Inverter check
  • stepgr
    • Nov 2008
    • 34
    • Greece
    Inverter check
    What type of test equipment is needed to check backlight inverters ? With the multimeter there's not much you can check besides the input voltages, would a frequency counter be suitable to check the output ? Anybody with experience on the subject ?
  • selldoor
    Slow Learner
    • Dec 2010
    • 7870
    Re: Inverter check
    If you mean testing inverter transformers then we normally advise not to try and test the output voltage as this can be between 1000 and 4000 volts.
    This is a link to the suggested method of testing (with the power OFF)
    http://lcdparts.net/TransformerDetai...ProductID=2724
    There are of course other types of transformer but the idea is basically the same. You measure the secondary wiring resistances (meter on 2000 ohms )and compare - should be within 3%. If you dont know where to measure post good clear pictures of the front and back of the boards they are on and we can help.
      Re: Inverter check
      Using test lamp to verify that you do not have the lamps problem is my first test, then you should have ESR/CAP meter for testing the caps, Ringer tester for testing the transformer, DMM, Hair dryer for heating components and boards, Cool spray for electronics troubleshooting for cooling components, Oscilloscope for looking at the SMPS and Inverter controller IC outputs, good magnifying glass, Isolation transformer andGFI AC outlet for safety, lots of reading on BADCAPS.NET, logical mind and common sense.
      Home made test lamp: https://www.badcaps.net/forum/showthread.php?t=19987
      Or remove old lamp assemblies from broken LCD panel.
      • stepgr
        • Nov 2008
        • 34
        • Greece
        Re: Inverter check
        Thanks I'll have a look , also if say I have an old panel with ccfl light on it, could I remove the light and use it as a test tube or it would be pointless ?
          Re: Inverter check
          Yes, remove the lamp assemblies and save them for testing the Inverter, it will save a lot of your time to narrown down to find out if you have lamp problems or inverter board problems.
          • selldoor
            Slow Learner
            • Dec 2010
            • 7870
            Re: Inverter check
            I didnt risk removing the lamp/s - you can just plug them in to the board you are testing
            if the plugs are the same size. It is a bit more cumbersome.
            • khelane
              test active pfc power with lamp test
              by khelane
              Hello
              I have a big problem and that is that in some cases when repairing active pfc power supplies I cannot work with a test lamp. I can only get help with 5 volts standby and for starting and starting I have to work without a lamp and this way there is a possibility of parts exploding and other parts being added.
              Sometimes with a multimeter test the problems can be reduced to some extent, but I had several cases that had to be tested on and online and recently two varistors exploded. They had terrible resistance because the power supplies were over 800 watts.
              Is there a way...
              06-03-2025, 01:00 AM
            • ttmi100x
              HANNSG Hi221 -- 2 secs to black feat. CCFL flicker & "burn" marks on power board
              by ttmi100x
              Greetings everyone,
              I have a HANNSG Hi221 monitor that exhibits two seconds to black issues (backlight goes off, display is still on as confirmed by shining a flashlight on it) with some additional oddities...
              The monitor failed on me with a standard "2 seconds to black" some time ago prompting me to initially replace most of the electrolytic capacitors (some of them were bulging/leaking).
              Things kinda sorta worked for a night, then the problem returned along with some flickering and "buzzing" noises.
              Upon closer inspection...
              07-31-2024, 06:36 PM
            • lmcancu
              LED Strip test points and testing?
              by lmcancu
              Hi is there a guide in this forum on how to test the LED backlight TV strips? I purchased an LED tester on amazon, but I am a bit confused on the test points and how to test the individual LEDs? I took apart a RCA 43" TV Rlded4331b. Please see attached pictures. I understand that all the LEDs are in series, but on these strips I don't see any individual test points for each LED? Any tips or guides?
              Thanks in advance...
              03-20-2023, 07:52 AM
            • R7027
              How to probe TP7002 for AP_PS_HOLD on SM-G930F?
              by R7027
              In the service manual for Galaxy S7 (SM-G930F), step number four in the flow chart for troubleshooting power-on issue is to check the voltage level of a "signal".
              I had a very hard time locating this. I didn't understand what it means to check for voltage of something by its signal name, and it's location was not described in the service manual (not that I could see in my four chapter excerpt of the complete manual). Then I learned that this signal name needs to be translated into a test point (TP) ID on the board. This is unlikely to be referenced in a service...
              01-02-2023, 06:25 AM
            • chth96
              How Can I test PWM DM0365R?
              by chth96
              Hello
              I have power adaptor(220V/input, 12V 1.2A/output) which has symptom of fluctuating output DC voltage between 11.5V-12.2V.
              So I opened its plastic case and when switched it on, I heard constant tik tik sound from inside its PCB.
              I measured DC voltage between negative and positive pin of the largest capacitor(400v 10uf) and it was measured contant 300V.
              I also measured ESR value of all capacitors and I noticed that one of capacitor(KMG 16v 470uf), which located in the secondary side, have high ESR value(10 ohm),So I replaced it with same specification NXH capacitor....
              06-18-2025, 04:14 PM
