troubleshooting DAC 19M008 power supply
  • sabre504
    • May 2010
    • 449
    • United Kingdom
    Re: troubleshooting DAC 19M008 power supply
    That would explain the no 5v i dont suppose you have another you can replace it with
    • mikeh1
      • Feb 2013
      • 37
      • usa
      no, do you know of a place here in the USA that has this fuse?
      • mikeh1
        • Feb 2013
        • 37
        • usa
        found a few on Ebay for $2 to $5
        I'll give it a try and post the results. Thanks much for the help so far.
        TTFN!
        • sabre504
          • May 2010
          • 449
          • United Kingdom
          There is a company on ebay called coreweave in Kaukauna, Wisconsin
          They do a kit for this board that includes the fuse all the caps you need and new mosfets item 220620219872
          Or just do a search DAC-19M008 on there and it will come up with several
          Checkout this site in the sales bit they may have a kit or could supply the parts you need
          You can use the list of parts to buy stuff individually .
          Whatever you do i would change the caps that you have not changed yet that way they are all done and you wont have to open it up again in a few months and do some more .
          The fuse is a 4amp smd fuse
          • mikeh1
            • Feb 2013
            • 37
            • usa
            That's who the Ebay listing was. It's $1.50 and free shipping
            • sabre504
              • May 2010
              • 449
              • United Kingdom
              #26
              Ok good well let us know how you get on
              good luck
              • mikeh1
                • Feb 2013
                • 37
                • usa
                #27
                How sensitive is this fuse to the heat, is there a chance I could fry it while installing it?
                • sabre504
                  • May 2010
                  • 449
                  • United Kingdom
                  #28
                  Just solder new one on top of the old one that will cut down the amount of time and heat you put into it
                  • mikeh1
                    • Feb 2013
                    • 37
                    • usa
                    #29
                    Excellent idea. Thanks
                    • mikeh1
                      • Feb 2013
                      • 37
                      • usa
                      #30
                      Installed new fuse, tested before applying power, tested dead short. After applying power fuse tests at 210 ohms. Still no green light. What could have caused the new fuse to fail?
                        You need to check the two MOSFET'S that drive the inverter transformers for shorts.
                        • mikeh1
                          • Feb 2013
                          • 37
                          • usa
                          #32
                          tested pin to pin on all pins, no shorts other than pins 5,6,7 and 8 on both MOSFETs, since they are all grounded
                            Please see the diagram and retest the MOSFETs, the circuit is setup as a bridge drive, 5,6,7 and 8 should never be at ground, if they are, they are shorted, only pin 1 is grounded.
                            • mikeh1
                              • Feb 2013
                              • 37
                              • usa
                              #34
                              sorry, 5,6,7,8 all connected together but not grounded
                              where can I find the diagram?
                                post #3
                                • mikeh1
                                  • Feb 2013
                                  • 37
                                  • usa
                                  #36
                                  both MOSFETs: pins 1 to 2 measures 29 M Ohm, 1 to 3 is 7 M Ohm, 2 to 3 is 35 M Ohm, 3 to 4 and 3 to 5 is 30 M Ohm, everything else is open (except for 5,6,7,8)
                                    How about Source (1) and Drain (5/6/7/8)?
                                    By the way, what resistance do you get at the either end of the fuse F102 and Ground? You still have short circuits in the main board.
                                      VA1912WB service manual
                                      • mikeh1
                                        • Feb 2013
                                        • 37
                                        • usa
                                        #39
                                        pins 1 to 5,6,7,8 is open
                                        from the outboard end of the fuse to ground is 300 k Ohm, inboard side is 2 k Ohm
                                        • mikeh1
                                          • Feb 2013
                                          • 37
                                          • usa
                                          #40
                                          already got it, it tells me to change the power board
                                            by sam_sam_sam
                                            03-31-2024, 02:12 PM
                                          • shamsudeen
                                            Hi, Can we use SMPS Bench Power Supply for Laptop troubleshooting?
                                            by shamsudeen
                                            Hi all, I just need to know that, can i use SMPS type power supply to test and short circuit detection on a laptop motherboard?
                                            I saw 95% of repair guys are using only Linear bench power supply. linear bench power supply is pricy, thats why i planned to get one SMPS supply.
                                            i know that in linear power supply the noise will be very low comparing to SMPS supply....
                                            Yesterday, 07:14 AM
                                          • dragon3x
                                            >>> Troubleshooting Delta Power MAX 500ATX ATX power supply
                                            by dragon3x
                                            Hi, this is for troubleshooting and, hopefully, repairing a Delta Power psu
                                            that is still quite new, as it worked OK for some months until it failed.
                                            At the time I was not into power supply electronics; it was put
                                            aside and a new power supply installed inside the computer. Also at the time
                                            power supplies were half the price of today's.
                                            On the PCB there are a D339 and 7500B chips.
                                            I have found that schematics with these 2 chips (see included file).
                                            Does it represent the actual circuit of the MAX-500ATX, I cannot tell.
                                            Some measurements,...
                                            06-05-2024, 03:34 PM
                                          • JimBanville
                                            Definitive technology SC 2000 subwoofer amp's power supply clicking and popping
                                            by JimBanville
                                            The sub developed a constant popping every couple seconds from woofer and power LED flickering with nothing but wall AC connected. Connecting an audio cable didn't change anything. It doesn't play but a second or two of audio in between the pops.
                                            Opened it up and discovered the power supply is making a faint clicking or ticking sound.
                                            I measured the amp's output to the woofer and it pulses up to 50mv DC to be driver. The pulses coincide with the power supply ticking/clicking.
                                            I measured the power supply output going to the amp board and it too has this pulsing. Voltage cycles...
                                            09-13-2023, 07:21 AM
