I have a ACER AL2216W LCD monitor that uses the v2 power board. I have only seen this board in one post in your forum.
I have identified a resistor in the attached picture that was damaged when the monitor failed. It is approximately centered at the top of the picture just to the right of the heat sink, I circled it in red. The picture I attached is not my actual board, it is identical to mine but I'm using it to show the location of the failed resistor.
When mine failed it burned the resistor and I have no way of identifying the value.
I'm hoping that someone has the same board and can help me to identify this resistor. I believe it may be a 110ohm high temperature resistor but with mine burnt and the picture not really clear enough to identify the bands I'm not certain.
The component # on the board is #816
Any help is appreciated.
Jim
Jim
