Samsung SyncMaster B2330 Black screen
+ More Options
Posts
  • tama4tama
    • Nov 2006
    • 56
    Dear friends,
    This monitor came in this morning with no power. This is Samsung SyncMaster B2330; I have checked the fuse and others things all look fine no bad capacitors.
    I have checked the voltage going to the signal card CN802 but all comes out 0.00V that show that there is voltage going there. The IC871 and F911S all are fine.
    Please help me on this one?
    I appreciate all your kind help.
    Thanks.
    Tama
  • PlainBill
    • Feb 2009
    • 7034
    Re: Samsung SyncMaster B2330 Black screen
    Originally posted by tama4tama
    Dear friends,
    Thanks.
    Tama
    First of all, while the pictures are fairly good, there is one mistake that makes things more difficult than necessary. This board has a strong orientation -when the CCFL connectors are toward the top of the picture the component identifiers are all right side up. While I can read upside-down, it's not something I prefer to do.
    Now onto the real problem.
    1. What is the voltage across the large cap?
    2. There is a large heat sink at the top of the picture. The IC on that heat sink is the SMPS controller. What is the part number?
    PlainBill
    • tama4tama
      • Nov 2006
      • 56
      PlainBill, I am very sorry for that picture which was upside-down.
      The voltage across the large capacitor is 321.9V
      The IC has this part number DA 29CK and GMO 565R
      Tama
      • selldoor
        Slow Learner
        • 7870
        How old is this monitor Samsung monitors have a 3 year warranty?
        http://www.samsung.com/africa_en/sup...OLICY.WARRANTY
        • tama4tama
          • Nov 2006
          • 56
          Just less done a year.
          • PlainBill
            • Feb 2009
            • 7034
            Tama
            That voltage is good. Unfortunately I can't find any reference to the part numbers of the SMPS controller.
            PlainBill
            • selldoor
              Slow Learner
              • 7870
              Could it be DMO565R
              http://www.scribd.com/doc/38843138/Datasheet-DMO565R
              NO PROBABLY NOT SEE NEXT POST
              • selldoor
                Slow Learner
                • 7870
                Think it is this? its a zero not an oh
                http://www.fairchildsemi.com/pf/FS/FSGM0565R.html
                • retiredcaps
                  • Apr 2010
                  • 9271
                  This post below doesn't help out the OP, but speaking of mixing up "0" and "O" ...
                  https://www.badcaps.net/forum/showthread.php?p=213475
                  --- begin sig file ---
                  --- end sig file ---
                  • retiredcaps
                    • Apr 2010
                    • 9271
                    Now for some real technical help.
                    Pin 3 is Vcc. Pin 2 is GND.
                    According to the datasheet, when Vcc reaches 12V DC, it will start. What DC voltage reading do you get on pin 3 (with pin 2 for ground)?
                    • tama4tama
                      • Nov 2006
                      • 56
                      Thank you, PlainBill, Selldoor and Retiredcaps, I am sending the picture of the IC
                      tama
                      • PlainBill
                        • Feb 2009
                        • 7034
                        To add a little bit to retiredcaps post, using pin 2 of the IC as ground, CAREFULLY measure the voltages on pins 3 and 6. Pin 3 is Vcc, pin 6 is the source for the startup voltage. the pins are numbered 1 - 6 from left to right,
                        PlainBill
                        • tama4tama
                          • Nov 2006
                          • 56
                          These are voltages I got on pins 3, was 238v and 6, and was 230v. Is that correct?
                          Tama
                          • PlainBill
                            • Feb 2009
                            • 7034
                            Tama
                            Those numbers don't look right. Verify the voltage on pin 3. I've attached a picture.
                            PlainBill
                            • retiredcaps
                              • Apr 2010
                              • 9271
                              If pin 3 was really 238V DC, that would be one cripsy chip.
                              Pin 3 maximum is 26V.
                              • tama4tama
                                • Nov 2006
                                • 56
                                I have done the measuring all over again and it seem that the IC is bad with according to the datasheet , this morning It read 5.9v on the pin 3 and pin 6 was generating high voltage.
                                Tama
                                • PlainBill
                                  • Feb 2009
                                  • 7034
                                  Tama
                                  It's probably a translation problem, but there is one slight error in that statement. The IC receives high voltage on pin 6, and is supposed to reduce it to about 12-20 volts for Vcc.
                                  The failure of Vcc to rise to the start voltage is is a common failure mode, replace the FSGM0565R. You may have to use the earlier version, it can be found on eBay as DM0565R
                                  PlainBill
                                  • tama4tama
                                    • Nov 2006
                                    • 56
                                    Thank you all for your help to see that this monitor came back to life. As soon as I get part and fix it, I will let you known the out came.
                                    Tama
                                    • VaNDAL_UK
                                      • Aug 2010
                                      • 77
                                      • United Kingdom
                                      Any news on the out come?
                                      I'm picking up one of these monitors on Monday repoted as no power issue.
                                      • malexry
                                        • Mar 2015
                                        • 20
                                        • america
                                        I have the same b2330 as you, and I have uploaded pictures of the circuit board. 2 days ago it went out randomly and when I turn on the monitor it makes a hissing sound and then shuts off after about 2 seconds. I have no blown capacitors and I do not really know much about circuitry and such but if anyone can help me with this problem that would be great! also one more thing to throw everyone off, like 1 out of 200 tries the monitor will actualy stay on! the pixels always are on it is the black light that stays on 1/200 times. why I have no idea! but if I turn it on and off for like 30 mins the monitor will work completely fine until I turn it off, it goes to sleep, ect. so if anyone can figure this one out id be happy! also the monitor is significantly dimmer than my other monitors and that might have something to do with it as well.
                                        ps: when I say the monitor "shuts off" or "goes out" its the back light, I did the flashlight test and I saw the image on the monitor BEARLY! but I did see them.
                                        also sorry for bump, I just really need this solved
                                        • aazjo
                                          A1502 screen only issues
                                          by aazjo
                                          I have a MBP A1502 (early 2015, 820-4924) with a screen that will not turn on. I have swapped screens with a cracked test screen and the computer boots and the cracked screen works for both backlight and image. The black/blank screen appears to do nothing.
                                          I have collected resistant data from the cracked screen connector pins and submitted to OBData server:
                                          1 PPVOUT_SO_LCDBKLT OL
                                          3 I2C_BKLT_SCL 9.97M
                                          4 I2C_BKLT_SDA 9.89M
                                          5 PP3V3_S0_EDP_R 79.10k
                                          6 SMBUS_SMC_0_S0_SCL 321k
                                          7 SMBUS_SMC_0_S0_SDA 323k
                                          8 EDP_BKLT_PWM ...
                                          11-04-2021, 11:46 PM
                                        • maxim2511
                                          LG 55EC930V OLED - swich on swich of no screen
                                          by maxim2511
                                          My Oled Tv is 55inch tv, 3 days ago I notice that middle of the screen is getting warmer and on picture I have ghosting, missing red color. Color red was still displaying, but it was not so strong as corners of the screen and watching some movies makes me angry.
                                          Then I get an idea to take it apart and clean boards from dust.
                                          In side of Tv was not so bad, I take compressed air in can, and gently blow up.
                                          Also I was thinking to styrofoam sponge to isolate power board from screen that the middle of the screen will not worm so much. Because Led on screen when gets higher...
                                          05-14-2021, 02:21 AM
                                        • kino0924
                                          Screen Replacement for A2337
                                          by kino0924
                                          I have a 2020 macbook air m1 that needs a screen replacement (cracked)
                                          Right now, I have few options but not sure what to take
                                          1. Screen only from aliexpress (80 USD)
                                          2. Housing and screen from aliexpress (144 USD)
                                          3. Genuine used screen from ebay (250 USD ish)
                                          4. New screen from ifixit (450 USD)
                                          To be honest, I dont think new screen from ifixit is worth it since I can get it replaced by apple with same amount of price (haha)
                                          Now, I am wondering is it really worth to spend 100 more on used genuine screen....
                                          01-19-2023, 02:02 PM
                                        • dicky96
                                          HP Elitebook Screen blank - backlights but no image
                                          by dicky96
                                          Hi guys
                                          I'm trying to fix this laptop screen
                                          Basically the owner is a computer shop and they brought it to me with two screens. They said the repair shop they use could not fix it, so I thought i would try to see if I am better than their current repairer!
                                          OK so I have the original screen which works but has lines across the bottom quarter of the screen
                                          I have the replacement screen, which they fitted and it worked. They then put the laptop on one side for a couple of weeks until they found a buyer. When they showed it to the buyer, the screen would...
                                          04-28-2021, 07:30 AM
                                        • Yehuda170
                                          ThinkPad P15s Gen 1, NM-C931 REV 1.0 touch screen replaced only works in UEFI menu
                                          by Yehuda170
                                          original screen was BOE NV156FHM-T07 with On-Cell Touch screen I²C
                                          replaced with what was in my stock, which is IVO R156NWF7 R2 which is also with On-Cell Touch screen I²C
                                          now touch screen works perfectly in UEFI BIOS menu & boot menu. but not working in OS, tried windows & linux too
                                          with original broken screen i can see in device manager touch screen in human interfaces
                                          but with the new screen it's not showing in device manager
                                          is it lenovo blocking it? is it driver missing?
                                          I²C is a headache
                                          07-14-2023, 01:29 AM
