HANNSPREE HF289H Black Screen No Power
  • RonBhay
    • Jan 2016
    Re: HANNSPREE HF289H Black Screen No Power
    I too have the same problem with my monitor, will try replacing the caps. I was also thinking of replacing the CFL lamps with LED strips. My question is can I discard the high voltage inverter board? Many thanks in advance . .
    • PantherDave
      by PantherDave
      Hi all!
      05-29-2024, 02:01 PM
    • grimacelord
      HP 15-EH1070wm - Black Screen With Power LED.
      by grimacelord
      I have an HP 15-eh1070wm laptop that came to me for the same reasons I am starting this thread. The charging LED appears when the laptop power adapter is connected and the power LED appears when pressing the power button, but nothing appears on screen.
      First thing I did was take off the bottom panel and remove the battery and then press and hold the power button for 30 seconds and then reinstall the battery and power on. The fan spins and this time, the back light illuminates and a brief message appears on the screen for about 1 second saying something along like,...
      01-28-2023, 10:50 AM
    • jean luc ferre
      acer aspire v5 571p touching screen cracked led blue of power indicator blinks 1s lighted 3s off.
      by jean luc ferre
      on this laptop acer aspire v571p the led of the power indicator blinks blue for periods of 1s lighted and 3s off after switch on and this indefinitely.
      i tried the hard reset, cmos reset, changing the ram without results.
      in order to reach the cmos battery i disassembled the laptop and did several mesures with my multimeter.
      The 19v, 5v, 3v are well established after the chip 5v-3v. the following signals : 3d3v_aux_kbc (which supplies the sio chip) and 3d3_s5 are well established also.
      but the signals: 3dv3_s0, pw_slp_s3# and pw_slp_s4 oscillate at the same...
      11-22-2025, 03:54 PM
    • joaquinmjuan
      Canon TS8350 Screen Freezes on Power On
      by joaquinmjuan
      Hello, I have a Canon TS8350 printer. The problem is that when I turn it on, "CANON" appears on the screen, but it never goes away. You can leave it on for a whole day, and it doesn't go away. Does anyone know how to fix this? I've tried unplugging it, but nothing. I've also tried holding down POWER, but nothing. In fact, once it turns on, it can't be turned off with the Power button. I've also held down Power and then plugged it into the Power supply, and the power light flashes once and doesn't turn on, but then when I press Power again, it turns on. Currently, it's a nearly new paperweight,...
      05-07-2025, 12:26 AM
    • Alicat
      Panasonic Plasma TH-50PZ85U No screen No blinks on red power light
      by Alicat
      Stopped by this site trying to fix my parents Panasonic Plasma TV.
      Model number is TH-50PZ85U
      Power comes on and the red power light stays on solid.
      Did a few checks like hold the power button on for 60 seconds, hold the - Volume while holding the menu button, no luck, still@ blank grey screen as the screen lights up very vague.
      I also hear a few clicks.
      I also think my parents said there was a thunderstorm and the TV failed after that.
      Section 6 in the service manual talks about power and no screen,...
      10-30-2024, 10:09 AM
