Dell 3008wfp faulty power supply
  • steny
    • Aug 2013
    • 14
    Re: Dell 3008wfp faulty power supply
    Having read through all of this thread, was wondering if someone could post steps of instructions on how to test the power board before reassembling the case - for someone without electronics background?
    Will be installing a new diode into 3008wfp this weekend and would like to see if it works before putting the whole mess back together... :-)
    Also, are there any tests that can be done if the diode ends up not the problem... ?
    • steny
      • Aug 2013
      • 14
      Are there any of the 3008wfp experts still around...?
      We need you!
      Hoping to get some guidance on testing the board before putting it all back together...
      • math
        • Jun 2013
        • 9
        • australia
        #363
        We need you!
        i plugged in the front control buttons and "half" assembled it with an input from my laptop.
        held it together so it didn't fall over and watched the screen come to life.
        then once it worked put it slowly and carefully back together properly
        If you were in Brisbane, Australia i would lend a hand
        • biosfear
          • Dec 2012
          • Puerto Rico
          #364
          Hi to all, i replace the d22 and the monitor now turn on but with color cycling. i did all the reset button like this one:
          * Turn the monitor off
          * Press the buttons simultaneously Menu/Plus/Power
          * Release all three buttons
          * Press the Minus button
          and no good. can you guys help me out what i can do to reset or something else?
          thanks.
            Color cycling with it hooked up to running PC?
            • biosfear
              • Dec 2012
              • Puerto Rico
              #366
              with a vga cable and with out it. is start with white, red, and blue ect.
              • horatio71
                • Oct 2013
                it seems that I'm also suffering from the same problem as everyone is having. Can I just sanity check my symptoms and see if you agree:
                -The other day my 3008 went completely dark.
                -The blue power light is still on and seems to work
                -However, I can not even get into the monitor menu, or at least i don;t see it as it is dark. (just a side note - my PC is all fine as I'm using it with a replacement monitor, but that would also not explain why I can't see the monitor menu)
                Do you guys agree that this could be the D22 issue (just uncertain as the blue power led is still working)?
                Cheers,
                John
                • maticma
                  • Nov 2013
                  • 5
                  • CRO
                  #368
                  should MBR20200 be ok replacement for D22?
                  Thanx
                  • Th3_uN1Qu3
                    Believe in
                    • Jul 2010
                    • 6031
                    #369
                    Yes, MBR20200 will work fine.
                    A working TV? How boring!
                    • maticma
                      • Nov 2013
                      • 5
                      • CRO
                      #370
                      Thanx a bunch! it is the one i can get locally
                      • maticma
                        • Nov 2013
                        • 5
                        • CRO
                        #371
                        Its alive!
                        Thanks to everyone contributed to this thread.
                        BTW, Bezel removing was pretty painless for me.
                        After 10min trying to remove from outside of monitor, cut my thumb and gave up.
                        Tried again from inside (display side) with only short plastic ruler removed it in 30sec
                        • Bakki1
                          • Nov 2013
                          • 10
                          • France
                          #372
                          Hey,
                          I need a new tconboard, does anyone know where I can order one!
                          Cheers
                          bakki1
                          • Bakki1
                            • Nov 2013
                            • 10
                            • France
                            #373
                            ? Instead of !
                            • Lumberjack777
                              • Dec 2010
                              • 464
                              #374
                              Originally posted by Bakki1
                              I need a new tconboard, does anyone know where I can order one?
                              I can probably help you locate one. But I need to ask you 2 questions first.
                              1. How do you know its the T-Con? Are you 100% sure?
                              2. What is the LCD Panel type? The T-Con is panel specific.
                              You'll find the sticker on the inside of the LCD panel. Examples....
                              LM300WQ5-STA1
                              LM300WQ5-STA2
                              LM300WQ5-SLA1
                              • biosfear
                                • Dec 2012
                                • Puerto Rico
                                #375
                                LM300WQ5-STA1
                                LM300WQ5-STA2
                                LM300WQ5-SLA1
                                The Tcon board is the main board?
                                • Lumberjack777
                                  • Dec 2010
                                  • 464
                                  #376
                                  No, the T-Con is the "timing control" board.
                                  The main board is basically the video board (with DVI, VGA, HDMI, inputs)
                                  The T-Con board is in top and attached to the LCD panel. It has a metal shield (with holes) covering it.
                                  An LVDS cable (ribbon) runs between the main board and the T-con board.
                                  The T-con model (part number) is associated with the LCD panel.
                                  Unless you get the exact T-Con, for the LCD panel, it won't work.
                                  http://www.youtube.com/watch?v=J1GmfoeQeP4
                                  • Bakki1
                                    • Nov 2013
                                    • 10
                                    • France
                                    #377
                                    A guy via a forum told me that with my error it should be the tconboard thats fucked up, the localshopdude says its the main board.. the generis/genesis-chip is faulty..
                                    my dell wont produce any picture, only for the second when i turn the settings back to default.. same problem with every inputmethod..
                                    • selldoor
                                      Slow Learner
                                      • Dec 2010
                                      • 7870
                                      #378
                                      So , I am not sure what you want us to say. Without carrying out specific tests using a multimeter it is almost impossible to guess. Do you have any experience at all of working inside a Monitor?
                                      Some high voltages in there will be between 220 and possibly 2200 vac.
                                      You will also need a digital camera and be able to provide clear pictures of your boards
                                      If you have a multimeter and can use it and are up to working close to those voltages we may be able to help. Otherwise you can only try
                                      changing out the boards one at a time - which could be expensive.
                                        "my dell wont produce any picture, only for the second when i turn the settings back to default." I wonder if the backlights come on for seconds, then black out is what you are seeing.
                                        • Bakki1
                                          • Nov 2013
                                          • 10
                                          • France
                                          #380
                                          I dont have any experience with working the inside of a monitor, that's why I gave it to a repairshop. They checked it with a multimeter and said that a controller chip (its called generis or genesis) on the main board is broken.
                                          • Tynan Dill
                                            by Tynan Dill
                                            Assuming...
                                            11-22-2024, 01:46 PM
                                            03-31-2024, 02:12 PM
                                          • Borse2008
                                            by Borse2008
                                            • There’s
                                            07-15-2025, 04:55 AM
                                            07-01-2024, 06:34 AM
                                          • Akhlz001
                                            by Akhlz001
                                            09-20-2025, 07:15 PM
