I got two of these awesome monitors on Craigslist in the winter. Both were not working, but it seems that one just had a loose wire on the power supply board because when I swapped the PSU boards back and forth, that monitor now seems to function fine with either PSU board. The other monitor still has a problem, though, and it’s the same regardless of which PSU board I use (it was like that before I even opened that monitor).
Basically, when I plug power to the broken monitor, it sounds like it tries to start up; at first, I can hear a buzz (the degauss coil coming on), but then I hear a high-pitched screeching (about 1 second in length) followed by a click after which the screeching stops. The monitor then tries to power on again and the above scenario repeats (relay clicks, screeching noise, relay clicks again and screeching stops).
With the back of the monitor and the top shield removed, I can clearly see spark gap SG901 begins to conduct when the monitor tries to power up and the screeching begins. This spark gap is found on the D board (deflection board?) very close to the HV flyback transformer. It seems that the high-pitched screeching also comes from that area.
The schematic for this monitor can be found here:
Page 31 has a schematic of the D board circuits.
So, does anyone know what could be causing this issue and what to look for? I don’t have much experience with CRT monitors and TVs (only fixed one CRT monitor that had PSU problems).
In any case, I’m sure the D board will have to be removed to check/change components. However, what’s stopping me from doing so is the anode cap on the CRT tube – I just can’t get it off. Does anyone have any tips on how to remove it? Or is there any special method? The service manual above does show how to do it, but I’m unable to for some reason (can't get past separating the protective rubber cup from the CRT tube… the closest I've gotten is to just get the anode cap a bit loose but that’s it). I don’t want to damage it.
If I can get the D board off, then I'll be able to check some of the components myself and also take some pictures, if that helps.
Also, I think I might have to remove the board that attaches on the back of the CRT tube. Anyone know how I should do that? Just pull the board from the socket or is there something more special to it?
Any other help and tips are welcome too. Would be great to get this monitor working again. The picture on the other one is great. Would be a shame if I do not fix it.
The only reason I got these monitors is because no one wanted them. Owner said he first put them on CL for $30 the first week, but no one responded. Then he tried $15 and still got no replies. Finally he put them up for free, but still no responses. I guess I got lucky because when I talked to him afterwards, he said was getting ready to put the monitors on the curb that week but didn't only because they weigh so much (and he didn't want to call e-recyclers cause they wanted too much money). So he ended up putting them on CL again. After a week of no one replying again, I saw the posting, literally minutes before it expired, and emailed him. I didn't expect anything, but when I got his email I was pretty surprised. So yeah, I guess I got really lucky (and the monitors too
– otherwise dump truck would have crunched them).
Anyways, thanks in advance everyone (and as usual, sorry for the long post).
