HP W2408H No Power (Surge) Repair - Success
  • jamalC
    • Sep 2015
    • 14
    • denmark
    Re: HP W2408H No Power (Surge) Repair - Success
    Originally posted by Davi.p
    Probably yes, supposed you power on che monitor only one time, the NTC is there to protect the diode bridge from Power surge due to high current requested to charge the big cap the first switching on.
    the monitor didnt poweroff
    so i soldered the sck 037 back.
    something I noticed: i can hear the high pitched sound (like capacitor charges?). and high pitched, i mean there is a ramp of the pitch going up (slow attack of the envelope)
    hey thanks for replies guys!!
    • jamalC
      • Sep 2015
      • 14
      • denmark
      Originally posted by budm
      SCK037: 15mm Dia.
      At room temp (25c) the resistance is 3 Ohms (Zero power, no current flow), full steady state current is 7A Max at 25C, at this current flowing the resistance will drop down to 0.091 Ohms. It is NTC so as the temp goes up when the current start flowing its resistance will go down.
      thank for the explaining, very usefull.
      • jamalC
        • Sep 2015
        • 14
        • denmark
        Originally posted by ryankam
        ... Found out it should have been reading 5 OHMs when cool. Replaced thermistor with 5 OHM resistor and the monitor powered up.
        im a bit puzzled why this guy says that this thermistor should be reading 5 ohm instead of 3??
        • jamalC
          • Sep 2015
          • 14
          • denmark
          i also went through all diodes and resistors, all are reading nothing suspicous.
          what is this guy i marked with a blue circle? it says some numbers on his back (0734 8178 y). what could his purpose be in this universe .) and how can i test him?
          • vinceroger69
            • Mar 2012
            • 6714
            i think its a optocoupler but not sure how to test it though.
            • jamalC
              • Sep 2015
              • 14
              • denmark
              #26
              thx for the reply!
              do optocouplers live long and strong?
              • jamalC
                • Sep 2015
                • 14
                • denmark
                #27
                .... Replaced thermistor with 5 OHM resistor and the monitor powered up. .....
                just replaced thermistor with 5 ohm (2 * 10ohms in parrallel was reading 5.6) and they both blew up.
                  • 30937
                  lol - because it probably pulled over 30w through them!
                  • jamalC
                    • Sep 2015
                    • 14
                    • denmark
                    #29
                    aaahhh ...
                    • Davi.p
                      Hobbist Tech
                      • Sep 2009
                      • 4277
                      • Italy - Milan
                      #30
                      Jamal maybe thermistor is not yor problem, it has a bit of resistance when you put the AC plug in but after it become as invisible, do some readings, for example in volt at the bigger capacitor, you must read about 320v. Use gloves for safety.
                        24 inch monitor, lest say you are drawing 2A (if it is really drawing that high, more likely to be around 1A or so) through 5 Ohms = 20W of power, so about 10W per resistor. How big are the 10 Ohms resistors?
                        May be you still have bad circuits that is drawing too much current too.
                          • 30937
                          2a? with leds maybe, but not with rack of cfl's in it!
                          this monitor is rated at 130w
                          • jamalC
                            • Sep 2015
                            • 14
                            • denmark
                            #33
                            i'll defo do this. thx
                            • jamalC
                              • Sep 2015
                              • 14
                              • denmark
                              #34
                              yea this is why im a newbee: i took the "usual" ones, you use with a breadboard.
                              but now i guess i will be ordering one(s) with +30W
                                • 30937
                                breadboard? you mean 1/3w resistors!! damn that must have been fireworks - on a small scale.
                                • jamalC
                                  • Sep 2015
                                  • 14
                                  • denmark
                                  #36
                                  hahahhahaha
                                    Really! Lets see now, his line Voltage is 230VAC, so 2A = 460W!, 130W will be less then 1A. The unit also has PFC.
                                    Check your math, or how you say it, lacking?
                                      • 30937
                                      my math? i got the wattage from HP's specs page!
                                        Yeah, so 130W with 230V, how many Amp will that be?
                                        jamalC, is in Denmark.
                                        Do the math again.
                                        Hint P= I *E
                                        130W @230vac = 0.565A
                                        130W @120Vac = 1.083A.
                                        I would say that the original Thermistor was blown due to bad parts on the power supply board that he needs to carefully inspect.
                                        • jamalC
                                          • Sep 2015
                                          • 14
                                          • denmark
                                          #40
                                          hey. what do you mean original Thermistor? you mean mine or Ryans (who bought a new thermistor and it worked?
                                            by momaka
                                            03-15-2023, 10:17 PM
                                          • ant3202
                                            HP 27es - LED monitor - Monitor Flashing On - Off
                                            by ant3202
                                            Hi Everyone
                                            Lately I am experiencing the deja-vu incident on one of the led monitor like this.
                                            https://www.badcaps.net/forum/troubl...lashing-on-off
                                            The monitor is HP 27es LED Monitor
                                            https://h30434.www3.hp.com/t5/Deskto...e/td-p/6804692
                                            The monitor will randomly blackout and display no signal and will recover again.
                                            Sometimes need to power and off again to restore the display but...
                                            03-20-2025, 07:30 PM
                                          • Rick_1234
                                            LG 23MP55HQ LED Monitor turns off after a few seconds or flickers.
                                            by Rick_1234
                                            Good evening, gentlemen.
                                            I have a problem with my monitor. It turns off after a few seconds or flickers. Shining a flashlight on the screen doesn't show any image, so I guess it's not the "2 seconds to dark" I read in the forum.
                                            To turn it back on, I have to press the power button twice. Then after a few seconds it turns off again or flickers. See video.
                                            https://drive.google.com/file/d/1L6S...ew?usp=sharing
                                            Things I tried
                                            - Bought a new AC adapter thinking that was the problem but the problem...
                                            06-22-2024, 04:44 PM
                                            Wise Wing F199 19'' LCD monitor - recapped
                                            by momaka
                                            Looking through my repair pictures and notes, it's been a long time since I posted anything in the LCD monitors section. So here goes that.
                                            I'm dedicating this thread to one of the very first LCD monitors I repaired (if not the first one), which was more than 10 years ago now. The monitor is a Wise Wing, model F199. It's a 19” CFL-backlit LCD. I got it for free off of Craigslist in 2009 from a guy, who said he bought it for cheap from Wallmart and the monitor worked only for a little less than 2 years before quitting.
                                            When I saw the Craigslist post, I wasn't...
                                            08-24-2020, 10:58 AM
                                          • sew333
                                            Pc shutdown, monitor flickered with no signal after 10 seconds
                                            by sew333
                                            My pc:
                                            10850K stock 4800mhz stock Kraken X73 good temps
                                            2x16 GB DDR4 GSKILL 3000mhz XMP
                                            Seasonic Tx-850 Ultra Titanium
                                            Gigabyte Rtx 3090 Gaming OC
                                            Aorus Z490 Pro Gaming
                                            1 TB SSD
                                            4 weeks ago i launched Metro Exodus Enhanced and during cinematic advertisement part ( 30 fps ), pc just shutdown.
                                            Also monitor flickered with NO SIGNAL 10 seconds after shutdown. So only monitor and pc was affected.
                                            Next i pressed only power button, rebooted again and its fine again. Happened once and i cant reproduce.
                                            Power...
                                            02-22-2022, 10:27 AM
