Dell Monitor blinking LED
  • Pentium4
    CapXon Be Gone
    • Sep 2011
    • 3741
    Re: Dell Monitor blinking LED
    Originally posted by retiredcaps
    So the 12V is there. That 17.26V is unregulated and should drop down once the backlights are on.
    Let's confirm you are measuring the DC voltage on the picofuse correctly.
    1) Put your black probe on a ground screwn.
    2) Put your red probe on one side of the picofuse? What is this reading?
    3) Put your red probe on the other side of the picofuse? What is this reading?
    My apologies, one side is 17.82V and the other is 17.83V
    • selldoor
      Slow Learner
      • 7870
      #42
      I would check the secondary windings on the inverter transformers even tho
      you dont see any flash. Perhaps also check the primaries but they rarely fail.
      • Pentium4
        CapXon Be Gone
        • Sep 2011
        • 3741
        All 4 of them? What pins would I check?
        • selldoor
          Slow Learner
          • 7870
          #44
          POWER OFF
          On the side with 3 pins first check on one transformer that the two pins close together are in fact joined - resistance 0.00 ohms. then check from either of those to the third pin. (meter on ohms 2000.) post results. Yes for all four transformers.
          If they are ok we can go on to primaries.
          • Pentium4
            CapXon Be Gone
            • Sep 2011
            • 3741
            POWER OFF
            All the adjacent pins tested good, and when checking to the 3rd pin they were all ~200Ω
            • selldoor
              Slow Learner
              • 7870
              #46
              They are probably ok then - I have been trying to find out what it should be 200 ohms seems low but they are all different.
              In post 19 I mentioned resoldering the caps near the 5707s and you rplied that you had replaced all the caps. Those ones are not usually replaced so I am just checking that you have resoldered them C735 C755 C754 C734.
              • selldoor
                Slow Learner
                • 7870
                #47
                Sorry - but I have to ask - you are plugging the leads from the lamps into the board
                when you are testing (I have known it heheh have even done it!!)
                • Pentium4
                  CapXon Be Gone
                  • Sep 2011
                  • 3741
                  Think the primary one is okay too then? And alright I will resolder those caps. I meant I replaced all of the lytics
                  Haha, I understand. Yes I have been, double check every time
                  Edit: Resoldered, no luck yet Thanks for your continued help!
                    By the way, while checking this monitor, do you have the VGA cable connected to a running PC?
                    • Pentium4
                      CapXon Be Gone
                      • Sep 2011
                      • 3741
                      Yeah, and I can see the desktop with a flashlight
                      • retiredcaps
                        • Apr 2010
                        • 9271
                        #51
                        Let's get back to basics here.
                        1) Is the power LED on or off?
                        2) Is the power LED blinking or solid?
                        3) What is the DC voltage on U10 (logic board)? Report all 3 pins.
                        4) When you press the on/off button does BL_ON = pin 2 (connector) change from 0.0V to 3.0V DC? See
                        https://www.badcaps.net/forum/showpo...4&postcount=27
                        Remember that the main/logic board needs to signal BL_ON high in order for the backlights to come on.
                        In post 31, you only measured 5 out of the 10 pins. BTW, I prefer text based answers rather than paint. It helps with people searching in the future and makes it easier for us to read.
                        5) There are 4 blue tuning caps next to the ccfl connectors. I can see C736 and C756. With power off, measure the resistance across the legs of all 4 caps. They should all read open circuit on the higest resistance range.
                        --- begin sig file ---
                        --- end sig file ---
                        • Pentium4
                          CapXon Be Gone
                          • Sep 2011
                          • 3741
                          1) On
                          2) Solid (And it will power off when I hit the power button)
                          3)
                          Pin 1 = 3.26V
                          Pin 2 = 0.00V
                          Pin 3 = 2.50V
                          4) Yes, it goes to 3.16V (Okay no more paint ) Do you want exact results on the other 5? I don't remember which is which but they either measured 3.3V or 5V
                          5) They all tested open
                          • selldoor
                            Slow Learner
                            • 7870
                            #53
                            More things to check - with power off R765 (lift one leg) and , with power on check voltage across IC751 IF it is a (TL1451AC) then pin’s 8~ (ground) and 9~ (+15Vdc) there should be 15Vdc. Need to be careful pins are small and very close. Slip and its gone!!!.
                            EDIT Have you anything to check the ccfl bulbs on - so we know if they are going to work
                            eventually.
                            • Pentium4
                              CapXon Be Gone
                              • Sep 2011
                              • 3741
                              Okay I will do that just to be sure, black probe on pin 8 and red probe on pin 9? And just curious, why R765 specifically?
                              • selldoor
                                Slow Learner
                                • 7870
                                #55
                                Yes, black probe on pin 8 and red probe on pin 9.
                                Apparently IC751 contains an oscillator circuit and frequency is controlled by C765 (470p 50v) and R765 - It is a 1% tolerance resistor and is critical for the circuit ( or I dont know - have just read it somewhere. )
                                • Pentium4
                                  CapXon Be Gone
                                  • Sep 2011
                                  • 3741
                                  So apparently R765 is a 120Ω resistor but it only measured out to 9.96Ω and testing the TL1451ACN, I didn't get any DC Voltage on pin 9
                                  • selldoor
                                    Slow Learner
                                    • 7870
                                    #57
                                    10 ohms may be correct what are the band colours
                                    • Pentium4
                                      CapXon Be Gone
                                      • Sep 2011
                                      • 3741
                                      Brown, Red, Black, Black, Brown
                                      Unless I did it backwards
                                      • selldoor
                                        Slow Learner
                                        • 7870
                                        #59
                                        Perhaps it was for a different board/revision those colours are correct for
                                        for that resistance 120ohms - you did have it lifted?
                                        If you could post a clearer picture of the board so I can see the colours
                                        a bit better I can do more looking tho it will be tomorrow now.
                                        Maybe retiredcaps will come up with something later on regarding the results of the test you did for him.
                                        • retiredcaps
                                          • Apr 2010
                                          • 9271
                                          #60
                                          If you don't have any voltage on pin 9, it could be one of two things:
                                          1) IC is bad. With power off, see if VCC (pin 9) is shorted to GND (pin 8). Report your ohms reading.
                                          2) The circuit path to pin 9 is bad. Take your multimeter and put it into continuity mode. Put one probe on pin 9 and the other probe on components that might have continuity to pin 9.
                                          For example, pin 9 might have continuity to C764 and R787. You can either check those components to see if they are okay or check the DC voltage on them.
                                          You know PF751 has 17V DC. You are just trying to find out why it doesn't reach pin 9. For example, an open resistor would stop 17V from getting to pin 9.
                                          PS. Note to future readers, here is where picture orientation matters in post #1. The top power board is "right side up". The backside of the power board is "upside down". This forces regulars to download the picture, rotate it, etc (i.e. more work on our part).
                                          • Bowline
                                            by Bowline
                                            06-11-2025, 10:13 AM
                                          • DanPoka
                                            Guide me through repairing a Dell p2210f LCD ccfl backlight monitor
                                            by DanPoka
                                            I bought this p2210f dell monitor to fix. Schematic is the same as p2210.
                                            Behaviour is that monitors comes on but then backlight switches off almost instantly. If I look with flashlight I can still find the "No signal message". So definitely a backlight issue. Trying to advance the issue I proved that the protection circuit is switching off the backlight by shorting out C3 and resistor to disable the INL chip then re enable by removing the short.
                                            This is where it gets interesting. When I disassembled the monitor to solder leads on c3 capacitor I noticed the backlight flickered...
                                            02-15-2025, 05:05 AM
                                          • artvandalai
                                            Help identifying voltage regulator on this concept 2 pm5 monitor pcb board?
                                            by artvandalai
                                            This Concept 2 rower pm5 monitor doesn't shut down. It keeps turning on and stays on after being turned off. I read on another forum by another user that replaced the same component to check the voltage regulator.
                                            The monitor should pull around 35mA when turned on and in shutdown it should drops to around 0.060mA. Any advice on finding the voltage regulator on this board to check if it needs to be replaced?
                                            11-05-2024, 07:38 AM
                                          • Jesus Coder
                                            Issues Reviving Old Dell 2408WFPb Monitor
                                            by Jesus Coder
                                            I have been having some difficulties reviving an old Dell 2408WFPb PC monitor that I received for free. When I first acquired it, the backlights of the display were on but alas no image was showing. After extensive research on the topic, I went ahead and purchased a new t-con board for the monitor. After installing the board, I was then presented with a new screen that was half black and half green (more so black). I have been unable to figure out what to do next as I have limited knowledge of display electronics. Might anyone on this forum have an idea of what may...
                                            06-25-2023, 02:33 PM
                                          • deep000
                                            Burned Voltage Regulator in Monitor – How to Identify and Repair?
                                            by deep000
                                            My computer monitor ASUS VP249H stopped working, and smoke came out of it.
                                            I opened it and found that a voltage regulator had burned out.
                                            The problem is that I can't identify its reference.
                                            I searched online for schematics or photos of similar boards that people are selling, but without success (no schematics, bad quality of the board or lack of the reference when it's a good quality 😅).
                                            How can I find its reference, and do you think it's repairable?
                                            Monitor: Asus VP249H
                                            Board reference: 0171 - 2271 - 6083
                                            09-08-2024, 01:13 PM
