hp f2105 conversion to smd led
  • klein
    • Nov 2008
    • 37
    hi
    i have had this f2105 for a while and when i got it i searched google and everyone said the ccfl's were bad. and at that times i didn't wont to put $60.00 into it, a while back bought a strip of water proof flexible smd 5050 leds. so last night i took the screen apart and the strip of leds fit right in the ccfl tray, this morning i put it back together for testing and hooked the two led strings to a computer psu, after testing i find the the psu on the monitor is putting out 18.98v and 3.3v and i need 12v @ .75 amp
    do you think a voltage regulator will work? i was thinking of using a TO-220 L7812CV will it have to be heat sinked ?
    psu for monitor is a 4h.l1s02.a20 but i can't find a pdf on it.
    where can i pull the voltage for the regulator i was thinking right off the plug for the ccfl inverter being it is a spare part right now.
    Last edited by klein; 11-08-2012, 12:08 PM. Reason: forgot to set e-mail notofication
  • jetadm123
    • 2169
    Re: hp f2105 conversion to smd led
    Various versions of the LM7812 voltage regulator will put out 1A (or more) and take a input voltage up to 35V. If your requirements are 0.75A, then I would suggest you place it on a heatsink. You might be able to remove one of the inverter transformers and install a small heatsink in it's place. If the inverter board input voltage is fed through a single fuse, then you should be able sever the connection there to kill power to the inverter board and connect your voltage regulator as you suggested earlier.
    I don't know if the LED string brightness varies with the input voltage you feed to it, but if it does, then you might want to purchase a variable output regulator.
    • klein
      • Nov 2008
      • 37
      hi jetadm123
      i was going to take the inverter pcb right out it is a separate board and the monitor works with out it hooked up, and take the power from cn7 of the psu pcb.
      am i correct that the back or mounting hole of TO-220 L7812CV is ground the same as the centre leg of the regulator ? if this is true couldn't i just screw it to the steel plate that is holding the pcb boards that would give it a 10" x 21" heat sink.
      variable output regulator, i'm not sure how much voltage these will take they ate set up and resistored for 12v. but i do have a small strip of 3 smd's i might try so higher voltage on. i'v been looking for something to test my new variack on 1-130v 20 amp and a d5sb 20 bridge
      • jetadm123
        • 2169
        Originally posted by klein
        hi jetadm123
        The ground should be the same. To verify, set your meter to resistance and place one probe on the tab and the other on the center leg. You should read approx 0 ohms. How close is that metal plate to the LCD panel underneath? I don't know how hot the regulator will get, as heat could affect the display itself.
        • klein
          • Nov 2008
          • 37
          there is 3/8 of an inch there between the plate and the lcd back
          • mariushm
            • May 2011
            • 3799
            The power supply takes 19v and outputs 600v on those connectors to the CCFL lamps. Be careful what you do there, I hope you don't plan to connect the leds to the old lamp connectors.
            The controller on board takes 19v and generates AC to the lamps at about 200 Hz, then uses PWM to change the brightness based on an input voltage from the other board... with leds you would ignore that adjust wire.
            Otherwise, leds are current driven devices, not voltage driven. The brightness is adjusted by limiting the current going through them or using pwm (turning leds on and off so fast your eyes don't notice it).
            I don't know why are you guys talking about 12v linear regulator - if you plug too few of those leds to 12v, you're just gonna blow them up by giving them too much current.
            Let's say each of your SMD leds tops at 50 mA and their forward voltage is 3.3v. You can put 5 of these leds in series for a total of 15.5v voltage drop.
            Now you need to put a resistor in series with the leds to limit the current going through them, so you use Ohm's law:
            I = V / R ... I = (19v - 5x3.3v) / R therefore R = (19-16.5) / 0.05 = 50 ohm
            So you'd pick a standard 56 ohm resistor.
            The power going through the resistor would be IxIxR = 0.05x0.05x56 = 0.14A or 140mA, therefore you'd need a 0.25w resistor.
            This online calculator agrees with me: http://led.linear1.org/led.wiz
            I'm not sure how you plan on adjusting brightness because this method won't allow you to adjust anything.
            Could do some PWM with a attiny or a pic, by switching an npn transistor on an off hundreds of times a second.
            • Khron
              • Sep 2006
              • 1350
              • Finland
              Actually, the AC supplying the CCFl's is closer to ~50kHz. The PWM-dimming frequency's around 200Hz
              Khron's Cave - Electronics - Audio - Teardowns - Mods - Repairs - Projects - Music - Rants - Shenanigans
              • klein
                • Nov 2008
                • 37
                hi guys
                as stated before i'm going to take the inverter pcb right out.
                led are water proof flexible smd 5050 leds, they were already set up for 12v ready to go i just cut 3 leds off cause i need them shorter.
                this was just quick and dirty experiment but i'm not taking that screen apart again lol
                do you guys think i should put caps before and after the voltage regulator as the pdf shows for test conditions .
                • jetadm123
                  • 2169
                  I was assuming that klein was using a aftermarket automotive type 12V LED strip. Those strips have built-in current limiting resistors. Klein- was I wrong?
                  • klein
                    • Nov 2008
                    • 37
                    jetadm123
                    you are 100% correct bought from e*b*y.
                    • Th3_uN1Qu3
                      Believe in
                      • Jul 2010
                      • 6031
                      • Romania
                      You could use the DIM signal of the monitor, that way you can connect the brightness of the LED strip normally, from the monitor's menu, just as you would normally do.
                      Basically you need a PWM- or voltage-controlled current source. Edit: Since you say the strips have the limiting resistors built-in, you can just drive the ADJ pin of a LM317 from the DIM signal and a suitably configured resistive divider, if you don't mind the heat dissipation.
                      A working TV? How boring!
                      • jetadm123
                        • 2169
                        Just out of curiosity, since you put the monitor back together, can you please post a photo of what the monitor image looks like with the 2 LED strips lit? I'd like to see how bright and uniform the light is.
                        • klein
                          • Nov 2008
                          • 37
                          ok here they are :
                          lights out
                          lights on
                          lights on movie playing
                          you can see some of the leds at the top and the bottom but when i put the strips in i didn't stick them to the pans, if they were stuck to the pans you wouldn't see the led i believe.
                          i have a couple 100, 5050 smd's i'm thinking of making a picture frame with thoes and a 21 inch sq dell, i will try my hand at pwm on that, these pre maid strips the leds are 11.5mm apart
                          • klein
                            • Nov 2008
                            • 37
                            accentual monitor looks better then the pictures
                              It looks really good.
                              I would just use a power resistor though instead of a regulator. More reliable, it has to dissipate the same heat but is more capable of it. For 18V to 12V at 750mA you need an 8 ohm resistor; 8.2 ohm will do. The resistor will dissipate 4.6W, so choose a 7W or 10W for reliability.
                              • jetadm123
                                • 2169
                                One of the better repairs I've seen using a LED strip as a substitute. And much cheaper than new ccfl's!
                                I would still stick with the voltage regulator as the current 19V output is un-regulated and may vary widely under load. Even though the LED strip requirement is 12V, I didn't see what voltage range it will work under. Maybe 12-15V?
                                  So are the LEDs are setup as 5-LED string, since LED is the current device, you can use LM317 as a constant current source, and set it about 30mA. You can change the brightness by adjusting the current control resistor.
                                  Or you can use Voltage regulator to feed the LED string which already has limiting resistor built-in, by varying the supply voltage,you then basically vary the current.
                                    It's unlikely to vary under heavy load, like with a big LED strip, and 1V is only an extra 125mA.
                                    • klein
                                      • Nov 2008
                                      • 37
                                      with my variack 1-130v 20 amp and a d5sb 20 bridge , at 15v they were getting hot, noticeably hot i don't think what ever they are in bedded into to make them water proof holds the heat in. now you can get the strips that are not water proof they might work better if your going to feed them more voltage.
                                      this is the first large monitor i have taken apart and it has a 1/2 or better thick piece of plexie / lexon glass that the leds shine into that may help with the light distribution
                                      • jetadm123
                                        • 2169
                                        What's was the minimum voltage required for the string to light?
                                        • edugimeno
                                          Finding the wrong part at a loooong led strip, part works fine, part flickers, all parallel...
                                          by edugimeno
                                          Hi There!
                                          I'm trying to help my friend who owns a restaurant be just bought.
                                          He has a very long LED strip running along all the walls and columns. The strip is attached facing down 2in above the floor, using a wall panel that ends in a metal rail that finishes the panel underneath
                                          It's stuck using, I guess, the 2 sided tape that comes with the strip
                                          The issue is that like 1/2 of the full length, including 1/2 one wall, another entire wall, and one column, flickers after 4 or 5 minutes ON. Particularly it flashes staying OFF most of the time and flashing ON for 1 tenth...
                                          09-05-2024, 09:34 AM
                                        • adelage
                                          220v Led strip flickering
                                          by adelage
                                          Hi, I am installing a long led strip and I noticed that it frequently flickers slightly, it is not a strong nor regular thing, but it is noticeable and annoying. I have measured the voltage of the mains and it shows some fluctuations, it normally stays at around 226v, but often (every few seconds) drops down to 218/219v), and the flickering happens exactly at the same time. I have measured this at the counter and with every appliance off, so it's not related to the house electrical system, but that's how it comes from the supplier.
                                          I know that the best solution would be to get a voltage...
                                          11-03-2024, 09:49 AM
                                        • disorder
                                          HP 2311 display, 3.3v regulator fried, need help to replace
                                          by disorder
                                          hello,
                                          i have a hp display 2311 to repair, totaly dead
                                          on the board, il have 2 capacitor 470µf that are dead and the 3.3v regulator : ax6630-33
                                          i have no such regulator, can i replace this one with a mic5209-33 (3.3v outpout regulator too) ?
                                          thank you
                                          07-27-2025, 04:34 AM
                                        • benareeno
                                          Adjustable dc power supply and tcl led strip
                                          by benareeno
                                          I wonder if i shorted the whole strip...where to put pos and neg to just light up a single diode...or the entire strip. The strip lit for a second...so maybe i fried it? What say you?
                                          I have an adjustable dc power supply and was trying around 9 volts.
                                          I have a pic of a single diode...where to put pos and neg terminals to light it up?
                                          Pic of middle of strip..is this where i light the entire strip?
                                          And pic of end...or does this light the entire strip?
                                          Where to put pos and neg for single diode..multiple diodes and the entire...
                                          07-11-2021, 02:31 PM
                                        • bilux
                                          uP0109: 2A Ultra Low Dropout Linear Regulator equivalent substitute
                                          by bilux
                                          I want to find a replacement for uP0109 8pins, and i found this parts:
                                          uP0109 is "2A Ultra Low Dropout Linear Regulator"
                                          RT9199 is "Cost-Effective, 2A Peak Sink/Source Bus Termination Regulator"
                                          FP6137C is "2A BUS TERMINATION REGULATOR"
                                          can replace uP0109​ by RT9199 or FP6137C ?
                                          11-01-2024, 12:00 PM
