Logic Board 820-00840-A Missing EDP_BKLT_EN
  • mferna14
    • Jun 2018
    • 1086
    Hi dear friends., I am working on a Apple MacBook Pro A1708 , Logic Board 820-00840-A that has no backlight. The logic board powers on fine, but no display. After Checking on the backlight driver chip, I found that the EDP_BKL_EN is missing. And this Power Enable comes from the PCH. So does this means this Logic board cannot be repaired & brought back to life again? The resistance from GRD to the test point of EDP_BKL_EN is around is 0.66M ohms. R8442 (0ohms) is ok. Any suggestion/Tip if any would really appreciate. ​
  • sajidmirza
    • Aug 2021
    • 24
    • india
    Remove Q9908 and U8400 and chk resistance before giving up.Give it a try
    Good luck
    • PITERPENY
      • Jul 2023
      • 527
      • Ukraine
      • microelektronics
      Is the display known to be good? they have a common problem with the flexible backlight cable
      • mferna14
        • Jun 2018
        • 1086
        I have a lot of T resistance boards (LCD logic board) & even slightly broken screen for this model. & I even used a Known good LCD, still the same, no difference, thanks PITERPENY
        • PITERPENY
          • Jul 2023
          • 527
          • Ukraine
          • microelektronics
          is there an image? since the backlight will not turn on if there is no image! Have you checked the J8500 lines?EDP_INT_AUX_N and EDP_INT_AUX_P ok?
          • mferna14
            • Jun 2018
            • 1086
            I get the image dear... I have a bare bone screen & I use a powerful LED torch to get a backlight. I see the Apple logo & the then folder clearly. & what is this for "EDP_INT_AUX_N and EDP_INT_AUX_P ok?"
            • reformatt
              • Feb 2020
              • 1691
              Connect via HDMI to external monitor, check internal display is detected and you can vary brightness up and down. Try a PRAM reset, also check I2C lines are pulled up to 5V.
              • Tynan Dill
                by Tynan Dill
                Assuming...
                11-22-2024, 01:46 PM
              • mferna14
                Logic Board 820-01987-A missing PP3V3_S5
                by mferna14
                Hi good Friends., today working on a Macbook Pro A2289, Logic board 820-01978-A. The history was liquid spill, Cleaned & replaced all corroded components & now the logic board shows 20v & .01amp on the meter. Not taking in any amps. Upon trouble shooting I get the required stable voltages 5V, PP3V3_G3H 3.3V but no PP3V3_S5. Checked the schematic, assume that this is generated from U7800. Checked all the Input/Output voltages on this chip. All is fine, except PP3V3_S5 is missing. Resistance from GND to PP3V3_S5 is 146 Kohms. First I need to make sure whether PP3V3_S5 is generated from...
                06-07-2025, 05:07 PM
              • m1ch43lzm
                by m1ch43lzm
                05-12-2025, 08:37 PM
              • joliver82
                Sony XR-65A95L no power due to logic board issue
                by joliver82
                Hi guys!
                I'm trying to repair a TV that a friend gave me recently. Lightning struck next to his house and broke the TV apart from more electronic devices.
                First of all I've checked the power supply and it works as expected. I removed the logic board and shorted the 3.3v standby output to TCON_ON and POWER_ON and every voltage was generated as expected (12v and 25v for logic board and 32v for TCON).
                When trying to boot the TV normally (having the board connected), the TCON_ON signal is not generated from it which made me think there's some issue in the logic...
                11-26-2025, 04:57 PM
              • ohren
                Upgrading a Samsung ue55nu7096u with logic board from an ue55ru7105k -- good idea?
                by ohren
                I hope this is the right forum to post in despite not technically being a repair, but still a question of swapping boards.
                I thought I'd explore the possibility to upgrade an existing working Samsung ue55nu7096u with the logic board (and power board if needed) of a newer model (ue55ru7105k) of the same size and appearance (and resolution). The reason being I'd like the extra inputs of that board including component in, an extra HDMI port and bluetooth. Its panel is broken so I have no use for the board otherwise.
                The models launched in 2018 and 2019 respectively....
                09-08-2023, 05:24 PM
