Samsung SyncMaster B2330 Black screen
  • malexry
    • Mar 2015
    • 20
    • america
    #41
    Re: Samsung SyncMaster B2330 Black screen
    Is their anyway I can run the monitor before buying the CCFLs? it has 2 of the 4 still in it functioning and I would like to confirm that that was the only problem before I spend 40 dollars on new bulbs.
      You can make two test lamps so it will keep the Inverter circuit from shutting down.
      https://www.badcaps.net/forum/showthread.php?t=19987
      • malexry
        • Mar 2015
        • 20
        • america
        #43
        that is problematic, they were actually cracked when I took them out... is their any other way that I can power on the monitor? any at all?
        • Lumberjack777
          • Dec 2010
          • 464
          #44
          Yes, there is. At the electronics recycle center where I volunteer; we sometimes get a decent monitor with bad bulbs. But it would be too costly, and time consuming to repair. So we grab an extra set of ccfl's about the same length and plug them into the inverter where the bad ccfl's are. This prevents the protection circuit from shutting the monitor down. And it's still safe to operate. Then we duct tape the ccfl's to the lcd panel. This means the lcd monitor will now be running on just those 2 good ccfl's inside. And that's often still plenty bright enough. We tell a buyer that it only has 2 bulbs lighting inside, and give them a discount. You could probably find cheap used ccfl's at your local lcd/tv/electronics recycle center.
          • malexry
            • Mar 2015
            • 20
            • america
            #45
            Thank you both budm and lumberjack and anyone else who helped! ordered 2 ccfl assemblies for 11bucks (from hongkong :/) should be here hopefully within the month.. then we will see if it has worker or not! thanks again!
            • malexry
              • Mar 2015
              • 20
              • america
              #46
              one little problem now, the monitor was clicking and making a weird noise and then this happened. is the monitor trash now? I feel like it is but maybe their is a simple fix. The ribbon cables off the motherboard post ccfl installation, it was making a weird noise that was rapid clicking and the screen had changing lines of color so I took it apart again and these ribbons came disconnected the contacts are smaller than a hairs with... idk what I should do now.. picture is posted
              • malexry
                • Mar 2015
                • 20
                • america
                #47
                Any Ideas? sorry again for the bump but I didn't think I should open a new thread because I already started the other portion on this thread
                • Chrissygizmo
                  by Chrissygizmo
                  02-10-2025, 12:33 AM
                • Chrissygizmo
                  samsung galaxy ao2s very temperamental after screen replaced
                  by Chrissygizmo
                  Hi , I've recently replaced the screen in my Samsung galaxy ao2s, at first it wouldn't even turn on, it had the charging symbol on the screen when plugged in but the green circle wasn't going around to show it charging....
                  Ive eventually managed to get it on and working but it's very temperamental...
                  The battery icon always reads as 50% , when the phone goes into lock screen mode i sometimes can't get the screen back on unless I plug the charger in to get it to light up, also it keeps putting the camera app on.. u think it could be something to do with the side buttons. ...
                  05-26-2024, 12:05 AM
                • Kiberge
                  Samsung LH82QENELGC/EN Help needed - Static line on screen
                  by Kiberge
                  HI guys!
                  I've got a Samsung LH82QENELGC/EN with a problem and need some advice and I hope this is the forum to use?
                  I'm from Norway so I'd like to apology in advance if my description of the fault is kind of simple or the names on the components are way off. 😊
                  the TV is powering up, working as normally and picture is all good, except a 1.5-inch-wide vertical line of snow/static across the screen.
                  This TV is a Signage Display/Public Display version and it's been used at my work for 4-5 years showing commercials 24/7. The fault occurred when...
                  04-22-2024, 11:28 AM
                • Ryan.man
                  by Ryan.man
                  02-04-2025, 12:23 PM
                • arbitarytwist
                  Samsung UN50NU7400 - No Picture (but boot screen and screensaver)
                  by arbitarytwist
                  Have a Samsung UN50NU7400 which shows a boot screen and a screen saver if left on long enough but no picture ?
                  Would a moving screen saver confirm that the panel is ok or it could still be a panel issue ?
                  03-01-2025, 01:16 PM
