Dell 1707FPt No Power
  • maybenever
    • Dec 2010
    • 158
    Re: Dell 1707FPt No Power
    I've done back over this thing, without boards connected, power out pins 1 thru 4 bounce between 5.1v & 5.3v, pin 9 between .5v & 1.7v. Connect boards, pin 1 thru 4 5.24v steady, pin 9 = zero volts, and the power LED no longers comes on, I don't know what changed.
    • maybenever
      • Dec 2010
      • 158
      Update, since the only thing I've done so far that made any difference was reflow joints on the AC inlet end of the board, I went back and reflowed & re soldered all joints. Connect AC power, steady voltage on output pins. Connect logic board and ribbon going to power button. Plug in AC, my green LED light, on (before I pushed it). Been there before. All voltages at connection pins steady and correct (as far as I know). Press power button, green LED light, off. Press it again, on. I cycle it several times, and it works good. Plug in spare ccfls, turn it on, no back light. Now, power button won't turn off. Unplug AC & replug, power button does nothing, dead again. Disconnect boards, output voltage now bounces between 5.1v & 5.3v, and when it does that, the power button does nothing when connected. What the hell is going on?
      • selldoor
        Slow Learner
        • Dec 2010
        • 7870
        #43
        I may have missed it but have you tested the inverter transformers.
        Cant see how they would affect the voltage problems you have but may as well test them as if they are gone they may not be replaceable
        POWER OFF Meter on ohms 2000 measure s1 to s2 and s3 to s4 on the attached pic.
        • maybenever
          • Dec 2010
          • 158
          S1 to S2 = 443ohm S3 to S4 = 442ohm
          • selldoor
            Slow Learner
            • Dec 2010
            • 7870
            #45
            Ok the secondary windings on the inverter transformers are good.
            Can you connect the ccfls that you know work and disconnect the main board.
            With mains power to the powersupply Can you get a 3v battery or 2x1.5v in series and connect negative to ground and positive to bl on.
            Probably nothing will happen - is there a pson pin? if so try putting the 3v+
            to that instead of the Blon.
            • maybenever
              • Dec 2010
              • 158
              Dell saw fit not mark any pins on this board, but when I do get it to working, pin 9 had 1.73vdc, pin 10 & 11 = 0. When I connect the boards, pin 9 = 0, pin 10 = 0, pin 11 = 3.24 vdc. Press power button, pin 9 = 3.24vdc, pin 10 = 3.24vdc, pin 11 = 2.56. I don't which is power on. I've also noticed, in the wiring harness from ps/inv board to logic board, pin 10 and pin 11 are crossed. I can rigg the 3v if I knew correct pins.
              • maybenever
                • Dec 2010
                • 158
                This is the way I'm numbering the pins. You'll have to blow the picture up a little to see my text.
                • selldoor
                  Slow Learner
                  • Dec 2010
                  • 7870
                  #48
                  Well as pins 9 10 and 11 receive around 3v then just try it on each of them
                  (one at a time) without the main board connected but with the lamps connected.
                  • maybenever
                    • Dec 2010
                    • 158
                    And use either pin 5, 6, 7, or 8 as my ground?
                    • selldoor
                      Slow Learner
                      • Dec 2010
                      • 7870
                      #50
                      Only if you have checked that they are ground pins - otherwise use a
                      groundscrew tag.
                      • maybenever
                        • Dec 2010
                        • 158
                        groundscrew tag.
                        Checking those pins back to board ground, .05 ohm, should be good to go. I'll get back.
                        • Rtech
                          • Jul 2010
                          • 1095
                          #52
                          The test of applying 3v to BL_on pins, is used regularly by lots of members HOWEVER this does not work 100% of the time !!!sometimes you need to apply voltage to the Dim pin at the same time.some DAC boards MUST have the Logic board connected, similarly one of the Samsung Monitors is also the same.Normally Dell do not give you problems like that, but you should be aware.
                            RTECH is corrct about applying the voltage to the diming pin, only if it used analog diming control (0~5v), if it uses PWM, then you will need to feed it wirh 150~200 Hz square wave generator (this will give 50% pulse width), otherwise it may not light up on some board.
                            • maybenever
                              • Dec 2010
                              • 158
                              Connected 2 AA batteries (3.12v) with a pushbutton switch. Apply voltage to pin 9, nothing happened, voltage to pin 10, nothing happened, voltage to pin 11, the ccfls try to light. I get a flash of light, about 3" of it at the ends where the wires are connected. Both sets flicker 3 times and stop. It's the same with just one set connected, either side, 3 flickers and stop.
                              • maybenever
                                • Dec 2010
                                • 158
                                Originally posted by budm
                                Is your meter True R.M.S? If it is, put it in AC mode and measure AC ripple voltage on the two legs of that large cap.
                                My meter now is True RMS. Got a Fluke 113 for my birthday. The AC DC is automatic fuction. Checking across the legs of the large cap, I get 166vdc, then slowly climbs up to 170.3vdc to 170.4vdc. Another strange thing, when I check for voltage on pin 9 with my $20 DMM, I get 1.73vdc (the logic board not connected). When checking with my Fluke, I get 0.00v voltage. What's up with that?
                                • retiredcaps
                                  • Apr 2010
                                  • 9271
                                  #56
                                  The Fluke113 is a specialized multimeter. Namely it has Vchek which tries to automagically determine the reading without the operator having to choose the correct function.
                                  As such, the default is to turn try and detect AC, DC, continuity or diode functionality automagcially. One of the limitations of the 113 is that you cannot set it to measure AC manually.
                                  The Vchek feature might be "fooled" when voltage is low (that is, it might be doing a diode test which explains the 0.000V DC reading). You can put the Fluke 113 into "manual" DCV mode by pressing the range key twice. It should show 0.000V DC. Now take your reading and it should be 1.73V DC.
                                  AFAIK, there is no way to disable Vchek on the 113. I have an older Fluke 12 which was the predecessor, but I can enable/disable the Vchek feature on it.
                                  PS. I don't recommend the Fluke 114 for electronics use because it has no diode test functionality. The 115 and 117 are good for electronics if you don't need to measure milli or micro amps.
                                  --- begin sig file ---
                                  --- end sig file ---
                                  • maybenever
                                    • Dec 2010
                                    • 158
                                    retiredcaps: The Vchek feature might be "fooled" when voltage is low (that is, it might be doing a diode test which explains the 0.000V DC reading). You can put the Fluke 113 into "manual" DCV mode by pressing the range key twice. It should show 0.000V DC. Now take your reading and it should be 1.73V DC.
                                    Thanks for the meter lesson, but when I set it to manual mode, I still don't voltage on that pin. The meter is working OK, I can check 1.5v battery, get 1.56vdc, I've got a 3v battery that's about shot, checks 1.43vdc., so I guess it's working, but there is no voltage detected at pin 9. Another thing, when power is first applied to the board, the 5.24 output voltage is steady, after a few minutes, it flopps between 5.1v and 5.3v. Using the min/max setting on my meter, between 5.3vdc max and -4.1vdc min. When the voltage is steady, I don't get a neg voltage at min. Am I doing this right?
                                    • retiredcaps
                                      • Apr 2010
                                      • 9271
                                      #58
                                      I have a Fluke 113. Let me do some tests over the next few days. You wouldn't be the first person to report strange readings with it.
                                      • maybenever
                                        • Dec 2010
                                        • 158
                                        retiredcaps, it seems I reported these voltages in error. Testing again, in min/max mode, I record a neg voltage when ever the output voltage is stable or not. Don't know where to go from here.
                                        • retiredcaps
                                          • Apr 2010
                                          • 9271
                                          #60
                                          Okay, I did some testing with my Fluke 113 and 12.
                                          As I expected in some circuits, the Fluke 113 and 12 when used in Vchek mode will not properly report some measurements because it is working 100% as designed.
                                          The Fluke 113 is in low impedance mode all the time (optional for Fluke 12). As such it can affect the circuit under measurement. To see why, have a read through
                                          http://www.talkingelectronics.com/pr...onents.html#12
                                          The Fluke 113 has a 3k ohm input impedance. Most digital multimeters have a 10M ohm input impedance. The Fluke 12 has a 2k ohm input impedance in Vchek mode and 10M ohm for DCV "manual" mode.
                                          In my tests, the Fluke 113 and 12 (when using Vchek) will both fail to measure DCV properly in some circuits (i.e. it shows 0.0V DC). When I switch the Fluke 12 to "manual" DCV mode (with input impedance of 10M ohm), it measures the DCV properly.
                                          So if you plan to do more electronics work, you may ask the gifter to give you the receipt for the 113 and exchange it for something else like a Fluke 115 (albeit more money).
                                          • Tynan Dill
                                            by Tynan Dill
                                            Assuming...
                                            11-22-2024, 01:46 PM
                                          • PantherDave
                                            by PantherDave
                                            Hi all!
                                            I'm trying to troubleshoot a Microsoft Surface Pro (5th gen) model 1796 that won't power on. Motherboard model is M1007506-015. My priority is retrieving data, but the SSD is integrated so it looks like if I can't repair it it'll need to go to a data recovery company. I've done a little basic board repair before, but nothing this advanced until now. So please forgive my ignorance in advance. ๐Ÿ˜…
                                            05-29-2024, 02:01 PM
                                          • Mark01
                                            Dell Optiplex 7490 AIO - red power led after flash
                                            by Mark01
                                            Hi guys,
                                            This is my first post! ๐Ÿš€
                                            I have no idea what Iโ€™m doing, but Iโ€™m learning by trial and error.
                                            Iโ€™m currently working on a Dell Optiplex AIO 7490โ€”one of a bunch of AIOs that mysteriously failed to POST just a few days after the warranty expired. The original issue was that the PC worked fine until it was rebooted, after which it got stuck on a black screen (no backlight), with fans spinning at normal speed and a solid white power LED. Forcing it off by holding the power button would just cause it to switch on automatically and get stuck again on...
                                            07-04-2025, 12:54 PM
                                          • zlr8r
                                            Dell inspiron 17 (7786) - DP/N 09P7JP - odd power issues, starting with no power LED
                                            by zlr8r
                                            hey guys, hoping for some pointers to repair an eBay bought "faulty" laptop.
                                            Ill try and give as much info as I can.
                                            Dell Inspiron 17 (7786) Laptop
                                            Service Tag: 5J0NHT2
                                            Bios: 1.9.0
                                            When I received this , it would only flicker on the KB backlight for a second, then off and on.
                                            Then it started getting weirder!
                                            Sometimes when attaching the AC power supply, and pressing various pre-boot diagnostic keyboard keys... it did try to boot, in fact out of a hundred attempts, the laptop did actually boot into the Bios ! but never has...
                                            12-12-2023, 09:31 PM
                                          • LimesKey
                                            Dell Inspiron 7506 Silver 2n1 - "HELLCAT 15" - No power
                                            by LimesKey
                                            Hi everyone, I have an Inspiron 7506 laptop I've had for a few years, and it'd occasionally have a problem where after I'd power it off, it wouldn't turn on again unless I disconnected, drained residual voltage by pressing the power button, and reconnected the battery. It now seems to be occurring every single time I shut down the laptop and attempt to turn it back on again. I have done all the common troubleshooting steps, such as completely disconnecting the battery & CMOS battery and draining the voltage and leaving it for an hour, and I've even replaced the battery. This is definitely...
                                            10-17-2025, 05:33 PM
