Dell E172fpb
--- begin sig file ---
--- end sig file --- -
Re: Dell E172fpb
As i'm new to electronics which is the startup cap?
http://s1063.photobucket.com/albums/...rent=DV172.jpg
Re: Dell E172fpb
Did you recheck those transistors again to see if they are shorted out again and the tabs are not touching the chassis?
You can also remove the BEL FUSE which feed the B+ to the inverter circuits and see if the LED stays green with PC connected. Also check the value and leakage resistance of those 4 tuning caps by the 4 inverter transistors.Last edited by budm; 09-05-2012, 11:31 PM.Never stop learning
Re: Dell E172fpb
Post your images following my sig file exactly.As i'm new to electronics which is the startup cap?
http://s1063.photobucket.com/albums/...rent=DV172.jpg--- begin sig file ---
--- end sig file ---Comment
Re: Dell E172fpb
This Cap seems to be the probable issue so will get some in town tomorrow and replace it and others and see if i get a result.
Sorry macro on my camera is not that good but the large brown 35v 1000uf is the bulging one.
Missed it before when i replaced at the mofsets etc. Vee
Re: Dell E172fpb
Replaced the large brown 35v 1000uf with units about 50% larger in size (just squeezed in) and the rest of the caps for the board are on order.
Fired it up anyway as will be a several days for stock to come in and it is working well. Yay
Will replace the others so i know i have all good quality caps and the board has been totally resoldered all over so hopefully no more problems. Thanks for all advice everyone and tutorials retiredcaps
. Vee
Re: Dell E172fpb
That squealing noise may be due to bad main DC filter cap (that large black cap in the primary side). Put the meter in AC mode and take the voltage reading on the two legs of the cap, also take the DC reading as well.Never stop learning
Re: Dell E172fpb
With this monitor its pretty hard to do as you cannot get to the otherside of the board but will give it a try. Must be a workaround.
Also noise is definatley emanating from the transformer i rolled up a sheet of paper and put the tube over it and you can hear the noise easy and nothing when i do the same to the large cap. Cheers Vee
Re: Dell E172fpb
You can solder two wires to the leg of the cap and run them out to allow you to connect the probes to them, you MUST BE REAL CAREFUL! you are working in the LINE (HOT side) of the circuits. Do not touch any thing with your hands.Never stop learning
Re: Dell E172fpb
Well obviously something is amiss,BUT trying to identify what,is not going to be easy.The DC input seems correct to give you the correct DC voltage on the cap.The first thing to do, although it may seem odd,is to measure the AC in the wall socket...we know its going to be about your 240v mains AC,BUT what does the meter actally read,on the AC range you used to measure on the Cap ??/Comment
Re: Dell E172fpb
Monitor has been plodding on for months and have been waiting for something to give up but not the case. Just squeals like a pig once it starts to get warm so good for about 20min and then it starts it call!!
So today replaced the large black main cap in the photo the 450V 100mfd Elite branded with a japanese equivalent and did not make any difference.
Now to locate a tranformer in the photo if i can as thats were the noise is coming from for sure!! Anyone have any idea where i may get one?? Cheers Vee
Re: Dell E172fpb
I just got one of these. Unlike most of you fellows, mine is doing thr 1 second to black issue.
If i shine a light at the screen, i can still see the image, and the green power led stays on solid so the monitor is staying on except for the backlight.
Should i tear it down and check these common suspect transistors anyways?
edit whoops this is a E173FPc maybe its not the same internally.Last edited by cadillacman; 03-18-2013, 06:31 PM.Comment
by BowlineMy question pertains to understanding the control circuity inside a Dell PT434 type battery used in Dell E6400, E6410 and other Dell notebooks?
I have tried multiple different Dell power adapters. My Dell... -
by Akhlz001Hi,
Could someone help trying to unlock this BIOS, seems that Dell have changed the layout of new Dell Pro 8FC8 bioses from checking HXD - 4000 bits do not need changing, only 2000. However after FF the section starting from '01000' upto 2000 bits and then soldering the chip back it seems that the microchip on the motherboard is recovering the bios back to original settings after first boot. Has anyone found a way to crack this extra layer of security Dell have implemented? Seems both HP and Dell have upped bios security to match Lenovo by implementing extra measures on a separate...-
Channel: BIOS Requests ONLY!
by master3112I would like to share my experience about charging issues with Dell power supplies with the tech community. I am working on a Dell Inspiron 5590, Mainboard 18778-1 with charging problems. The device can be switched on and works so far, only the message appears at startup:
The power supply unit is not recognized in the Bios and the charging process is set to "idle". I use original Dell battery, type...-
Channel: Schematic Requests ONLY!
by SMDFleaDell thunderbolt firmware, extracted from dell firmware update exe. Padded to 1MB.
Some models have a choice of 2 different firmwares, it depends on the dell SKU.
The SKU is in brackets (****)
EDIT: NVM65...-
by F R 2568Hello all,
this is my first post, so if I make mistakes please do not hesitate to point them out, thank you in advance.
I got a Dell Latitude 5420 (Service Tag: 7RFM6D3, Motherboard: GDF40 LA-491P Rev.: 2.0 (A01)) which does not start and I want to repair it. These are the symptoms:
If the laptop is only connected to the AC adapter (battery removed):
When I press the power button, the keyboard backlight and the display backlight are turning on. Caps key light is lightning, but key does not respond to pressing it.
The power/battery... - Loading...
