Dell 3008wfp faulty power supply
  • yzenezy
    • Aug 2014
    • 5
    Re: Dell 3008wfp faulty power supply
    Hi Everyone,
    I have a 3008WFP in which I've replaced D22 with STPS40170CT (testing the old D22 showed it was shorted). I also didn't put the ferrite insulator back on the leg of the STPS40170CT. I hope that's OK.
    Anyway, I now get a blue power light and the monitor is detected by Windows 7 when I connect my laptop via the VGA connection, but the 3008WFP doesn't show any output. What do I do now?
    I haven't put the plastic case or bezel back on so disassembly should be straight forward. Any clues as what to do next are appreciated.
    Regards,
    Tom
    • yzenezy
      • Aug 2014
      • 5
      Sorry, I forgot to connect the power board connector the the circuit board on the back-right of the monitor.
      Now I get a backlight at least but still no output. Also, the On-Screen-Menu doesn't show when I push the buttons. Not even the source select shows. I can't remember if this monitor has an auto source select.
      • selldoor
        Slow Learner
        • 7870
        #443
        Did you see it working before or did you get it in to fix.
        • yzenezy
          • Aug 2014
          • 5
          Hi selldoor, I pulgged the connector in. Then I saw the backlight come on (at least I think it is a backlight as it is a kind of 'glowing' behind the LCD). On the same board there is a small dblue ribbon connector as well. I reseated that as well but still no output or on screen display (menu) showing.
          If I disconnect the VGA cable, the blue power indicator light turns to orange.
          • yzenezy
            • Aug 2014
            • 5
            It's working!
            Thank you everyone who has contributed here. I was able to debug it by reading through the thread again.
            At the top of page 12, Maxidud2000 had a similar issue to me in that the blue power indicator light came on but not signal was received and the on-screen-menu was not working. Selldoor's post in the thread suggests checking the fuses on the board at the top of the monitor. So I disassembled my monitor again and found that one of the plugs to that top board had worked loose during the first reassembly. I check the fuses anyway and found them good, reseated the plugs, reassembled and it worked first time.
            Thanks again everyone!
            • selldoor
              Slow Learner
              • 7870
              #446
              Well done! - hope it continues to work for you.
              • werz51
                • Sep 2014
                I find this thread 3 days after I replace my dead 3008WFP with a second hand 3011WFP.
                I'll order the part and try to fix my old monitor.
                Thanks to everyone for posting their how to repair this fault.
                • shrafciger
                  • Sep 2014
                  • 3
                  • Serbia
                  #448
                  I need help to repair this cable:
                  http://i61.tinypic.com/zwjn8y.jpg
                  Could anyone explain me how to properly connect this 3 connectors A,B,C
                  example: A1 - B6, A2 - B2 .... A24 - Cx
                  and which of wires to TWIST?
                  Thanks everyone who can help me!
                  • selldoor
                    Slow Learner
                    • 7870
                    #449
                    That is one hell of job!!!
                    I have only seen 3 cases of that - here is one
                    https://www.badcaps.net/forum/showth...008WFP&page=12 start at post 240.
                    I think you will just have to replace it wire by wire
                    • shrafciger
                      • Sep 2014
                      • 3
                      • Serbia
                      #450
                      I have replaced wire by wire, but forgot to twist wires. I think, this is only problem. However, I like to check if cable is properly wired.
                      • selldoor
                        Slow Learner
                        • 7870
                        #451
                        I see now - you pinched his picture.
                        I know its 2 years ago but you could try and PM kazkasneaiskaus and ask if he kept any record.
                        • selldoor
                          Slow Learner
                          • 7870
                          #452
                          Or PM werz 51 See further up )and ask if he has his 3008 apart does he have time to
                          ohm out the pins on his connector.
                          • shrafciger
                            • Sep 2014
                            • 3
                            • Serbia
                            #453
                            No one can't help me?
                            • mozg1986
                              • 6
                              • Russian Federation
                              #454
                              TMDS Cable the scheme, on the future
                              • selldoor
                                Slow Learner
                                • 7870
                                #455
                                Thanks for posting that- could be helpful in the future
                                • mozg1986
                                  • 6
                                  #456
                                  And I draw now the scheme of the inverter, here part, responsible for DCR
                                  • vvulture
                                    • Apr 2015
                                    • 17
                                    Hi Guys,
                                    Just removed D22 from my 3000wfp PSU.
                                    I am trying to determine if it is infact faulty but need some advice.
                                    Using a DMM in DIODE testing mode, i get a voltage drop of 0.158v when placing leads across Anode and Cathode.
                                    If i reverse the leads i get zero volts ( ie no reading ).
                                    Is this the correct way? and are the readings indicative of ok or faulty ?
                                    I need to know before purchasing a new diode which will cost me about AU$25 .
                                    Thank you
                                    • selldoor
                                      Slow Learner
                                      • 7870
                                      #458
                                      There is no such thing as "no reading" unless your meter is not on or the battery is totally dead.
                                      Do you mean it is on 0.00 or perhaps a 1 on the right hand side of the screen
                                      or OL or something else.
                                      Try testing on ohms 200 test each leg to the other 1-2 1-3 2-3 looking for shorts (same as holding the probes together.
                                      Next Meter on ohms 2000 test 1-2 then again with the probes reversed
                                      then do the same for 2-3.and post the result
                                      • vvulture
                                        • Apr 2015
                                        • 17
                                        Thanks for the reply selldoor.
                                        The "no reading" i was referring to is infact "OL".
                                        1-2 Resistance ( Reversed OL )
                                        1-3 SHORT
                                        2-3 Resistance ( Reversed OL )
                                        I can only set my DMM on ohms, 1kohms, 10kohms, 100kohms, 1Mohms, 10Mohms
                                        Cheers
                                        • selldoor
                                          Slow Learner
                                          • 7870
                                          #460
                                          That is probably an ok D22 as the legs 1 and 3 are joined and the diode
                                          sections perform correctly.
                                            by sam_sam_sam
                                            03-31-2024, 02:12 PM
                                          • Borse2008
                                            Seeking Advice: Repairing Dell U3425WE Monitor with Faulty USB-C/Thunderbolt Ports
                                            by Borse2008
                                            Looking for some advice or opinions on what to do with a monitor issue I’ve run into. Apologies in advance is this crossovers a few forum categories.
                                            I have a Dell U3425WE, which I've recently replaced with another model. That said, the original unit is still fully functional in terms of the display — it works perfectly over HDMI and DisplayPort. However, the USB-C and Thunderbolt 4 ports have stopped functioning correctly. The Issue:
                                            • The 90W Thunderbolt 4 port (circled in the photo) no longer charges or powers any device, including laptops or MacBooks.
                                            • There’s
                                            07-15-2025, 04:55 AM
                                            by sam_sam_sam
                                            07-01-2024, 06:34 AM
                                          • Akhlz001
                                            by Akhlz001
                                            09-20-2025, 07:15 PM
