Dell 1707FPt No Power
  • LDSisHere
    • May 2012
    • 727
    • U.S.A.
    #61
    Re: Dell 1707FPt No Power
    Originally posted by retiredcaps
    Okay, I did some testing with my Fluke 113 and 12.
    As I expected in some circuits, the Fluke 113 and 12 when used in Vchek mode will not properly report some measurements because it is working 100% as designed.
    The Fluke 113 is in low impedance mode all the time (optional for Fluke 12). As such it can affect the circuit under measurement. To see why, have a read through
    http://www.talkingelectronics.com/pr...onents.html#12
    The Fluke 113 has a 3k ohm input impedance. Most digital multimeters have a 10M ohm input impedance. The Fluke 12 has a 2k ohm input impedance in Vchek mode and 10M ohm for DCV "manual" mode.
    In my tests, the Fluke 113 and 12 (when using Vchek) will both fail to measure DCV properly in some circuits (i.e. it shows 0.0V DC). When I switch the Fluke 12 to "manual" DCV mode (with input impedance of 10M ohm), it measures the DCV properly.
    So if you plan to do more electronics work, you may ask the gifter to give you the receipt for the 113 and exchange it for something else like a Fluke 115 (albeit more money).
    That information explains a whole lot, at least I know the problem was the 113 and not my imagination when I had mine. This is the still the only Fluke meter I have ever disliked (so far).
    @maybenever
    I ran into the same problems you are experiencing a while back ago when I made the mistake of buying the Fluke 113. It is probably a good meter if you are an electrician or do HVAC repair but worthless for my purposes. I did discover I could get the thing to give me a voltage reading in the situations you are having problems with if I reversed the leads but that could ultimately cause more problems than it solves.
    My solution was to replace it. I have since picked up two good meters from a local pawn shop and keep wanting to go look for more even though I do not really need them. I recently discovered the test leads alone that came with my 175 cost more new than what I gave for the meter with the leads included.
    https://www.badcaps.net/forum/showthread.php?t=26191
    • maybenever
      • Dec 2010
      • 158
      The Fluke was a gift from my wife, she thought she did good, I thought she did good. I destroyed the package getting it out, so guess I'll keep it. I'm a residential plumber and electrician by trade, so I can use it., but it's on my dislike list too.
      Back to the Dell monitor, I found a new PS board on ebay for $15 & free shipping. Got it today, what are the odds of getting a board with the exact same issues as my old board? It looked good, all KY caps, but the output voltage is bouncing between 5 & 5.3 volts. Went ahead and connected it up, power LED came on as soon as it was plugged to AC, wouldn't turn off, unplugged and plugged in again, no power LED and it won't come on again. What are the odds, I'll try to get it replaced.
      • maybenever
        • Dec 2010
        • 158
        Got a responce from my ebay seller, they are giving me full credit on my purchase. I asked what to do with this bad board, and I still need a board. I got this reply
        [QUOTE]You can just throw the bad one away.
        These batch of boards that we have are probably bad that we are looking for solutions to test them further. If you purchase another one from us, it is very likely that it will have the same problem again.
        Therefore, if you need another one, we suggest that you purchase one from other seller.
        Thank you for your understanding[/QUOTE
        Ain't that something.
        • retiredcaps
          • Apr 2010
          • 9271
          #64
          Please name the ebay seller because that is a seller I would want to do business with in the future. Most sellers would not be some honest about their stock.
          The only thing really left to test are the voltage regulators on the main board (just to rule them out).
          --- begin sig file ---
          --- end sig file ---
          • maybenever
            • Dec 2010
            • 158
            The money went to IT Express 101, and they are the ones that shipped it from Austin, TX, but great.pc.parts are the ones responding to my messages.
            I've checked the voltage reg on main board, it's putting out 5.0vdc. What about voltage regs on the invertor board, where are they?
            I started out with output voltage that dropped like a rock, reflowing & resoldering has stopped that. Now, just unstable output voltage. I've checked all caps, even the ones I pulled off the board, all have low ESR & correct uF readings (I now have an Atlas ESR70, so no more guessing). For some reason, I've commeted to figuring this one out, so please help, and thanks for the attention you've already given.
            • selldoor
              Slow Learner
              • Dec 2010
              • 7870
              #66
              Can we just recap on what you are working on - perhaps repost pictures top and bottom of any boards - what are you calling the inverter board? inverter transformers are on the power supply?
              Test any fuses and give board numbers F100 F200 etc
              Test and repost voltage on the main cap a) when plugged in b) when switched on.
              Test and repost the voltages measured on the connector between the Power supply and main board a) when plugged in b) when switched on. c with the main board disconnected, d) with the main board connected but the panel -lvds cable unplugged.
              If you have established which is the pson get a 500 ohm-1kohm resistor and with the main board diconnected jumper 5v to pson and see if the backlights come on.
              If not, is there also a blon pin if so, in the same way jump 5v to Blon as well.
              Best to set up the jumper then switch on the mains power.
              • maybenever
                • Dec 2010
                • 158
                All fuses check good on PS board. Output voltages on PS pins (without main board connected) bounces between 5 & 5.3vdc. Voltage on large cap bounces between 166 & 168vdc. With main board connected, voltages on pin outs bounces between 4.7 & 5vdc, large cap voltages drops to 162 & 164vdc. Usually, the power button on front does nothing. Sometimes, the led comes on as soon as AC is connected, then won't turn off. When I connect spare ccfl and apply 3.1vdc to on pin, tubes flicker 3 times, about 3" of the tube on the wire connected end, then stop. I ordered a new PS board from ebay, has the same unstable voltage as old board. I had only a few minues today, I connected spare ccfls to new board & applied 3.1v to on pin. The tubes light from end to end (bright), for just a second, then go off. (better than old board).
                I haven't tried many combinations with main board connected, didn't think it made much difference, if I can't get the backlights working. I hope this recap helps, I am thankful for all of yall's help.
                • selldoor
                  Slow Learner
                  • Dec 2010
                  • 7870
                  #68
                  That is the old power supply? I meant a pic of the new one.
                  Does your ac in voltage wobble/bounce?
                  • maybenever
                    • Dec 2010
                    • 158
                    Don't have any pictures of new board yet, it's exactly like my old board, only with all KY caps.
                    AC voltage bounces very little, between 123.2 to 123.1vac.
                    • retiredcaps
                      • Apr 2010
                      • 9271
                      #70
                      I count three voltage regulators on the main board. Please report the readings as per my guide.
                      There are likely no voltage regulators on the inverter board. There may be a voltage regulator on the panel or t-con board.
                      • maybenever
                        • Dec 2010
                        • 158
                        Would those be I301, I311, & I318? I've checked 318, it's 5v input, 3.3v output. I said 5v earlier, my bad. Have not checked the other two, if tha's the ones you are referring to.
                        Another correction, the voltage on the new board at the large cap is between 168.9 & 169.4vdc.
                        Her are photos of new board.
                        • selldoor
                          Slow Learner
                          • Dec 2010
                          • 7870
                          #72
                          I know you did some reflowing but wonder if you did enough.
                          If this is an early dell board it may be suffering the Benq/Dell cold joint
                          disease. Which means nearly all the primary side needs reflowing.
                          Remove as much old solder as you can and apply fresh to the points in the picture. Check it over with a magnifier.
                          • maybenever
                            • Dec 2010
                            • 158
                            I applied flux and resoldered all these joints, but did not remove old solder. How about I do this on the new board, sence it almost fired up the ccfls?
                            • selldoor
                              Slow Learner
                              • Dec 2010
                              • 7870
                              #74
                              Sounds good to me- there are are few odd looking joints on the new one - the bridge rectifier and C805 and a joint just below it which I think is on the transformer - im off for an early night.
                              • retiredcaps
                                • Apr 2010
                                • 9271
                                #75
                                I don't know what you are looking at, but see photo.
                                • selldoor
                                  Slow Learner
                                  • Dec 2010
                                  • 7870
                                  #76
                                  I should have said - I am off to bed and expect you two to have it fixed when I look in tomorrow.
                                  • maybenever
                                    • Dec 2010
                                    • 158
                                    I'm on it, 1st thing in the morning. I gotta go away now. Will report back ASAP.
                                    A Big THANKS
                                    • maybenever
                                      • Dec 2010
                                      • 158
                                      Today didn't go as planned, but finally got to do some testing. On the main board, top left voltage reg, pin 1 = 5.16v pin 2 = 3.29v pin 3 = 0v. reg below that one, pin 1 = 3.29v pin 2 = 1.80v pin 3 = 0v. The top right voltage reg had 0v on all pins. But this reg checked good when the monitor would power on (one of the few times), and it had 5v input & 3.3v output. Reading were the same with or without lvds cable connected. Output voltage was stable with both boards connected, 5.16v. I removed solder & resoldered all those joints selldoor had circled and several more. Connected backlights and applied 3.1v to on pin, backlights came on full tube, for 1 sec, then off two sec, & on for 1 sec & so on. I added another AA battery to the on pin (applying 4.7v), plugged in AC, backlights came on full and stayed on, for 3 min, then went back to on 1 sec, off 2 sec cycle. While they were on for 3 min, output pins = 5.16v, steady, during the on & off cycle, voltage bounced between 4.9v & 5.3v. But the changing voltage did not match the lights on & off cycle. I could never duplicate the full on condition again.
                                      • LDSisHere
                                        • May 2012
                                        • 727
                                        • U.S.A.
                                        #79
                                        I think your 5V output fluctuating is due to no load being on the supply. When the back lights are on, the supply has a load so the voltage is stable, when they go off it has no load so it becomes unstable. If the fluctuating 5V is bothering you, try connecting a 100 ohm resistor between it and ground and see if it stabilizes. I would also try driving the back lights on with the supply voltage using a 100 ohm resistor between the 5V and "ON" pin, opposed to an external voltage source if that is what you are using.
                                        When the CCFL's were on for three minutes did any one of the four bulbs flicker or dim before the other three just before it went out?
                                        It may help if you took a picture of your test while it is in progress.
                                        • maybenever
                                          • Dec 2010
                                          • 158
                                          I didn't notice any flickering or dimming before they went out. I can make some pictures.
                                          • Tynan Dill
                                            by Tynan Dill
                                            Assuming...
                                            11-22-2024, 01:46 PM
                                          • PantherDave
                                            by PantherDave
                                            Hi all!
                                            I'm trying to troubleshoot a Microsoft Surface Pro (5th gen) model 1796 that won't power on. Motherboard model is M1007506-015. My priority is retrieving data, but the SSD is integrated so it looks like if I can't repair it it'll need to go to a data recovery company. I've done a little basic board repair before, but nothing this advanced until now. So please forgive my ignorance in advance. ๐Ÿ˜…
                                            05-29-2024, 02:01 PM
                                          • Mark01
                                            Dell Optiplex 7490 AIO - red power led after flash
                                            by Mark01
                                            Hi guys,
                                            This is my first post! ๐Ÿš€
                                            I have no idea what Iโ€™m doing, but Iโ€™m learning by trial and error.
                                            Iโ€™m currently working on a Dell Optiplex AIO 7490โ€”one of a bunch of AIOs that mysteriously failed to POST just a few days after the warranty expired. The original issue was that the PC worked fine until it was rebooted, after which it got stuck on a black screen (no backlight), with fans spinning at normal speed and a solid white power LED. Forcing it off by holding the power button would just cause it to switch on automatically and get stuck again on...
                                            07-04-2025, 12:54 PM
                                          • zlr8r
                                            Dell inspiron 17 (7786) - DP/N 09P7JP - odd power issues, starting with no power LED
                                            by zlr8r
                                            hey guys, hoping for some pointers to repair an eBay bought "faulty" laptop.
                                            Ill try and give as much info as I can.
                                            Dell Inspiron 17 (7786) Laptop
                                            Service Tag: 5J0NHT2
                                            Bios: 1.9.0
                                            When I received this , it would only flicker on the KB backlight for a second, then off and on.
                                            Then it started getting weirder!
                                            Sometimes when attaching the AC power supply, and pressing various pre-boot diagnostic keyboard keys... it did try to boot, in fact out of a hundred attempts, the laptop did actually boot into the Bios ! but never has...
                                            12-12-2023, 09:31 PM
                                          • LimesKey
                                            Dell Inspiron 7506 Silver 2n1 - "HELLCAT 15" - No power
                                            by LimesKey
                                            Hi everyone, I have an Inspiron 7506 laptop I've had for a few years, and it'd occasionally have a problem where after I'd power it off, it wouldn't turn on again unless I disconnected, drained residual voltage by pressing the power button, and reconnected the battery. It now seems to be occurring every single time I shut down the laptop and attempt to turn it back on again. I have done all the common troubleshooting steps, such as completely disconnecting the battery & CMOS battery and draining the voltage and leaving it for an hour, and I've even replaced the battery. This is definitely...
                                            10-17-2025, 05:33 PM
