LG flatron L1718S - shaky picture when not in native resolution
+ More Options
Posts
  • retiredcaps
    • Apr 2010
    • 9271
    #41
    Re: LG flatron L1718S - shaky picture when not in native resolution
    Originally posted by bocca
    oIn the meantime i found one on the old motherboard but fried it while desoldering.
    I remove those SOT packages like so
    https://www.badcaps.net/forum/showpo...&postcount=139
    --- begin sig file ---
    --- end sig file ---
    • bocca
      • Mar 2012
      • 107
      • Serbia
      #42
      Very interesting! What kind of tape is that exactly? I thinh i've seen it couple of times in laptop mobos.
      One question. Is desoldering wick of any use with SMD's?
        Looks like Kapton to me. Kitchen foil will also do the job, cover up everything you want intact.
        Desoldering wick is very useful for SMD work. I sometimes find it is easier to flood the pins of a SOT223 with solder so they are all bridged, then wick it all up so the three pins are loose, then I heat up the tab and try to lift it.
        • retiredcaps
          • Apr 2010
          • 9271
          #44
          Yes, Kapton tape. It is trademark of Dupont. You can find it widely available on ebay. I got 100ft of the widest tape I could find with the thought that I can always cut it into strips.
          Aluminum foil works as well, but I don't know how to secure the foil down to the board and not have it blow away.
          • mockingbird
            • Dec 2008
            • 5484
            #45
            bocca -
            Any update with this?
            I did a total re-cap of the PSU and logic board, but I'm still stuck witht he same symptom... backlights come on but no picture. Can't see the OSD either. It's not a white screen, just no picture.
            • bocca
              • Mar 2012
              • 107
              • Serbia
              #46
              Hey man.
              Nah, no update. Still waiting for the damn voltage regulator.
              Did you try those 4 cables that go to the PSU? Are they OK, power coming thru clean? If the backlight is on, then logic board is letting the power through, but signal from the video card is not being trasmitted. Maybe the buig chip itself has gone bad?
              • selldoor
                Slow Learner
                • Dec 2010
                • 7870
                #47
                Originally posted by mockingbird
                bocca -
                Did you test your voltage regulators?
                • bocca
                  • Mar 2012
                  • 107
                  • Serbia
                  #48
                  Was the problem present before the recaping too? I mean, backilight on, no picture
                  • selldoor
                    Slow Learner
                    • Dec 2010
                    • 7870
                    #49
                    Hey man.Nah, no update. Still waiting for the damn voltage regulator.
                    I bought some off that ebay site - I'll let you know when I get them then if you still need Ill post you a couple.
                    • bocca
                      • Mar 2012
                      • 107
                      • Serbia
                      #50
                      that would be great! I tried to order them but no one will work without paypal, even though some accepted to send to serbia.
                      One store here sent me the response that they'll make an order "but only if i take 100 or more because it too much of a hassle to order just a few for me". So I'm stuck basicly
                      • mockingbird
                        • Dec 2008
                        • 5484
                        #51
                        This is the next step...
                        Yes. Exact same problem as before...
                        • mockingbird
                          • Dec 2008
                          • 5484
                          #52
                          YAY!!!
                          I changed the 1.8v regulator on the logic board, fired it up and I saw the Flatron Logo, and then the PC input! Woohoo!
                          My first SMD repair!!!
                          I removed the regulators with a 60w iron if anyone is wondering. It takes a bit of finesse, but it is possible.
                          My replacement regulator came from an old Acer logic board. It's an STMicro part "LD18A", almost like this.
                          Thanks everyone for the help. There is also another good thread for this monitor here, if anyone is interested.
                            These regulators cost 6-10 cents each in volume, so 100 could be worth it if you can get a good price...
                            • bocca
                              • Mar 2012
                              • 107
                              • Serbia
                              #54
                              @mockingbird: congrats man! Why oh why can't i find one to salvage?
                              @tom66: unfortunately price is not so good it goes to about 30 euros for the 100 and that's more that this monitor's worth i know it souns silly but thats the prices here. Nothing to do about is but whine at forums like these
                              OK, at least we definitely know that 1.8 reg is a bad boy so the search continues!
                              • mockingbird
                                • Dec 2008
                                • 5484
                                #55
                                Actually I knew I had one because I have a very similar PSU/logic (ILPI---) from an Optiquest. I didn't take it from that one partially because it would be difficult to get to with the iron... Then I found the Acer logic board and it was really easy to get to... Looking around my house I see them on all kinds of components. The thing is, there are like a million different names for this regulator. And you have to make sure to get the 1.8v version. Look on spare AGP videocards, you might find one there.
                                Free Mladic!
                                • retiredcaps
                                  • Apr 2010
                                  • 9271
                                  #56
                                  I received 10 from China for $1 + free shipping. I fixed an Acer lcd that has been sitting in my basement for about 14 months with a bad 1.8V regulator.
                                  @bocca, If you can't find one in the next few days, PM with your address. I think sending a letter to your country is only $1.80 CDN. I'll send you a couple.
                                    That is very nice of you to offer that, retiredcaps!
                                    • bocca
                                      • Mar 2012
                                      • 107
                                      • Serbia
                                      #58
                                      retiredcaps, thank you very much for your offer! If I don't find it in couple a days I'll PM you my postal address, and of course, hope to see to returning you the favour
                                      @mockingbird: you sure you're not serbian, mate?
                                      • retiredcaps
                                        • Apr 2010
                                        • 9271
                                        #59
                                        Selldoor in post #49 offered, but I already have them and I know at least one of the ten work.
                                        • bocca
                                          • Mar 2012
                                          • 107
                                          • Serbia
                                          #60
                                          retiredcaps, selldoor, I haven't had any luck finding there voltage regulators, so if the offer still stands...
                                          • Tr0ll
                                            by Tr0ll
                                            Original T-con:
                                            First replacement T-con:
                                            10-07-2023, 07:48 PM
                                          • JJAAMM
                                            by JJAAMM
                                            Problem
                                            07-06-2023, 06:01 AM
                                          • TR103
                                            by TR103
                                            - it keeps rebooting
                                            01-22-2025, 04:12 PM
                                          • Mgiffune
                                            by Mgiffune
                                            I have a 60 inch Samsung UN60EH6000F flatscreen TV. The screen went black a few months ago Sound is good, backlight is good, no menu. I replaced the TCon board with a used board purchased from Ebay. It worked fine for a 3-4 months, then the screen started β€˜fading' back. Once again, sound is good, backlight is good, no menu. However, this time the picture looks fine for about 10-15 minutes, then fades back. If I power cycle the TV, the display reappears, for another 10-15 minutes, then fades black again. Repeatable ever time.
                                            I ordered a supposedly β€˜new' Tcon board this time, and
                                            06-09-2024, 10:28 AM
                                          • CyberPhoenix
                                            Issue with picture quality of Sony bravia TV
                                            by CyberPhoenix
                                            Hello, Last week I bought the 50" Sony X80j tv everything was working fine, untill I plugged the tv in a ups power supply 650va the tv remote control became unresponsive and the TV became laggy after a while the picture quality isn't the same as before the tv seems less brighter and the picture is somehow blurry, people's faces don't look as natural as before, there is a mini orange-pink tint to the edge of people's faces especially in NETFLIX Dolby Vision like in One Piece ep1 Alvida skin tone, my intention was to protect the tv but something went wrong I checked the ups with a multimeter,...
                                            01-22-2024, 02:08 AM
