Benq broken chip
  • quackeruk
    • Apr 2010
    • 9
    Benq broken chip
    I have a belina monitor with Benq motherboard, Q601 has blown so I cant read it, can anyone help me with device no. The only ident no for the m/board ican find is 070 128.
    Thankyou;
  • retiredcaps
    • Apr 2010
    • 9271
    Re: Benq broken chip
    1) Post a clear focused picture using the manage attachment function of the entire board. See my sig file below for instructions.
    2) Circle which is Q601.
    3) BTW, this question is better suited in the "Troubleshooting Computer Displays" sub forum.
    --- begin sig file ---
    --- end sig file ---
    • quackeruk
      • Apr 2010
      • 9
      I am not too good with uploading files. I hope these are ok, I have no photo editor, so have placed a yellow hairband on one of the photos to indicate the position of Q601.
      Regards
      Don
      • Uranium-235
        Comrade Glimmer
        • Aug 2007
        • 5042
        • US
        I'm more concerned about the darkening around your inverter transformers
        • Gabriel
          • Jan 2010
          • 620
          • Norway
          I had a similar board type and info is here.
          You might want too double check that the chip is of the same type as mine was.
          • quackeruk
            • Apr 2010
            • 9
            With regards to the dark area, i have replaced the two inverters, the two driver devices plus all the caps, so i hope the new q601, a three leg device with heat sink.
            cheers don
              master hoarder
              • May 2008
              • 12160
              • Bulgaria
              Q601 should be a N-channel MOSFET (that's what it normally is on most monitors). Not sure of numbers and specs since I don't have this monitor.
              • FIXITNOW
                • Jun 2008
                • 128
                belina monitor model number is ??
                would help me to look in my notes to see if i have any info
                cheers
                • Gabriel
                  • Jan 2010
                  • 620
                  • Norway
                  Like I said, the ship is most likely a 1203p60 8 pin dip 'PWM Current-Mode
                  Controller for Universal Off-Line Supplies Featuring Standby and Short Circuit
                  Protection' as it was on my board, see my picture.
                  • jetadm123
                    • 2169
                    I think there is some confusion here. For Q601, the "Q" designator is for a transistor. In this case, it's the switching mosfet transistor mounted on the heatsink. However, the OP has circled the 8-pin PWM chip in his photo, which should be labeled IC601. The OP needs to identify which component they're really asking about.
                    • Gabriel
                      • Jan 2010
                      • 620
                      • Norway
                      Ahh now I see what the fuzz was all about - I just saw his picture with the yellow hairband and did not see the 'Q601' part.
                      If he however is thinking of the PWM chip it most likely is a 1203p60.
                      • quackeruk
                        • Apr 2010
                        • 9
                        Thanks to all. Gabriel was right, I did not put the hairband over to the right enough, the heatsink is only just visible, and it def is Q601 NOT ic601, this device is next to L604 and D 601. Sorry for problem/
                        • quackeruk
                          • Apr 2010
                          • 9
                          Now we have indentyfied the right device, is anyone able to give number.
                          rgds to all.
                          • Rtech
                            • Jul 2010
                            • 1095
                            Monitor model number, may be more than helpful.
                            • quackeruk
                              • Apr 2010
                              • 9
                              Sorry for delay with midel no. have had nasty chest infection.
                              Model no. BB10001. the BB could be 88,
                              rgds.
                              • Shrike
                                • Sep 2011
                                Maybe i am wrong , but the BenQ number printet on the board is
                                4H.03V02.A03
                                If so Q601 is a K3530, IC601 a 1203P60
                                I found this board in a belinea 2225 S1W
                                • veeresh
                                  • Oct 2011
                                  hi everybody i am new to this forum. i need to know is there any equivalent for 1203p60? i need urgent. videopoint5@yahoo.com.
                                  Regards
                                  veeresh
                                  • retiredcaps
                                    • Apr 2010
                                    • 9271
                                    http://www.findchips.com/avail?part=+1203P60
                                    • jetadm123
                                      • 2169
                                      Regards
                                      veeresh
                                      There are no substitutes for this controller. Readily available through Ebay or the link retiredcaps gave you.
                                      • lcdman
                                        TinkerTech
                                        • Nov 2010
                                        • 232
                                        • U.S.A.
                                        Maybe this link would be of help.
                                        http://www.mouser.com/search/Product...63-NCP1203P60G
                                        Take Care,
                                        lcdman
                                        • acedogblast
                                          by acedogblast
                                          11-02-2024, 05:13 PM
                                        • BMCappelletti
                                          Asus Chromebox CN62 - wrong chip put on BIOS reader
                                          by BMCappelletti
                                          Long story short:
                                          - dad converted Asus Chromebox CN62 into Windows compatible, with mrchromebox BIOS, years and years ago
                                          - gave the computer to his son a couple years later
                                          - son now decided to revert it to Chrome OS, to sell it as original (re-writing BIOS with the backup one created by his dad)
                                          - too lazy to remove the board from the case, thought a voltage regulator was the BIOS chip (you know... it has 8 legs)
                                          (seems like the story was not that short)
                                          He used alligator clips to read the chip. No luck reading it. Removed chip and placed on a SOC-8...
                                          01-08-2025, 07:27 PM
                                        • Troystain
                                          Help EZP2023+ updated chip database for w25q256jveq?
                                          by Troystain
                                          Hello, anyone here have updated ezp2023+ chip database in .dat file format.
                                          I need to add w25q256jveq chip but I do not know what data should I type.
                                          I'm using the ezp chip dabase editor posted from here https://www.badcaps.net/forum/troubl...ro-programmers
                                          The currenty unit model that I am trying to detect is HP elitebook 640 g9 which is currently locked on admin bios....
                                          11-25-2024, 12:53 AM
                                        • seppde
                                          Benq Zowie XL2540K / Power board failure / 6Pin-SOP-Chip identification
                                          by seppde
                                          I've got a Benq power board of a XL2540K monitor which suffered from a power cut and is since defective / won't turn on. It's got obvious defects, some blown resistors, some burning around the drain pin of a MOSFET...
                                          ... and some 6-pin IC I struggle identifying, that is driving said MOSFET.
                                          The IC is labeled as IC601, so someone with a circuit schematic could probably identify it really quick, unfortunately I can't find the schematics.
                                          In other power boards of Benq for which I did find the schematics, IC601 is an 8-pin NCP1200 PWM controller - I suppose...
                                          02-09-2024, 05:19 AM
                                        • inck243
                                          Acer e15-e5-576g-5762 bricked. Bios chip won't interface in AsProgrammer.
                                          by inck243
                                          Thanks for any help. The board version is DAZAARMB6E0 REV: E. The bios chip is winbond 25Q64JVSIQ1736. W25Q64JV is not available in AsProgrammer -- only BV CV FV or FW_1.8c. The chip won't interface with asProgrammer and a CH341A. When I have this chip on the board, the laptop will not post but when I plug it in to power, the blue LED lights up, also the orange when the battery is connected. When I push the power on button, keyboard backlight turns on and the fan starts briefely then turns off. But I can't do anything to program this bios chip so I bought another one.
                                          The BIOS...
                                          07-25-2024, 09:17 AM
