LG W2234S Repair Help...
  • alf_red007
    • Nov 2010
    • 4
    #61
    Re: LG W2234S Repair Help...
    i think its a transistor or high voltage transformer failure
    • PlainBill
      • Feb 2009
      • 7034
      On the logic board?
      PlainBill
      • docksteaderluke
        • Jul 2011
        • 39
        #63
        Found one from ebay that HAS been programmed... How does this look?
        http://www.ebay.ca/itm/MX25L1005MC-F...#ht_1580wt_907
        • PlainBill
          • Feb 2009
          • 7034
          That should do it. They describe the precise symptoms, and have 100% positive feedback.
          PlainBill
          • pattontj
            • Oct 2011
            #65
            Plainbill, just wondering how you made out with this issue. I have a friend who has the exact same monitor, and his symptoms are almost identical to yours. The monitor turns on, LED goes blue, the LG Logo comes up, then it all goes black after about 2 seconds, and repeats. However, in this case, it only seems to do it after the computer goes to sleep, or if you try to change the resolution. If that happens, the computer needs to be powered off, then the monitor powered off, then turn on the computer and wait for it to get into Windows, THEN power on the monitor.
            Works as a workaround for now, but it's probably only a matter of time before the monitor completely dies as yours has. Let us know :-)
            Tim
            • docksteaderluke
              • Jul 2011
              • 39
              #66
              Hey Tim,
              I'm still waiting on the part (shipping from China is SLOW). It should be here within the next 2 or 3 days. As soon as I try it out I'll post back here to let everyone know if it worked.
              • docksteaderluke
                • Jul 2011
                • 39
                #67
                Hey guys...
                Sorry for the late reply, but I finally got the part (MX25L1005MC with firmware) and replaced it tonight and the monitor works like a charm !
                Thanks for all of your help. I hope this solutions helps you out Tim (and all others who have a similar issue).
                • retiredcaps
                  • Apr 2010
                  • 9271
                  #68
                  I picked up this monitor a while back, but didn't get around to it until I got some decent tools.
                  I can verify the above seller, monitor-09, ships a chip with the flash programmed in it as I just did the same repair. The menus are in Chinese so you will have to fiddle around with the OSD menu settings until you see English.
                  Beware of another ebay seller that sells the "same programmed" chip for about 1/2 the price. I bought it and it didn't work and then I found out I bought a blank chip even though their ad clearly states it is programmed with the firmware. I pointed this out, but their ad still says it comes pre-programmed. I got a refund, but I put my logic board at risk unnecessarily (see below).
                  For removing the old SMD IC, I used a non temperature control hot air gun and protected all the surrounding areas with Kapton tape. It only took about 30 seconds to remove the old one. I also used lots of flux to help solder in the new IC.
                  My first SMD chip repair!!!
                  The monitor is now under going real world tests.
                  PS. This monitor has no screws holding the metal cage to the plastic and the lvds cable is super short so be careful taking it apart.
                  --- begin sig file ---
                  --- end sig file ---
                  • retiredcaps
                    • Apr 2010
                    • 9271
                    #69
                    I forgot to add that my particular monitor does NOT automatically discharge the large filter capacitor. The cap still held 165V DC overnight and I had to discharge it with a 100K ohm resistor.
                    Normally, there is a bleeder resistor and maybe mine doesn't have one or it is not working? Anyway, my lcd is all put together and I have no plans to take it apart again.
                    • senndogg
                      • Dec 2011
                      • 383
                      • Albania
                      #70
                      Hello people,
                      its been a month i dont enter the forum because of an internet malfunction, and now lets get down to business, seriously!
                      this LG i have was completely dead. no signs of life.
                      measured the voltages. 5V ok. tested with a 2W lamp, ok, no voltage drop.
                      measured the regulators in the main board. 3.3V ok, 1.8V ok.
                      measured the voltage in the power button. 3.3V.
                      at this point i searched THIS forum and heard about the firmware problem.
                      as i dont have much time for the chip to be shipped from china, i found the FW online, and i want to share it with you.
                      went to a friend of mines, who has a ELNEC programmer, and the procedure was routine for him. it took 5 minutes to unsolder it, to test-read it (found it was corrupted), to rewrite the .bin file, and to solder it back.
                      its working great!
                      thank you guys and i am pleased to help!
                      • retiredcaps
                        • Apr 2010
                        • 9271
                        #71
                        Originally posted by senndogg
                        its working great!
                        How do you find the picture quality? Normally, I'm not picky about picture quality, but my W2234S is noticeably worse than most even after adjustments including a complete factory reset. The constrast is particularly poor.
                        • senndogg
                          • Dec 2011
                          • 383
                          • Albania
                          #72
                          hi retiredcaps, i didnt notice anything strange after the ROM flashing, the monitor just came back to life. i havent used it before, since it wasnt mine, but the owner said everything was ok. we tested it for several hours and i even liked the picture quality of the cheap Innolux panel
                          it seems strange to be software related, but if you are able to flash it to the ROM i have posted, you should try!
                          • brokenboy
                            • Nov 2010
                            • Spain
                            #73
                            Hi, same symptoms that docksteaderluke, flash eprom mx25l1005 reprogrmmed with this
                            file http://dump.elektroda.pl/download12145.html, and working without problems.
                            Thanks to all.
                            • mothballstocks
                              • Oct 2012
                              • saudi arabia
                              #74
                              oh this prob was a year ago... any luck?
                              • jbn907
                                • May 2013
                                • India
                                #75
                                I need the datasheet of MP1008es ,i have only the problem of back light .it turn off immediately, if i disconnect the protection ckt it lights up the feedback voltage at pin 2 is very low,diodes and capacitors are found good chnged the lamps but problem exixit dou have any idea
                                • fall
                                  • Oct 2013
                                  • Lithuania
                                  #76
                                  w2234s-bn my monitor goes white after ~10mins or goes completely off or goes white and then off(no power led) (then you need to unplug power cable and plug it back on(after ~3times) then it starts to work again but after ~5mins it goes white or completely off , and on native resolution there is flickering dots all over , small lines flicering into the right side of my monitor if i click power button a couple of times the image will be normal no flickering, and i have MX25L1005MC with blue dot on it , if i take that part where the d-sub cable goes to repair will it solve my prob by replacing that little chip ( MX25L1005MC ) or its more behind this like power supply is it worth to fix it?
                                  • krisztian_andre
                                    • Jul 2014
                                    • 5
                                    Hello, I'm trying to program my w2234s' flash chip in circuit with this software http://sourceforge.net/projects/ch341eepromtool/ and this programmer: http://cgi.ebay.ca/ws/eBayISAPI.dll?...m=171122644445 . In your attached file I aussume w2234.cat is the image file. What is the icc file for? Where did you find this image?
                                    Hello people,
                                    its working great!
                                    • krisztian_andre
                                      • Jul 2014
                                      • 5
                                      I should have opened those files, they are windows drivers ofc. Here's a link to the firmware: http://elektrotanya.com/lg_w2234s_du.../download.html
                                      • krisztian_andre
                                        • Jul 2014
                                        • 5
                                        The file I downloaded is around 512 kB but the chip is a 128kB part, where can I find the proper firmware?
                                        • krisztian_andre
                                          • Jul 2014
                                          • 5
                                          I'm having a nice conversation with myself here, but here's a 128kB file I found: http://www.ebastlirna.cz/modules.php...nload&id=23916
                                          • taslan
                                            Surface 7 Pro wont boot, shows Logo and immediately turns off
                                            by taslan
                                            as stated in the title, my surface 7 pro wont boot anymore.
                                            When i press the power button it shows the square windows logo for a second and immediately turtns off again.
                                            I dont even have a chance to get into bios or boot from usb.
                                            While trying to find help online it was suggested to look for help/repair here on badcaps and it might be a ME Region corruption in bios.
                                            I dont know what that is exactly, but i never tinkered with the bios or windows in terms of hacking/patching etc.
                                            Bought it directly from microsoft and used it now and then and only...
                                            01-16-2025, 01:25 AM
                                          • Super360
                                            Vizio E701i-A3 Vizio logo flashing then turns off
                                            by Super360
                                            Ok so here's the story. I was watching tv one day when all of a sudden I heard a pop from the back of the tv set and rushed to unplug the set. By this time the tv already had smoke coming out the back. It was not storming or inclement weather that day to cause a power surge to the best of my abilities. When I opened the tv up, I found that the three capacitors on the psu (highlighted in red) were all bulging and looked they had exploded. I replaced all of them right away and when I went to start up the tv after the "fix" it started just showing the flashing vizio logo as soon as power...
                                            07-25-2024, 07:06 PM
                                          • Teban1306
                                            [REQUEST] ThinkPad T14 Gen 1 (20S1) - Custom Boot Logo Modification
                                            by Teban1306
                                            Hello everyone!
                                            I hope this is the right section for this request. I'm looking for help to modify the boot logo on my ThinkPad T14 Gen 1.
                                            System Information:
                                            • Model: Lenovo ThinkPad T14 Gen 1
                                            • Machine Type: 20S1S4E600 (Intel i7 variant)
                                            • Current BIOS: N2XET42W (1.33) - Latest version
                                            • BIOS File: n2xuj25w.exe (12.98 MB) - Downloaded from Lenovo support
                                            What I'm trying to achieve:
                                            Replace the default "LENOVO" boot logo with a custom image during POST.
                                            🔧 What I've tried:
                                            09-14-2025, 11:49 AM
                                          • USmechS
                                            Hisense 65H6570F Logo shows then turns off
                                            by USmechS
                                            Hello everybody,
                                            I had this Hisense TV since November 2019 (Bestbuy Blackfriday special). Couple of nights ago my dad turned it off normally. In the morning it does turn on, shows the Hisense logo, then the LED light flashes and it turns off. It remains in the same state.
                                            Things I have done:
                                            A. Plug it off and on.
                                            B. Plug it off, pushing the power button for up to 2 minutes, plug it in.
                                            C. Contacted the customer service, They sent me a firmware update, with the file name:
                                            upgrade_loader_no_tvcertificate.pkg
                                            The zip file has this...
                                            04-25-2022, 03:06 PM
                                          • ossroy
                                            Vizio M60-C3 powers on, perfect logo, turns off
                                            by ossroy
                                            Vizio M60-C3 powers on, perfect logo, turns off. If you don't touch anything it will repeat this process by itself until it is unplugged. Not the "button board" since I disconnected the cables to the main board and the problem persisted. So I'm fairly positive something is going on with the main board, but want to know if there is a fix for this other than replacing the expensive mainboard, which may eventually have the same problem. Also, heat sink was hot as hell when this all started. Unplugged for a few days and same thing happens.
                                            My kids are getting antsy waiting...
                                            08-03-2022, 08:11 PM
