HANNSPREE HF289H Black Screen No Power
  • ismolika
    • Nov 2012
    • 8
    • turkey
    #61
    Re: HANNSPREE HF289H Black Screen No Power
    Hello all, I have the same model and went yellow light. When i plug the monitor to pc yellow light goes off , if i unplug it from pc yellow light goes back on.
    Can you guys look at the picture and tell me how many and which caps i need to replace and/or what kind of caps i need to go get?
    Thank you very much.
    • Qbass70
      • Aug 2012
      • 9
      I would replace all of them. You are going to have to look at all of them as you remove them, no one has a list that i got anyway... what I should have done is took a picture of the whole board ( yours isn't showing the top part), took the caps off one by one and wrote down what they were with a map.
      Mine worked after I replaced the 22uf 35v and other small ones. the only ones I didnt replace were a 1uf 100v, and 2 22uf 50v on the outer edges. there are several 1000uf 25v & 35v, 470uf 35v, 25v, 10v...etc..there is 1 22uf 400v cap on there too. Order them from digikey, they will be the best quality. good luck, i'm a beginner at fixing monitors and im using mine right now after fixing
      • ismolika
        • Nov 2012
        • 8
        • turkey
        #63
        Thanks for your reply
        I took this board to local repair shop and guy said caps look good, He wants me to bring the whole monitor. I did change some caps on my old Samsung and caps did look bad ( tops were blown) But on this monitor all caps look ok like repair guy said. I don't know if i should just change them or bring the monitor to him to look at the whole thing.
        What would you say?
        • selldoor
          Slow Learner
          • Dec 2010
          • 7870
          #64
          If you want to try to fix it yourself you will need a multimeter and soldering equipment.
          If you cant fix it you can still take it to the repair shop.
          We will need better pictures posted using manage attachments.
          Welcome to the forum-
          We can help a lot more if you please post good clear pictures of the whole chassis, and then pictures of each board, front and back (in the same orientation) and close up of connectors, (max resolution 2000x2000 and 2MB) using the manage attachments button, which is found by clicking "go advanced" under quick reply.
          Examples of what is needed
          https://www.badcaps.net/forum/attachm...1&d=1290283049
          https://www.badcaps.net/forum/attachm...7&d=1280167246
          It will be useful if you can say what the supposed fault was and a bit about yourself - skills tools etc.
          • ismolika
            • Nov 2012
            • 8
            • turkey
            #65
            Thank you for the info
            I did drop it off to a repair shop and will know whats going on Monday.
            I live in Istanbul, Turkey now, so repairs could be cheaper here than US. I will post more after Monday.
            Once again thank you for your support.
            • retiredcaps
              • Apr 2010
              • 9271
              #66
              It may turn out they are good, but anyone who declares that capacitors are good by simple visual inspection doesn't know what they are talking about.
              A capacitor can appear fine, just like an AA battery looks good, but have incorrect ESR or capacitance. The two parameters requires specialized test equipment to measure them.
              --- begin sig file ---
              --- end sig file ---
              • Lumberjack777
                • Dec 2010
                • 464
                #67
                That's exactly right RC. This board is a perfect example of that. This is one of the "HANNS" boards where the small capacitors in the middle dry up due to extreme heat and poor quality. You cannot tell just by looking at them. But need an ESR tester.
                Ismolika; Does this look like your board? I'm attaching a picture of the 3 caps that need to be replaced. (circled in red). The ones circled in blue are optional. You'll need to use high quality, low ESR - 105c rated capacitors because they take a lot of heat.
                You could replace all of the caps: but when I tested the others on my boards the ESR was still very low and good. I have fixed a couple of these monitors and it was always those 3 little caps. Good luck! ~L-J-7~
                Last edited by Lumberjack777; 12-02-2012, 02:52 AM. Reason: Additional information
                • ismolika
                  • Nov 2012
                  • 8
                  • turkey
                  #68
                  That is the same board i have. I will have to buy the equipment to test the caps. Thank you for your help
                  • ismolika
                    • Nov 2012
                    • 8
                    • turkey
                    #69
                    Repair guy couldn't find whats wrong with it, lol
                    So, now i have to go get some tools and try to fix it myself. Ill post some more pictures, maybe you guys can tell me more about it.
                    Before i go on and get my hands dirty can you guys answer a few questions please
                    1- Is there a way to test the caps without taking them out?
                    2- What voltage numbers iam looking for? Good cap , bad cap?
                    Thank you.
                    • selldoor
                      Slow Learner
                      • Dec 2010
                      • 7870
                      #70
                      1 No - without an esr meter you cant even test them when out.
                      2 Bad caps can reflect in odd voltages on the board you cant just say
                      voltage x = bad cap
                      post the pictures to see if we can spot anything and source the 3 caps
                      L777 mentioned.
                      • ismolika
                        • Nov 2012
                        • 8
                        • turkey
                        #71
                        ok SUCCESS Repair guy said he cant fix it. So i took it back and,
                        I did change all the caps with red circle and whatever i could with blue. I had very little exp. with soldering but i did it. woooottt. I am using my monitor right now.
                        Thank you very very much to all people who helped out.
                        I am one happy camper at the moment )
                        • retiredcaps
                          • Apr 2010
                          • 9271
                          #72
                          Refer back to post #66. If the repair guy is serious about his business, he should consider investing in an ESR meter.
                          While I'm glad you got it fixed, unless you have an ESR meter to check every capacitor out of circuit, there could be more caps that are bad than the 3 you changed. As I have mentioned several times, this particular monitor in its various incarnations seems to run very temperature hot drying out caps on both the power and main board.
                          • ismolika
                            • Nov 2012
                            • 8
                            • turkey
                            #73
                            You are right , Monitor was hot before, you could feel the heat from screen, Its not like that anymore now.
                            I was low on cash so i did buy analog meter but its very difficult to understand it. I will buy digital int he future. Its kinda hard to check the caps without taking them out. Plus i need some soldering classes. I did a messy job but hey it worked
                            • gunslinger2013
                              • May 2013
                              • unites states
                              #74
                              I have the same issue that everyone basically has with the monitor. Doesn't power on, then i get an orange light, followed by a blue blinking light. This whole process takes about 30 min to an hour.
                              I am going to attempt the repair myself after reading some of the successes in this forum.
                                Try setting the PC video resolution to the lowest setting and see if the monitor will stay on.
                                • ckconboy
                                  • Aug 2013
                                  I had the same problem about 4 months ago. I took the monitor into an electronics repair facility and 4 months later, I was told that the problem is the "Main Board".
                                  (Hannspree Part #70-HF9901006010 - MAIN BOARD HSG1052)
                                  Unfortunately, I was then told that the part was "No longer available". I "WAS" running two of these monitors and I'm now trying to find another one. Hannspree has a "Retail Store" in Los Angeles, I'm hoping to start there. If anyone knows where I can find this part, it would be greatly appreciated. Thanks in advance.
                                  • Lumberjack777
                                    • Dec 2010
                                    • 464
                                    #77
                                    The part number kinda threw me a little, because I could not find it ever being sold, anywhere at any time. Try part number HF990100G010
                                    That's a "G" not a "6". Can't tell you how many times I have made the same mistake.
                                    • konverts
                                      • Mar 2014
                                      • Philippines
                                      #78
                                      Hello, looking for fixes to my hanspree monitor brought me here. I have similar problems to what people are describing in this thread. It started with My Led Power button having issues when waking from sleep mode, its performance diminished over time, to where the monitor would only turn on when cold.
                                      I have removed the 8 caps that are circled in the image posted earlier in this thread and ordered replacements on digikey. I wanted to make sure I ordered the right caps as I wasn't sure about several factors like ripple current, impedence and size. If anyone can tell me if these capacitors i ordered listed below will work, it would be much appreciated. I have also attached a board map of the capacitors I removed.
                                      1x P13462-ND EEU-EB1H2R2S CAP ALUM 2.2UF 50V 20% RADIAL
                                      1x P13478-ND EEU-EB1H100S CAP ALUM 10UF 50V 20% RADIAL
                                      1x 493-10411-1-ND UTT1V100MDD1TP CAP ALUM 10UF 35V 20% RADIAL
                                      3x 493-11889-1-ND UPX1V220MPD1TD CAP ALUM 22UF 35V 20% RADIAL
                                      1x 493-1962-ND UPW2A010MDD CAP ALUM 1.0UF 100V 20% RADIAL
                                      1x 493-3288-ND UTS1H470MPD CAP ALUM 47UF 50V 20% RADIAL
                                      Any help is much appreciated, and thank you in advance!
                                      • kennad
                                        • Jul 2014
                                        I have (2) of these 289H monitors that are having the same problem as being described here. Going give a shot at replacing the caps mentioned. Will keep you posted. Thanks for a starting point.
                                        • konverts
                                          • Mar 2014
                                          • Philippines
                                          #80
                                          Well I replaced the 8 caps and the monitor has started up perfectly. I also removed 5 vertical lines on the screen by pressing near the edges to fix the loose connections. Now in testing phase of using the monitor, the fact that it started up at all is a good sign, will repost if the problem persists. But so far so good, this thread has helped out a lot!
                                          • PantherDave
                                            by PantherDave
                                            Hi all!
                                            05-29-2024, 02:01 PM
                                          • grimacelord
                                            HP 15-EH1070wm - Black Screen With Power LED.
                                            by grimacelord
                                            I have an HP 15-eh1070wm laptop that came to me for the same reasons I am starting this thread. The charging LED appears when the laptop power adapter is connected and the power LED appears when pressing the power button, but nothing appears on screen.
                                            First thing I did was take off the bottom panel and remove the battery and then press and hold the power button for 30 seconds and then reinstall the battery and power on. The fan spins and this time, the back light illuminates and a brief message appears on the screen for about 1 second saying something along like,...
                                            01-28-2023, 10:50 AM
                                          • jean luc ferre
                                            acer aspire v5 571p touching screen cracked led blue of power indicator blinks 1s lighted 3s off.
                                            by jean luc ferre
                                            on this laptop acer aspire v571p the led of the power indicator blinks blue for periods of 1s lighted and 3s off after switch on and this indefinitely.
                                            i tried the hard reset, cmos reset, changing the ram without results.
                                            in order to reach the cmos battery i disassembled the laptop and did several mesures with my multimeter.
                                            The 19v, 5v, 3v are well established after the chip 5v-3v. the following signals : 3d3v_aux_kbc (which supplies the sio chip) and 3d3_s5 are well established also.
                                            but the signals: 3dv3_s0, pw_slp_s3# and pw_slp_s4 oscillate at the same...
                                            11-22-2025, 03:54 PM
                                          • joaquinmjuan
                                            Canon TS8350 Screen Freezes on Power On
                                            by joaquinmjuan
                                            Hello, I have a Canon TS8350 printer. The problem is that when I turn it on, "CANON" appears on the screen, but it never goes away. You can leave it on for a whole day, and it doesn't go away. Does anyone know how to fix this? I've tried unplugging it, but nothing. I've also tried holding down POWER, but nothing. In fact, once it turns on, it can't be turned off with the Power button. I've also held down Power and then plugged it into the Power supply, and the power light flashes once and doesn't turn on, but then when I press Power again, it turns on. Currently, it's a nearly new paperweight,...
                                            05-07-2025, 12:26 AM
                                          • Alicat
                                            Panasonic Plasma TH-50PZ85U No screen No blinks on red power light
                                            by Alicat
                                            Stopped by this site trying to fix my parents Panasonic Plasma TV.
                                            Model number is TH-50PZ85U
                                            Power comes on and the red power light stays on solid.
                                            Did a few checks like hold the power button on for 60 seconds, hold the - Volume while holding the menu button, no luck, still@ blank grey screen as the screen lights up very vague.
                                            I also hear a few clicks.
                                            I also think my parents said there was a thunderstorm and the TV failed after that.
                                            Section 6 in the service manual talks about power and no screen,...
                                            10-30-2024, 10:09 AM
