Samsung SyncMaster T190, pwr led flashing
  • _max_
    • Dec 2012
    • 46
    • Italy
    Hi there,
    I have a couple of LCD Monitor Samsung SyncMaster T190.
    Both of them do not power on when connected to the power supply line: the red LED starts flashing and the panel remains black.
    I guess there is a problem in the power supply stage. I had a look on the rear panel in order to open it, but apparently there are no screws for unassemble.
    Do you have any hint for this issue?
    Where I can find the Repair / Service Manual for SyncMaster T190 Monitor?
    Thanks a lot for your help!
    Max
  • Pentium4
    CapXon Be Gone
    • Sep 2011
    • 3741
    Re: Samsung SyncMaster T190, pwr led flashing
    It always helps to post clear pictures of both sides of the boards. I had one like that and it was just the start up cap that was going bad (47uF 50V CapXon)
    • _max_
      • Dec 2012
      • 46
      • Italy
      That's true but unfortunately, as I wrote, I can not open the case... So that's why I dd
      I'd not send any picture so far.
      • Pentium4
        CapXon Be Gone
        • Sep 2011
        • 3741
        They're usually held together by clips, you can usually carefully pry them open with a flathead. It could be the power brick as well, have you tried powering it on with a known good one?
        • _max_
          • Dec 2012
          • 46
          • Italy
          Thanks for your time! Yes I have tried several plugs and different cables, but both of them remain with the red led flickering. One question , do you know if there are some pictures or video to show me how to remove the covers? It looks to me that by forcing the opening something get broken...
          • _max_
            • Dec 2012
            • 46
            • Italy
            Where can I found the Service Manual for the SyncMaster T190 LCD Monitor ?
            • jhunvidz
              • Jun 2013
              • 27
              • philippines
              max and pentium 4 have already open the cover of your monitor?do you have any videos or pictures?
              • lexwalker
                • Feb 2011
                • 307
                • Malaysia
                Most of Samsung monitors have to use the pry technique to open them up (use flat head screwdriver and/or putty knife). Also remove the stand first before prying. Usually there are some screws at the stand attachment location which holds down the cover. The T190 chasis looks very similar to T220HD. See attachment...
                • jon koay
                  • Jun 2013
                  • 8
                  • Malaysia
                  Hi Max,
                  I too had the problem opening up the back cover of my Samsung T190 monitor. Go to Fixya.com and look up a guy by the name Werner Tebelmann. He has given a detail explanation on how to open up the back cover (T190) with photos attached. I managed to open up mine after reading his instructions.
                  Hopes this help. Good luck!!
                  • ant3202
                    HP 27es - LED monitor - Monitor Flashing On - Off
                    by ant3202
                    Hi Everyone
                    Lately I am experiencing the deja-vu incident on one of the led monitor like this.
                    https://www.badcaps.net/forum/troubl...lashing-on-off
                    The monitor is HP 27es LED Monitor
                    https://h30434.www3.hp.com/t5/Deskto...e/td-p/6804692
                    The monitor will randomly blackout and display no signal and will recover again.
                    Sometimes need to power and off again to restore the display but...
                    03-20-2025, 07:30 PM
                    09-07-2024, 05:50 AM
                    by momaka
                    03-15-2023, 10:17 PM
                  • learnmore
                    Samsung QE55Q60TAUXXU - flashing backlight and flashing standy light--no image
                    by learnmore
                    Hello Community!
                    CASE DETAILS
                    Promblem Signs: Backlight on 1 sec off 7sec > repeat && Red standby light: 1blink, off 3 sec, 2 blinks, off 5 secs, 2 blinks, off 3 sec, restart cycle
                    13V present on powerboard output. Backlight continues flashing after removing cables to pannel one at a time and even with both disconnected. NOTE: backlight STOPs flashing and remains on when connector between powerboard and mainboard (note Tcon built in) is disconnected.
                    Tried inserting firmware on USB and left it in for a few hours, but no change
                    03-03-2024, 09:49 AM
                    09-06-2024, 11:40 PM
