Samsung BN44-00284A Backlight problem
  • sandinemail@hotmail.com
    • Feb 2023
    • 15
    • Sweden
    Samsung BN44-00284A in a Samsung LE40B755 TV bought 2009.
    In November 2020 the TV didn´t turn on only flashing red diod on front off TV.
    I then opened up the TV and found bulged capacitors on the inverter/powerboard.
    I changed all capacitors except the main two 450V 100uf capacitors.
    The TV has worked pefectly since.
    But this week it started to turn off the backlight. Audio on TV still works.
    Sometimes it turn off the backlight after 10 seconds but sometimes it works for hours.
    Any suggestions on what might be wrong and how to fix it?
  • nomoresonys
    • 12223
    • U.S.
    Re: Samsung BN44-00284A Backlight problem
    check over all solder joints, specially those components on heatsinks, and the transformer legs, reflow any that look suspect, careful not to bride any joints that shouldn't be with solder and recheck your solder work on caps, one might have been not too good, Another test, maybe when it's acting up heat up your electrolytic caps with a hairdryer for a couple minutes, see if it comes on any better, if only for a bit.
      • Feb 2023
      • 15
      • Sweden
      Have already resoldered all transformer and mosfet legs.
        • Feb 2023
        • 15
        • Sweden
        If I turn up backlight settings to 10 it immediately turns off backlight.
        • nomoresonys
          • 12223
          • U.S.
          what does it do with them turned way down?
            • Feb 2023
            • 15
            • Sweden
            Sometimes it works for a couple of hours sometimes for a couple of minutes.
            • nomoresonys
              • 12223
              • U.S.
              I might suspect one of the backlight transformers or possibly bad ccfl or connection in that circuit.
                • Feb 2023
                • 15
                • Sweden
                Ok
                Not main capacitors 450V 100uf?
                Couldn’t find any schematics of the inverter/powerboard.
                • vinceroger69
                  • Mar 2012
                  • 6714
                  • uk
                  my guess is a failing ccfl tube
                  • nomoresonys
                    • 12223
                    • U.S.
                    maybe ohm check those transformers, they should be very close to each other in reading.
                    • nomoresonys
                      • 12223
                      • U.S.
                      well it could be those big caps, you have a way to test them? can ohm test them, dirty test is put meter on 20k ohm or maybe higher and test them, they should go up or down steady, reverse probes should be steady climb or decrease, not terribly accurate test but can give a clue at times.
                        • Feb 2023
                        • 15
                        • Sweden
                        Resolder the caps first?
                        • nomoresonys
                          • 12223
                          • U.S.
                          ohm testing done with tv UNPLUGGED from power, for those looking on that might not know.
                            • Feb 2023
                            • 15
                            • Sweden
                            How to test ccfl tube?
                            • nomoresonys
                              • 12223
                              • U.S.
                              sure, if they look bad or suspect.
                              • nomoresonys
                                • 12223
                                • U.S.
                                the ohm test is easy enough, done with caps in place, no need to take out for that.
                                  • Feb 2023
                                  • 15
                                  • Sweden
                                  Measured with 6Mohm on multimeter.
                                  Goes up steady. Reverse goes down slowly.
                                  Capacitor measurement shows 190uf
                                  • nomoresonys
                                    • 12223
                                    • U.S.
                                    could be similar to this problem: https://www.youtube.com/watch?v=PflyJ4H51Fg
                                    • nomoresonys
                                      • 12223
                                      • U.S.
                                      so thats probably the total uf of both then.
                                      • nomoresonys
                                        • 12223
                                        • U.S.
                                        • fanaticgames
                                          Samsung UE32D4010 Backlight problem, led ok
                                          by fanaticgames
                                          hello I have a backlight problem on this TV, if I unplug the cn201 cable the backlight works perfectly and the voltages are 13v if I connect the cn201 cable the backlight goes off and the voltage drops to 12v, I assume it's a motherboard problem, the question is has anyone had a similar problem? I want to understand if the motherboard is repairable or it's not worth wasting time...
                                          02-22-2023, 09:46 AM
                                          09-07-2024, 05:50 AM
                                        • sansanpartida
                                          Samsung QE82Q70RAT no backlight
                                          by sansanpartida
                                          Hi everyone!
                                          Hope you're all having a great day, and thank you very much for stopping by and taking the time to read this post to help me with my parents' Samsung TV.
                                          My issue: No backlight.
                                          Model: QE82Q70RAT
                                          Type No: QE82Q70RAT
                                          The TV was already serviced by Samsung once under warranty for the exact same issue, but six months after the fix, the backlight went out again. Now, Samsung is asking for nearly the same price as a brand new TV to fix this with the same 6-month guarantee.
                                          So hopefully, I can fix this cheaper.
                                          05-22-2024, 06:56 AM
                                        • howardc64
                                          Samsung UN55NU7300F Curved TV. Half side backlight out. Fixed by just removing the rear snap cover
                                          by howardc64
                                          TV was fixed just after removing Samsung's rear snap cover.
                                          This curved TV's construction is rather interesting. When the snapped on back is removed, rest of the TV will relax the curvature. Top of LCD panel is loose as it wants to straighten out against the slightly curved bezel. Snapped back provide most of the curvature shape. So just simple disassembly of rear cover will allow the rest of the TV frame to relax its curvature. Thats probably what fixed it but no idea which connection. 4x LEDs are edge lit.
                                          Maybe PSU->backlight connector didn't have a good contact?...
                                          07-23-2025, 12:34 AM
                                        • howardc64
                                          Samsung QN75Q6FNA backlight no display, red LED blink 2x, fault in panel
                                          by howardc64
                                          • Prior owner tried a replacement main board. No difference.
                                          • Samsung 2x red blinking standby LED = panel fault
                                          • Jumpered FB_TRDY_1 (pin 1 CN1300 left. main tcon->left side buffer boards) and FB_TRDY_3 (pin 95 CN1301 right. main tcon->right side buffer boards) This allows testing individual T-Con (on main board) connection to panel on this Samsung. Found fault on left side (viewing from rear of TV)
                                          • Each side has 2 buffer boards, disconnected left side flex between 2 buffer boards. Fault is on the left most board.
                                          • Tape masking eventually isolated to CN1300 pin 15 (CKV4_GOA) Display
                                          07-19-2025, 10:54 PM
