Samsung 940b - classic nod backlight problem
  • bocca
    • Mar 2012
    • 107
    • Serbia
    Re: Samsung 940b - classic nod backlight problem
    Thank you. I will desolder tehm now and measure again.
    Ebay won't ship to serbia in any case, and if someone agrees to do it outside of ebay it's pretty expensive. I'll have to find another way
    • retiredcaps
      • Apr 2010
      • 9271
      Take a copy of the 4502C datasheet to your local electronics store and maybe you can find an equivalent part?
      --- begin sig file ---
      --- end sig file ---
      • Jasgriff
        • Feb 2012
        • 578
        http://www.digikey.rs/rs/en/digihome.html
        $120 fixed rate shipping to Serbia? lol
        Fixed so far : 1 Home cinema system, 16 LCD Monitors, 4 LCD TV's
        How to resize your pictures guide click HERE
        Retiredcaps Ideal post example click HERE
        • bocca
          • Mar 2012
          • 107
          • Serbia
          ugh, there's not an easy way to desolder these is there? :-\
          @jasgriff: yeah, that's what i'm talking about. And if you order something chances are it's gonna "get lost" in the customs. Most of the things I ordered never arrived...
          • Jasgriff
            • Feb 2012
            • 578
            Are you trying to remove the 8 pin chip?
            • bocca
              • Mar 2012
              • 107
              • Serbia
              #26
              That's right. One problem is, the soldering wick can't be found here anywhere. (Most never heard of the stuff). Is there any way to do it without it?
              • Jasgriff
                • Feb 2012
                • 578
                Even if you did have solder wick you would probably find that it wouldn't get all of the solder off and risk you lifting a pad as you attempt to pull it off.
                  I use stainless steel razor blade or eXACTO blade inserting under the melted soldeer IC pin of the IC to separate the pin from the pad if you have no other tools to do it with, just take your time doing it. Main key is that you should have 40watts soldering Iron so the tip can maintain the temperature without heating up the traces and damage the trace, most people using 25~3watts iron which does not have enough heat capacity to maintain the temprature.
                  • bocca
                    • Mar 2012
                    • 107
                    • Serbia
                    #29
                    I do have powerful enough iron, and that razorblade trick is pretty neat. I'll try it asap
                    • bocca
                      • Mar 2012
                      • 107
                      • Serbia
                      #30
                      Two of the 8 legs came off along with all the solder on the board. I guess that can't be that easily fixed...
                      • Jasgriff
                        • Feb 2012
                        • 578
                        Can you show us a picture of what's happened?
                        • bocca
                          • Mar 2012
                          • 107
                          • Serbia
                          #32
                          sure can
                          here's a photo. i believe you'll destinguish my messup
                          • Jasgriff
                            • Feb 2012
                            • 578
                            sure can
                            Its not that bad of a mess! these things happen.
                            I'm pretty sure you can get away with patching the Pins with the missing pads to the next nearest connection.
                            The board looks clean what did you use?
                            • bocca
                              • Mar 2012
                              • 107
                              • Serbia
                              #34
                              good, so there is still some hope
                              You will have to guide me on that nearest connection business, as I'm not sure I quite got it.
                              Clean in what sense? General cleanliness or soldering stuff? Thnx, by the way
                              • retiredcaps
                                • Apr 2010
                                • 9271
                                #35
                                Basically you have to figure out where those pads connect to in the circuit. If you look at the datasheet the two solder pads you lifted are either pins 6 and 7 or pins 2 and 3. I can't tell from the photo and regulars will notice that in one thread yesterday, I can't tell north from south in a diagram.
                                If there is any solder pad left, then you may be able to use the continuity beep on your multimeter to find out where the pads connect to. Then you can use some wire to bridge the connection.
                                Something like this ...
                                http://www.circuitrework.com/guides/6-1.shtml
                                • Jasgriff
                                  • Feb 2012
                                  • 578
                                  That site offers some fantastic examples of patching. Much better than my response P.s Never Eat Shredded Wheat N-E-S-W.
                                  • bocca
                                    • Mar 2012
                                    • 107
                                    • Serbia
                                    #37
                                    Wow, thanks retiredcaps
                                    I will do what you both proposed, and try to look for a place to bridge the connection
                                    • cpp
                                      • 9
                                      #38
                                      you can desolder this little mosfets (8pin smd) with a little pliers.
                                      take the ic whit the pliers and add solder to four legs on both sides,then pull up
                                      you must add heat on both sides quickly 2 or 3 times.
                                      just repaired one samsung syncmaster 153v , whit 2 of 4 AO4600 mosfet shorted,due to dry capacitors.
                                      My soldering iron is a "JBC" 25W, whit soldering tip slightly curved.
                                      sorry for my english,hahaha, i use google translator sometimes..
                                      • Behemot
                                        • 4845
                                        • CZ
                                        #39
                                        Both mosfets above are bad. Desolder both and retest S2-G2 out of circuit to verify that read around 1.0 ohms. If still shorted, then replacements are available on ebay. 8 for $4.80 + free shipping.
                                        Exactly my problem, thanks bro
                                        Nah, exactly the right transistors are in one shop here but I don't like the price, worth $4 a piece. Pretty expensive, it will barely make any money when display sold after repair…
                                        EDIT// found a thread here on slovakian forums, a guy replaced them with IRF7389. They are third the price and actually on local stock. Slightly worse current parameters, but who gives a shit, there will be less than 0,3 A of current running through both of them…(rating of the backlight is 650 V/7,5 mA which equals to less than 5 W).
                                        • Behemot
                                          • 4845
                                          • CZ
                                          #40
                                          Bocca please what is the resistance of R316 resistor? It is next to the 33uF C345 cap on the upper side. I have slightly burned it due to short between S1 and G2
                                          • fanaticgames
                                            Samsung UE32D4010 Backlight problem, led ok
                                            by fanaticgames
                                            hello I have a backlight problem on this TV, if I unplug the cn201 cable the backlight works perfectly and the voltages are 13v if I connect the cn201 cable the backlight goes off and the voltage drops to 12v, I assume it's a motherboard problem, the question is has anyone had a similar problem? I want to understand if the motherboard is repairable or it's not worth wasting time...
                                            02-22-2023, 09:46 AM
                                            09-07-2024, 05:50 AM
                                          • sandinemail@hotmail.com
                                            Samsung BN44-00284A Backlight problem
                                            by sandinemail@hotmail.com
                                            Samsung BN44-00284A in a Samsung LE40B755 TV bought 2009.
                                            In November 2020 the TV didn´t turn on only flashing red diod on front off TV.
                                            I then opened up the TV and found bulged capacitors on the inverter/powerboard.
                                            I changed all capacitors except the main two 450V 100uf capacitors.
                                            The TV has worked pefectly since.
                                            But this week it started to turn off the backlight. Audio on TV still works.
                                            Sometimes it turn off the backlight after 10 seconds but sometimes it works for hours.
                                            Any suggestions on what might...
                                            02-15-2023, 05:10 AM
                                          • sansanpartida
                                            Samsung QE82Q70RAT no backlight
                                            by sansanpartida
                                            Hi everyone!
                                            Hope you're all having a great day, and thank you very much for stopping by and taking the time to read this post to help me with my parents' Samsung TV.
                                            My issue: No backlight.
                                            Model: QE82Q70RAT
                                            Type No: QE82Q70RAT
                                            The TV was already serviced by Samsung once under warranty for the exact same issue, but six months after the fix, the backlight went out again. Now, Samsung is asking for nearly the same price as a brand new TV to fix this with the same 6-month guarantee.
                                            So hopefully, I can fix this cheaper.
                                            05-22-2024, 06:56 AM
                                          • howardc64
                                            Samsung UN55NU7300F Curved TV. Half side backlight out. Fixed by just removing the rear snap cover
                                            by howardc64
                                            TV was fixed just after removing Samsung's rear snap cover.
                                            This curved TV's construction is rather interesting. When the snapped on back is removed, rest of the TV will relax the curvature. Top of LCD panel is loose as it wants to straighten out against the slightly curved bezel. Snapped back provide most of the curvature shape. So just simple disassembly of rear cover will allow the rest of the TV frame to relax its curvature. Thats probably what fixed it but no idea which connection. 4x LEDs are edge lit.
                                            Maybe PSU->backlight connector didn't have a good contact?...
                                            Yesterday, 12:34 AM
