Samsung 740B plus won´t start
+ More Options
Posts
  • selldoor
    Slow Learner
    • Dec 2010
    • 7870
    Re: Samsung 740B plus won´t start
    I think its still most likely that c107 - when you said you changed it was that for a previously used one. It needs to be a good cap with low esr.
    • rogfanther
      • Jul 2006
      • 458
      • Brazil
      Hmm, well, to heat the opto with the soldering iron, I was near the C107 also ...
      The original wasn´t that low ESR ( 0.45 ohms as per the datasheet ) so, as I didn´t find a low one around here, just used a general purpose one.
      I´m waiting for the board to cool and giving time for all the caps to discharge, just to repeat the experiment. Will try to put some isolation between the heat and C107, otherwise will try transplanting the C107 from the good psu to the bad one.
      • selldoor
        Slow Learner
        • Dec 2010
        • 7870
        OK - you could also check its not a bad joint on that D103 looks a bit odd in the pic.
        • rogfanther
          • Jul 2006
          • 458
          • Brazil
          Ok, redid joint. I think it is a little odd because I had already replaced that diode.
          Well : used the C107 from the "good" psu in the "bad" one, and it didn´t work . Tried also with another cap, from an ATX psu, but same thing.
          Also, replaced the optocoupler with one from the parts box, still no change. If I heat the diode side of the opto ( near the CN2 connector ) , voltage climbs up and the controller start working.
          Tomorrow I will see if the resistors around the TL431 measure ok, and maybe replace it.
          • selldoor
            Slow Learner
            • Dec 2010
            • 7870
            Not much left to go at in that area - a bunch of caps that might work better when heated? How about heating further out and work in towards the opto perhaps start at the diodes above the caps.
            • Rtech
              • Jul 2010
              • 1095
              #26
              Disconnect D104,105.106 and 107 from the transformer side,and see what happens to the Vcc then.If the Vcc then works every time, you have isolated the problem.The next thing, without a diagram I am assuming that C107 is fed from the transformer via D103,you have proved the cap ok, but the diode could be 'leaky', easy to test by swapping it with the one from your good board.
              • rogfanther
                • Jul 2006
                • 458
                • Brazil
                #27
                @selldoor :
                Will try heating the diodes. As of now, for it to work, I´ve been heating with the solder iron directly over the opto.
                @rtech
                I believe that disconnecting the diodes would be the same as not connecting the logic board flat cable ? Without the logic board, the supply seems to come up ok, with Vcc a little low ( around 10.7V ) that I suppose is due to no load. But will try to disconnect the diodes tomorrow.
                I have already replaced the diode by a new one.( 1N4007, as it was ) .
                  Did you swap the ref diode IC102 (TL431)? It is used to regulate the output voltage by turning on the LED inside the OPTO which causes the opto-transistor on the receiving side to conduct more which will clamp down the output voltage if the output voltage rise above the ref point, or conduct less if the output voltage drops down.
                  • rogfanther
                    • Jul 2006
                    • 458
                    • Brazil
                    #29
                    Good Morning,
                    Not yet. That will be done today.
                    • rogfanther
                      • Jul 2006
                      • 458
                      • Brazil
                      #30
                      Aaaand, ..... it works.
                      The captain´s log :
                      - Revised all solder joints. Defect remains.
                      - substitute the zeners and pwm - defect remains
                      - substitute the (already replaced ) 1000uF x 10V caps, just because they were a different brand from those that worked in the other psu. Still nothing.
                      - before replacing the TL 431, observed that the psu would start after just touching the meter probe to the 431 ref output.
                      - tried reflowing the 431´s solder joints again. Same thing.
                      - Then, replaced the TL431. Finally, the thing works. Left it rest for some hours to coold and discharge the caps. Tested ok. Repeated some times. Still ok.
                      So, I consider it is fixed. Will order good new caps for them today, so I don´t need to open this thing again in the next months. Then test it correctly.
                      Thanks you all for the help.
                      • selldoor
                        Slow Learner
                        • Dec 2010
                        • 7870
                        #31
                        Great!! not sure how/why heating helped but at least it meant you were able to find the fault.
                        Well done.
                        • rogfanther
                          • Jul 2006
                          • 458
                          • Brazil
                          #32
                          Thanks. Not let´s hope with the new, good caps it behaves itself.
                          • m1ch43lzm
                            by m1ch43lzm
                            05-12-2025, 08:37 PM
                          • korben_dallas
                            Will I have a bricked logic board after reflow of the GPU v-core U8900 chip on my Mid-2012 15" Retina Macbook pro?
                            by korben_dallas
                            Hi everyone! I'm trying to fix my black screen / failed U8900 GPU v-core on my Mid-2012 Macbook Pro 15" Retinaby doing a rework/reflow of the chip (once I determine that's the real issue; but it likely is).
                            I've been disabling the GPU in NVRAM for a few years... but it's just time for a better solution.
                            I'm new to soldering but the only feasible way to fix this issue is to do something myself.
                            MY QUESTION:
                            I've been seeing some people (on this forum mostly) run into issues with the logic board needing a serial number or it being deactivated (?)...
                            02-14-2024, 12:23 AM
                          • tony359
                            2007 Macbook logic board fault
                            by tony359
                            Good day all,
                            I got a 2007 MacBook from a friend. The fan was not working so it was overheating.
                            Once the fan was swapped, I installed an OS and it worked fine.
                            The board had quite a few corroded spots so I removed it, touched those spots with a soldering iron, washed the board in PCB cleaning fluid (I've done that many times), rinsed it with distilled water, dried it etc.
                            Unfortunately it doesn't work anymore. It does turn on, fan spins, power LED turns on. But no picture.
                            If I see that right, I have missed VCORE on L7100 (page 59)....
                            01-23-2025, 06:59 AM
                          • mferna14
                            Logic Board 820-00840-A Missing EDP_BKLT_EN
                            by mferna14
                            Hi dear friends., I am working on a Apple MacBook Pro A1708 , Logic Board 820-00840-A that has no backlight. The logic board powers on fine, but no display. After Checking on the backlight driver chip, I found that the EDP_BKL_EN is missing. And this Power Enable comes from the PCH. So does this means this Logic board cannot be repaired & brought back to life again? The resistance from GRD to the test point of EDP_BKL_EN is around is 0.66M ohms. R8442 (0ohms) is ok. Any suggestion/Tip if any would really appreciate. ​
                            07-10-2024, 05:18 PM
                          • Tynan Dill
                            by Tynan Dill
                            Assuming...
                            11-22-2024, 01:46 PM
