, it tells me to change the power board
