Steer me the right way on this Samsung 245BW of epic cruddyness?
  • izzy
    • 9
    Geez, I've spent days reading here now, and I've come to the conclusion that Samsung must have let the new guy design the 245B[W] or something. I guess, there are a few advantages to having the one that always breaks...looks like a few folks around here just about have the schematics memorized, heh.
    Anyhow, I'd appreciate if someone with more cluepons than I could look over my findings, and see if any of them are even slightly factual. I've played electricity some and only made my hair stand on end a couple times, but this is substantially beyond my previous experience. This dang thing cost way too much to just toss out tho, and besides...what am I gonna do, break it?
    My 245BW has always done the blue horizontal flickery lines thing after waking up from power saving. I figured out a power cycle would fix it, assumed it was a driver/firmware bug or something and forgot about it. All was good until the other day when it learned the other popular trick. Now it has the far too common 'screen blank but power LED behaves normally' thing...acts like it's turning on+off, goes to sleep, wakes up, etc...but the display is limited to a resolution of 1x1 at 1 bit color (blue light off, or blue light on...). [Sorry, I think I went a bit nutty reading the 20something page long 245BW thread...]
    Here's what I have found/speculated/invented while wishing I had a clue:
    - I have the more popularly broken BN44-00173A power board.
    - I believe RB805 is dead, RB806/RB807 appear okay
    - Inverter board requires new caps, C39 is tossing it's cookies (it's a miracle it worked long enough for RB805 to blow up...or could these be related?)
    - Caps on power board all look ok, but should probably be changed anyway
    - 24V appears dead (makes sense, I believe, without RB805)
    - All fuses seem okay (1 on inverter, 3 on power board), To the untrained eye, FB802S looks more like a fireplace than a fuse...reading 0.0 - 0.1 ohms though.
    - Not sure about CM802/RM802 - is it possible to test RM802 in circuit, or must a leg be lifted? If it can be tested in circuit, I believe it's toast...
    Basically, I'm concerned by the abundance of heat marks on the power board, and by the great difficulty that a few people had in getting it going. I'd be interested in giving a go at changing some stuff, but not if the whole thing is generally toasty. Any advice is welcome...no fancy equipment got a seemingly acceptible DMM that does ohms and volts. Don't have a sufficiently powerful soldering iron yet, but willing to get one. Camera isn't the best, but hopefully it'll work. Love you guys forever if you help me quit using this teeny tiny 19" CRT that is taking up six times the deskspace
    Oh, and I'd stress more about picture quality, but this board seems so well documented that I hope it's not a problem If needed, I can take some closer up, and paste them together/zoom em out or something...manual anti-aliasing hehe.
  • selldoor
    Slow Learner
    • 7870
    Re: Steer me the right way on this Samsung 245BW of epic cruddyness?
    Just because you have had to read an epic thread there is no need to create another one - this would probably have been enough:
    We dont know at this point if it is a quick fix or even a no fix
    My suggestion would be to replace the 3 resistors and the known to be faulty caps then come back if it doesnt work.
    Fuse is ok. RM 802 test in circuit compare with color bands.
    If you have to lift it you may as well replace it - its not going to add much to your outlay.
    Photos are not really sharp enough and whilst the board may be well documented you have chosen to start a new thread.
    I dont have the inclination to keep skipping back to another thread to find the board numbers so that I can tell you which particular diode on your board looks quite heated and needs tested. I cant read the number on your picture so you will have to guess.
      I believe RB805/RB806/RB807 should all measure 68 ohms.
      I'm not sure what the purpose of these resistors is... Looks like maybe bias power for the standby controller IC but I can't tell.
      You will quickly learn that Samsung prices its products high on the retail sticker, but inside they are very poorly made. Often a little better than the really cheap ones, but not much better.
        All I know it that the three 68 Ohms are hooked up in series. Still trying to figure out their functions in the circuits.
        • izzy
          • 9
          Thanks for the replies, probably be early next week before I get much of a chance to work on it again but I'll try to start rounding up some supplies. I'll let you all know when I destroy it with my poor soldering skills
          • jetadm123
            • 2169
            Hopefully, you have at least a digital multimeter to perform basic measurements. RB805 is a common failure on your board. As was said previously, it's a 68 ohm resistor. If it measures bad, then replace all 3 of the 68 ohm resistors. RM802 seldom fails, it should read 1 Meg ohm. CM802 is the second most common failure. It's rated at 18nf 630V. C39 on the inverter board is clearly bad and when you replace it make sure you also replace the other green cap next to it.
            • izzy
              • 9
              I thought I'd resurrect this thread to report a belated success! After letting it gather dust for a few months, I replaced the three 68 ohm resistors and the monitor came to life! I did not replace the capacitor that appears to be puking its guts out on the inverter board, though I know I really should...but I'm really stoked by the success so far - this was the first project of this nature I've tried, so if anyone has a similar problem and is hesitating to dive in for the first time, you can do it!
              Thanks to everyone who has posted advice and guides on this board, you saved my monitor
              Isaac
                Great. You should also remove ALL the glues on the components.
                https://www.badcaps.net/forum/showth...763#post279763
                read post 569 and up.
                • smason
                  • 1652
                  That cap has a job to do, and it ain't gettin' it done if it's bloated and puking.
                  If it's not doing it's job other components will be stressin'
                  It's harder to disassemble a monitor than it is to replace a cap.
                  Nike.
                  • jason123
                    Epic failure of the screen suction holders
                    by jason123
                    Just sharing a failure of the suction cups used for screen removal. I don't know if these require special maintenance, but they came with no literature.
                    Today i was repairing a Vizio E70-E3 (70" 4k TV) with bad backlight. One of the suction cups failed and the panel hit the ground and shattered. I got these from SJ so they're supposed to be decent quality.
                    Anything you guys do to maintain the rubber on these? I wipe them with damp rag before use, then wipe dry. Any hints / tips?
                    10-06-2022, 02:39 PM
                  • bellyacres
                    Samsung 245BW BN44-0019A
                    by bellyacres
                    Hello all,
                    First time post here. I've searched here and used up my know-how. I'm at a loss on how to continue with this. I really don't want to blown another pair of mosfets!
                    https://cdn.badcaps-static.com/pdfs/...f8a620fd8c.pdf
                    Is the schematic that I've been using, not an exact match, but I believe that it's close enough for this board as a guide.
                    Here is what was found on initial inspection.
                    CM809 47pf obviously blown open on initial examination
                    QM801, QM802 FQPF5N50C shorted
                    RM801 0.22 1W FR open...
                    05-28-2020, 05:27 PM
                  • OberAgain
                    Syncmaster 245bw going dim/bright at times after all caps/resistors replaced.
                    by OberAgain
                    I just did a replacement of all caps/resistors for the 245bw, I have done it a few times prior to fix my other monitors and this was definitely the second+ repair done on this board (first by me, bought off ebay)
                    Anyways, now when windows dialog boxes come up it gets dim, or with I use this Windows Tweaker program it gets really bright then slowly dims back down and to a yellowish tint after every change made. The monitor works fairly decent as long as you ignore the random changes in brightness when you open/close anything.
                    The previous repair was done really sloppy and...
                    01-31-2019, 12:47 PM
                  • jlafaye
                    Zotac RTX 3070 Ti Trinity no power
                    by jlafaye
                    I am trying to troubleshoot & repair a Zotax RTX 3070 Ti Trinity for which I was not able to find schematics nor board view.
                    The card came up with no apparent short circuit but was missing some voltages; unfortunately I cannot remember which ones as it was two weeks ago. While probing I accidentally shorted 2 pins of an IC (cannot remember which one either) and burnt GS9238 which I understand to be a 5V power supply.
                    I replaced this GS9238 but unfortunately I am not able to get back the 5V.
                    Checked the soldering twice, even tried another...
                    03-16-2025, 10:47 AM
                  • ratdude747
                    Ratdude's computer workbench... and epic fail build
                    by ratdude747
                    Tonight I did some major clean up work on my electronics workbench... it was a real pit and I need work space for what was going to be an upcoming project. Might as well, because working on my car outside is out of the question:
                    Before I show what the project was (and why it became a complete fail), while it's clean and presentable (or at least the half I'm going to show), here's my current PC work area:
                    Note that I said half was presentable... the other half is mostly organized but has a bunch of crap stacked up (and the empty pop can, I know...
                    01-20-2019, 01:55 AM
