viewsonic vx2835wm no power
  • Lee1
    • Feb 2013
    • Walker
    Re: viewsonic vx2835wm no power
    Hi, I am new to this forum. I have been reading lots of post on the Viewsonic VX2835WM, but have not found a list of the capacitors that are on the power supply board for this monitor. This would make it easy to find replacements. Thanks for any help.
    • selldoor
      Slow Learner
      • 7870
      We rarely provide lists of caps as we have no idea what version of any particular board might be in your set. The manufacturers sometimes make
      amendments to the values they use even on the same board versions.
      The best way is to simply list the caps you have on your board and then
      look up the datasheets and see what is available at digikey. You need the same voltage and uf value and same or better esr. You should also make
      sure they will physically fit.
      • badcapass
        • Apr 2013
        • 16
        same sort of Problem here with HD281D and PSM217, but there is no voltage on the Output rails, just 5V stand by (~5V, blue LED is on, react on power button, screen works with another power supply). All recapped, but the 400V parts (150muF and 22muF). Checked main capacitor (150muF), round 320V, soldered it out, 140muF, is that ok? Same on the 22muF cap, measured 20muF, both looking good.
        Any idea why it stays in standby?
        Regards
        Paul
          Can we good close up of the power supply board connectors? We are looking for the PS_ON signal to see if the signal (>2.75vdc) is present, also the voltage on that 450VDC main filter cap should go up to 380Vdc measure AT the two LEGS of the cap when power is switched on. Pictures of the main board also.
          • badcapass
            • Apr 2013
            • 16
            thanks for your help. I soldered all back together and measured the given points. PSON is always 0, but blue LED react on power button... Voltage on main cap is 320V, after blue LED is on it drops to 319V, voltage is constant.
            Pics will follow.
            Thanks and regards,
            Paul
              OK ,the main board is not sending the PS_ON signal to turn on the power supply and the PFC Voltage booster circuit to boost it up to around 380~390VDC.
              We need to test the main board next.
              • badcapass
                • Apr 2013
                • 16
                I thought the main board is ok, because if I replace the power supply with a compatible FSP217 (from another HG281D) it works. But when standby has 5V why there is no PS_ON? I think I get it. But why the blue LED reacts then and why ist goes in standby (blinking) after a while (think at the time where it shows the ‘no signal' screen). Oh, I didn't mention, there is no input connected while testing.
                Back to the main board. On the main board three caps are already replaced with 105°C Matsushita (Panasonic), C18 (10muF/50V), C74 (10muF/50V) and C83 (100muF/50V). At the connector from the power supply, there are just the 5V from SB (between black/GND and red/SB). Measured the voltage at the power button, it's always 3.3V, but when the blued LED went of, it shortly drops down.
                Hope the pics are god enough. Sorry for full image, thumbnail as link doesn't work:
                PSP back a:
                PSP back b:
                PSP back c:
                PSP front c:
                PSP front b:
                PSP front a:
                MB back:
                MB front:
                Regards and many thanks
                Paul
                  OK, you have to have it connected to running PC, then check the PS_ON again, when it is in standby, the PS_ON will be LO (<1V).
                  • badcapass
                    • Apr 2013
                    • 16
                    connected it to a video signal, PSON fluctuate between 0.01V and 0.9V. When blue LED went off, there is a short peak (0.9V) at PSON, the voltage at power button drops.
                    Seems like monitor do not wake up from stand by, but with another power supply it will... Are there other Points I can check voltage? By the way, voltage an main cap is today ~ 325V. I have read voltage at main cap is 340V?
                    Many thanks for your efforts, regards
                    Paul
                    • Lumberjack777
                      • 464
                      #30
                      I might be able to save you some time here. That appears to be the same power supply used in the Hanns-G 28" monitor. Some of the smaller caps tend to dry out. I normally replace the 3 caps circled in red, and everything fires back up again. You could optionally replace the ones circled in blue, but they have always shown low esr for me; even after years of use. But the 3 in red definitely need to be replaced, and it will probably work.
                      • badcapass
                        • Apr 2013
                        • 16
                        Hi Lumberjack777,
                        yes the power supply is from a HG281D. All caps are already replaced with Matsushita (Panasonic) 105°C LowESR types, seems you use the same, thanks for the pic. Just the two 400V are original, I tested them and they are ok. But maybe you can help me with the right sizes. I got the power supply with replaced caps and didn't check them, because I couldn't get a schematic for the board.
                        Input
                        C3 150muF/400V main cap (ori)
                        C203 2.2muF/50V
                        !C205 10muF/50V !1muF/50V
                        Middle
                        !C108 10muF/50V !22muF/50V
                        !C111 10muF/35V !22muF/50V
                        C114 2.2muF/50V
                        C403 470muF/35V
                        C406 10muF/50V
                        C601 22muF/400V (ori)
                        C603 22muF/35V
                        C606 1muF/100V
                        C605 47muF/50V
                        C701 1000muF/35V
                        C707 22muF/35V
                        Output
                        C301 1000muF/35V
                        C302 1000muF/35V
                        C306 470muF/35V
                        C401 1000muF/50V
                        C502 470muF/35V
                        !C505 470muF/35V !1000muF/10V
                        C506 470muF/35V
                        C702 (470muF/35V?)
                        Please check values of caps marked with !
                        Many thanks, regards
                        Paul
                        Last edited by badcapass; 06-30-2013, 04:49 AM. Reason: Got a list with size of caps here http://s14.directupload.net/file/u/40674/29fvxoqk_jpg.htm differing values marked with !
                        • badcapass
                          • Apr 2013
                          • 16
                          after reading some more, I changed C111 to 22muF and C505 to 1000muF. C205 I replaced with 2.2muF, because I have no with 1muF in Stock. So far so god, it's not working at all, but the blue LED doesn't come up anymore... :-( Main Cap is on 318V, 5VSB is on 4.99V, PS_ON between 0.02 and 1.2V, there are 3.3V at power buton. Could the C205 make such a differents? Is C108 10 or 22muF? Any hints, any spots to measure? It has to be the powersupply!
                          Regards
                          Paul
                            The main board looks like HanG, I see that you replace one of the two caps (100uf/16v) by the two regulators ICs, but not the one to the right as shown in the pictures.
                            • badcapass
                              • Apr 2013
                              • 16
                              yes thats right. I got the TFT with replaced caps, but it neither starts. So I took the power supply from another HG281D and it works! Put back the PSM217 and the Problems were back to. That is the reason why I wrote in this thread for the PSM217, also knowing it's ViewSonic related. Either at the Moment I havn't the caps for the main board. So first I want to concentrate on fixing the power supply.
                              Regards
                              Paul
                                OK, since you do have the working power supply, I would like what DC voltage you get at the main cap of the good power supply when it is in standby and when it is on. I expect it to be about 325V (230 x 1.414) in standby, about 380V when it is on. I do not have this power supply with me right to do the test.
                                • Lumberjack777
                                  • 464
                                  #36
                                  Yeah budm, he might be the victim of a bad cap change. That's why I always prefer a monitor that has never been touched.
                                  Ok badcapass: fortunately I did get an hg281d in the other day and I just opened it and its untouched
                                  The cap values you requested are.....
                                  C205 = 1uF 50v
                                  C108 = 10uF 35v
                                  C111 = 22uF 35v
                                  C505 = 1000uF 10v
                                    @Lumberjack777, so what DC voltage do you get at the main cap when it is on?
                                    • badcapass
                                      • Apr 2013
                                      • 16
                                      thanks for the input, that are the same values I have read across the net. I measured a voltage at main cap (C3) of 320V. Ordered the missing caps today, waiting to replace the last wrong part (C205 1muF). Hopefully it will change the situation.
                                      Regards
                                      Paul
                                      • badcapass
                                        • Apr 2013
                                        • 16
                                        just replaced C205, but nothing changed. I ordered the caps for the main board to and since the blue LED doesn't react anymore I want to recap the mb as well. But as you know, I am not sure about the right dimension. They should fit, but...
                                        Nr. [muF] [V]
                                        C8 10 16
                                        C13 10 16
                                        C14 10 16
                                        C18 10 16
                                        C19 10 16
                                        C60 10 16
                                        C61 10 16
                                        C63 - -
                                        C69 100 16
                                        C74 10 16
                                        C77 10 16
                                        C80 100 16
                                        C83 100 16
                                        C92 10 16
                                        C94 100 16
                                        C97 100 16
                                        C98 470 16
                                        C99 470 16
                                        C103 470 16
                                        C119 10 16
                                        C120 10 16
                                        Edit: Maybe I am totally wrong in a ViewSonic Thread..., sorry.
                                        Regards
                                        Paul
                                        • badcapass
                                          • Apr 2013
                                          • 16
                                          I have to make an addition. Just tried to start up my PSM217 by putting SB5V on PSON, no reaction voltage on +12V or +24V, just a slightly droped votage on main cap C3. Measured voltage on Q601, there it is :
                                          .........|xxxxx|-- 1
                                          .. i - -|Q601|-- 2
                                          .........|xxxxx|-- 3
                                          I get between i/1~20V, i/2~0V, i/3~20V, 1/2~0V, 2/1~20V, 2/3~20V is that correct?
                                          Regards
                                          Paul
                                          • Victor Moreira Silva
                                            Acer Nitro 5 LA-L181p power LED turns on by 5 secs (Short on PCH rail?)
                                            by Victor Moreira Silva
                                            I'm trying to repair my old Acer Nitro 5 (AN517-54-55T5). I've already bought a new laptop, so this is more of a learning project. For the experience, with no high expectations of success.
                                            Well, my decice specs are the following:
                                            Model: Acer Nitro 5 AN517-54-55T5
                                            CPU: Intel Core i5-11400H
                                            GPU: NVIDIA GeForce GTX 1650
                                            Motherboard: GH51G LA-L181P Rev:1c
                                            The symptom:
                                            When pressing the power button, the power LED lights up for about 5 seconds and then turns off. Initially, the issue was intermittent: sometimes...
                                            05-26-2025, 10:49 AM
                                          • PantherDave
                                            by PantherDave
                                            Hi all!
                                            05-29-2024, 02:01 PM
                                          • GLISIT
                                            by GLISIT
                                            01-16-2025, 02:29 PM
                                            by sam_sam_sam
                                            03-31-2024, 02:12 PM
