DELL 2405fpw
  • Mirage00
    • 58
    • Usa
    Re: DELL 2405fpw
    part number F5305S
    I-R 506C
    part number FR9024N
    I-R 452G
    part number H183
    950T65
    part number H185
    952T43
    • Mirage00
      • 58
      • Usa
      Re: DELL 2405fpw
      OK, let me get the voltages with everything hooked up
      • Mirage00
        • 58
        • Usa
        Re: DELL 2405fpw
        Ok fuse voltage on each side of fuse is .34 on each side
        • Mirage00
          • 58
          • Usa
          Re: DELL 2405fpw
          Here are the new readings with everything hooked up and power on
          part number F5305S
          I-R 506C
          Pin #1 18.30
          Pin #2 0
          Pin #3 18.66
          part number FR9024N
          I-R 452G
          Pin #1 18.44
          Pin #2 5.14
          Pin #3 18.70
          part number H183
          950T65
          Pin #1 3.29
          Pin #2 0
          Pin #3 2.48
          part number H185
          952T43
          Pin #1 0
          Pin #2 1.8
          Pin #3 3.28
          • retiredcaps
            • Apr 2010
            • 9271
            Re: DELL 2405fpw
            Originally posted by Mirage00
            part number F5305S
            I-R 506C
            Pin #1 18.30
            Pin #2 0
            Pin #3 18.66
            part number FR9024N
            I-R 452G
            Pin #1 18.44
            Pin #2 5.14
            Pin #3 18.70
            I will have to look up the 2 above. I'm not sure about those readings.
            part number H183
            950T65
            Pin #1 3.29
            Pin #2 0
            Pin #3 2.48
            part number H185
            952T43
            Pin #1 0
            Pin #2 1.8
            Pin #3 3.28
            The two above are working perfectly. The first is a 2.5V regulator. The second is a 1.8 regulator.
            See
            http://pdf1.alldatasheet.com/datashe.../G950T65U.html
            http://pdf1.alldatasheet.com/datashe.../G952T43U.html
            --- begin sig file ---
            --- end sig file ---
            • Mirage00
              • 58
              • Usa
              #26
              Re: DELL 2405fpw
              I really appreciate your help. Thank you
              • retiredcaps
                • Apr 2010
                • 9271
                #27
                Re: DELL 2405fpw
                Some sort of signal is being detected because when the backlight turns of after 30-40 seconds, if I toggle the monitor output on my laptop that is connected to the 2405fpw the backlight turns back on again.
                1) Does your laptop wallpaper show up on the lcd?
                2) If not, is the screen just white?
                • retiredcaps
                  • Apr 2010
                  • 9271
                  #28
                  Re: DELL 2405fpw
                  Wrt to post #27, can you get a picture of what is going on so we can see? Make sure a computer is hooked up to it.
                  Last edited by retiredcaps; 06-27-2012, 11:13 PM. Reason: Make sure a computer is hooked up to it.
                  • Mirage00
                    • 58
                    • Usa
                    #29
                    Re: DELL 2405fpw
                    Nothing shows on the LCD. The screen is a greyish black, the backlight is on because I can see the ccfl lit. Here is a pic of the monitor, its hard to see ( I was holding it up) but it shows the lights and buttons working at the bottom and the screen backlight on.
                    • retiredcaps
                      • Apr 2010
                      • 9271
                      #30
                      Re: DELL 2405fpw
                      Let's eliminate the obvious.
                      1) Have you tried a different computer?
                      2) Have you tried a different VGA or DVI cable?
                      3) Have you tried all the input ports?
                      4) Are you using known working computer and VGA/DVI cable?
                      • Mirage00
                        • 58
                        • Usa
                        #31
                        Re: DELL 2405fpw
                        Yes to all. As I mentioned the On Screen Menu does not display. I have a second 2405fpw and the OSM displays when you press the menu button regardless of it receiving a video signal (computer off).
                        • retiredcaps
                          • Apr 2010
                          • 9271
                          #32
                          Re: DELL 2405fpw
                          Not all monitors have that feature which is why we always ask for a computer to be hooked up.
                          Can we get an overall backside shot of the lcd? I can't quite tell the relationship of all the boards with the different orientations. I would like to see how all the boards are connected to each other.
                          • Mirage00
                            • 58
                            • Usa
                            #33
                            Re: DELL 2405fpw
                            Here ya go
                            • selldoor
                              Slow Learner
                              • 7870
                              #34
                              Re: DELL 2405fpw
                              Hi - in each corner of the main board there is a F1 to F4 designation are there any fuses there or is it just a fixing point? Also on the Power Supply there is an Orange pico torpedo fuse - has that been checked. I dont know much about circuits so its just a case of see a fuse check it. There are also 2 on the inverter board. Can you do a close up pic of the L shaped board - just for completeness.
                              EDIT
                              Also can you do a pic of the back of the main board if there are any component on it.
                              • Mirage00
                                • 58
                                • Usa
                                #35
                                Re: DELL 2405fpw
                                The F1-F4 boxes are not fixing points. Its odd, they are just square boxes. Not sure exactly what they are.
                                I didn't check the torpedo fuse, but I thought if the display is turning on and all button functions work, then the issue would not be power related on the power supply?
                                The L shaped board is just the USB/Media card dock. It's not part of the main board circuitry. If you still want a pic, I will need to take one.
                                • Mirage00
                                  • 58
                                  • Usa
                                  #36
                                  Re: DELL 2405fpw
                                  BTW is this considered a white screen? Only the backlight is on.
                                    Re: DELL 2405fpw
                                    0.34V at the T-CON fuse, means the T-CON is not getting the voltage for it to run.
                                    Please verify of what I think the connections are.
                                    We need to find that switched transistor that supplies the B+ to the T-CON fuse.
                                    • Mirage00
                                      • 58
                                      • Usa
                                      #38
                                      Re: DELL 2405fpw
                                      Thanks budm, I will check later today.
                                      • Mirage00
                                        • 58
                                        • Usa
                                        #39
                                        Re: DELL 2405fpw
                                        OK please bare with me, I'm not sure how to check this. I hooked up the DMM in OHM mode with the monitor off to each one of the pins and the other end on the FUSE and most of them read 0.
                                        • selldoor
                                          Slow Learner
                                          • 7870
                                          #40
                                          Re: DELL 2405fpw
                                          I think its just the last 4 pins at that end of the connector that are usually the power.
                                            LCD LED TV Service Menu Codes
                                            ALL LCD LED TV SERVICE MENU CODES
                                            Service Menu Code with Board Name
                                            China Universal Board / Jumper Board Service Menu Code
                                            Changhong Ruba Service Menu Code
                                            Ecostar LED TV Service Menu Code
                                            Orient LED TV Service Menu Code
                                            Haier LED TV Service Menu Code
                                            TCL LED TV Service Menu Code
                                            Samsung LED TV Service Menu Code
                                            LG LED TV Service Menu Code
                                            Videocon LED TV Service Menu Code
                                            Supra LED TV Service Menu Code
                                            Toshiba LED TV Service Menu Code
                                            Symphony LED TV Service Menu Code
                                            Veste/ LED TV Service Menu Code...
                                            10-31-2024, 03:58 AM
                                          • Bowline
                                            by Bowline
                                            06-11-2025, 10:13 AM
                                          • Aezakmi
                                            Dell 2408 - No OSD or input menu
                                            by Aezakmi
                                            A few days ago my Dell 2408 has stopped to working without any noticeable sign.
                                            It can be power on, power light stays green, backlight works but there is no OSD, menu input, Dell logo etc. It happens if there is some input source connected or not.
                                            I disassembled the case but I didn't see any failures on the board. The only element that looked suspicious was L6561 - there was some brown dirt under it. So I replaced this IC but it changed nothing.
                                            What else should I checked or is this repair even possible/worthwhile?
                                            Thank you for your c...
                                            01-29-2024, 04:12 AM
                                          • master3112
                                            by master3112
                                            07-29-2025, 01:55 PM
                                          • F R 2568
                                            Dell Latitude 5420 does not start (no post) need help to find the reason why
                                            by F R 2568
                                            Hello all,
                                            this is my first post, so if I make mistakes please do not hesitate to point them out, thank you in advance.
                                            I got a Dell Latitude 5420 (Service Tag: 7RFM6D3, Motherboard: GDF40 LA-491P Rev.: 2.0 (A01)) which does not start and I want to repair it. These are the symptoms:
                                            If the laptop is only connected to the AC adapter (battery removed):
                                            When I press the power button, the keyboard backlight and the display backlight are turning on. Caps key light is lightning, but key does not respond to pressing it.
                                            The power/battery...
                                            01-08-2025, 05:45 AM
