Dell E172fpb
  • Mohonri
    • May 2009
    • 13
    #361
    Re: Dell E172fpb
    I had the same issue as everyone else--monitor turns on, then starts flashing every second or so.
    First, I replaced the (single) bad transistor. The monitor worked fine for about a week, then exhibited the same symptoms.
    The second time, I replaced the newly bad transistor, and resoldered all the joints on the transformers. Since then (going on four weeks now), all appears to be well.
    So chalk up another vote for "Resolder the transformer legs".
    • Cakk
      • Apr 2009
      • 8
      #362
      Re: Dell E172fpb
      I ended up just buying a new inverter
      • thefloyd
        • May 2009
        #363
        Re: Dell E172fpb
        I recently acquired a broken Dell E172fpb monitor and thanks to the info on here and a "repair kit" from ebay I was able to get it back up and running again. This was my first attempt at repairing components on a PCB and I'm happy to say that it went well. Thanks to everyone for providing such a valuable resource.
        • AquaticEarth
          • Jul 2009
          #364
          Re: Dell E172fpb
          Got a BENQ FP531 LCD which use exactly the same PCB with the same problem as described in this thread. Just replaced Q759, Q760, Q740 and Q739 with four 2sc5706 from local electronic store for NT$15 each (USD0.46) this afternoon and everything went ok. Thanks for all message contributors here, you guys are great!
          • AquaticEarth
            • Jul 2009
            #365
            Re: Dell E172fpb
            Update: After second power-on, the monitor failed again with the same on-off cycle problem. This time I took the advice from earlier posts and resolder the PCB. Now it's back to working condition.
            • Richie_asg1
              • Feb 2009
              • 21
              #366
              Re: Dell E172fpb
              Have just picked up a Dell - E151FPb for rework.
              Aparently "works ok for a bit - but have to keep smacking it"
              Exhibited classic Transformer cracked solder joints.
              Resoldered all inductors as there was signs of rings around more than one.
              Works fine now.
              This NASA website is great for good practice and faults in soldering -
              http://workmanship.nasa.gov/lib/insp...uirements.html
              • weefa
                • Aug 2009
                #367
                Re: Dell E172fpb
                sorry in advance guys, but when i have the time i'll read through the 19 pages of this thread.
                my monitor powers on for a few seconds and shuts off. from what i could gather is this the kit that i need to fix the problem?
                http://cgi.ebay.com/ws/eBayISAPI.dll...m=220476282873
                • PlainBill
                  • Feb 2009
                  • 7034
                  Re: Dell E172fpb
                  Yes, that should do it. Also, resolder all pins on both transformers in the inverter.
                  PlainBill
                  • weefa
                    • Aug 2009
                    #369
                    Re: Dell E172fpb
                    well, i bought the kit on ebay and my monitor is alive! less than $10 in parts - sure beats buying a new invertor board or monitor.
                    FYI, i got the kit here:
                    http://cgi.ebay.com/ws/eBayISAPI.dll...m=220486136668
                    • EGuevarae
                      • Nov 2008
                      • 1336
                      Re: Dell E172fpb
                      Don't forget to resolder the transformer solder points or else you will be working in the unit again very soon....
                      There are 10 kind of people in this world: those that understand binary, and those who don't.
                      • ASUS ROG Maximus IX Code
                      • Intel Core i5-7600K 3.8GHz
                      • 16gb GSKILL TridentZ RGB DDR4-3200
                      • 1 M2 SSD + 2 WD Blue 1TB (Mirrored)
                      • Windows 10 Pro x64
                      • GeForce GT1050
                        2 x Acer KA240H + 1 Vewsonic VP2130 21 (a cap replacement job )
                      • mbates14
                        • May 2005
                        • 169
                        #371
                        Re: Dell E172fpb
                        also its amazing after replacing JUST the transistors you guys have working monitors. most of you are failing back out within a short period of time:
                        Word of advice:
                        Check the shottkey clamps D751,D761. they 90% of the time will short when the base current surges during the transistors "shorting" stage before shutdown.
                        This helps limit the base current on the output transistors, if this diode is bad, the unit will run.. but not for long....
                        Diode SB360
                        • xtraelectronics
                          • Apr 2009
                          • 49
                          #372
                          Re: Dell E172fpb
                          Also nobody mentioned that the C5707 is listed in the spec sheet as a "high speed switch". The reason the TIP41C's are running so hot is because they are not designed to operate this way. Look at the PDF spec sheets when deciding what transistors to use as replacements. C5707: https://cdn.badcaps-static.com/pdfs/...964cb690e1.pdf
                          TIP41C: https://cdn.badcaps-static.com/pdfs/...3d809d111d.pdf
                          NTE cross reference: http://nte01.nteinc.com/nte/NTExRefSemiProd.nsf/$$Search
                          • gina0602
                            • Jun 2009
                            #373
                            Re: Dell E172fpb
                            Originally posted by HelpQuick
                            Thanks all for your help...
                            I tested the transistors Q759 and Q760 were shorted, I have swapped these, and the monitor now works great!
                            Once again, Thanks to all who helped!
                            Swapping transistors is not sufficient in my case. After 3 days, the transistors got shorted.
                            • PlainBill
                              • Feb 2009
                              • 7034
                              Re: Dell E172fpb
                              Have you resoldered the transformer leads? That is a common problem. Also, have you replaced the capacitors, especially those in the inverter section?
                              PlainBill
                              • Bobdee
                                • Jun 2008
                                • 461
                                #375
                                Re: Dell E172fpb
                                Hello Gina0602
                                You must resolder the 4 Inverter transformers, these are the probable cause for the failure of the transistors in the first place
                                They usually have ring cracks that are hard to see with the naked eye
                                Resolder all four
                                Possibly only one of the new transistors has failed, so one of your old ones that is good can replace it and check inverter fuse if there is one
                                Bob
                                • Mohonri
                                  • May 2009
                                  • 13
                                  #376
                                  Re: Dell E172fpb
                                  Well, I'm now up to six or seven of these monitors. One of them had a failed FU9024N, but all had failed C5707 transistors. Replacing the failed transistor and resoldering the tranformers has done the trick every time.
                                  One tip I've learned: The transistors *can* be tested in-circuit by using the "diode" setting on my multimeter. Measure from base to emitter and from base to collector. Both should be between 0.5V to 1.0V. Failed transistors show a short.
                                  Also, a hot iron is important. If your iron isn't hot enough, the traces can come up.
                                  The E173FPb has the same issue as the E172FPb.
                                  As others have said (over and over again, but the question still comes up) you MUST resolder the transformers.
                                  I personally have seen no bad caps, but maybe I've been lucky so far
                                  • Bobdee
                                    • Jun 2008
                                    • 461
                                    #377
                                    Re: Dell E172fpb
                                    Hi Mohonri
                                    Very Interesting
                                    Are you saying that you are testing when Monitor Powered On???
                                    Also how can you attain a Voltage reading on (Diode Test) settings???
                                    Bob
                                    • PlainBill
                                      • Feb 2009
                                      • 7034
                                      Re: Dell E172fpb
                                      Originally posted by Bobdee
                                      Hi Mohonri
                                      Very Interesting
                                      Bob
                                      I though most electronics techs knew this. The diode test function on a dmm works by applying a voltage to one end of a resistor, the other end of the resistor is connected to the + lead. The number displayed is the voltage across the leads. Since the voltage applied and the value of the resistor vary, it is difficult to determine precise information on the diode (or transistor) characteristics. In theory, a silicon diode conducts at 0.7 volts. A DMM diode test can report anything from .5 volts to more than .8 volts, depending on the meter design and the type of diode. You can't do the test with power on.
                                      I prefer to check transistors (and diodes) for shorts by using the 200 ohm scale. This should be the same for all meters (within the accuracy limits of the meter). The Ohms scale will not detect an open transistor, but it was designed not to.
                                      PlainBill
                                      • techbrat
                                        • Nov 2009
                                        • 13
                                        #379
                                        Re: Dell E172fpb
                                        I had this problem on my dell 17" e172fpb too. The monitor would work for 2 seconds showing the bios motherboard booting and then shutoff and the power light turned orange.
                                        replaced all 4 transistors with the oem japan transistors and it blew the transistors immediately
                                        then I went to radio shack and used a NPN tipp 3055
                                        I saw the back-light come on very bright white and shutoff.
                                        Now the back-light does not come on any longer
                                        It never came back on after that! I tried a bunch of NPN tipp 3055 today and the back-light did not come on period. I pretty much give up on this monitor.
                                        The traces have peeled off the board next to the transistors and it is hard to remember the trace routing when soldering
                                        does anyone have a picture of the traces?
                                        • PlainBill
                                          • Feb 2009
                                          • 7034
                                          Re: Dell E172fpb
                                          Read the other 18 pages of this thread. There may be pictures of both sides of the board on one of the pages. With luck all you've done is blow a fuse. Or you may have destroyed more than just the traces.
                                          PlainBill
                                          • Bowline
                                            by Bowline
                                            06-11-2025, 10:13 AM
                                          • master3112
                                            by master3112
                                            07-29-2025, 01:55 PM
                                          • F R 2568
                                            Dell Latitude 5420 does not start (no post) need help to find the reason why
                                            by F R 2568
                                            Hello all,
                                            this is my first post, so if I make mistakes please do not hesitate to point them out, thank you in advance.
                                            I got a Dell Latitude 5420 (Service Tag: 7RFM6D3, Motherboard: GDF40 LA-491P Rev.: 2.0 (A01)) which does not start and I want to repair it. These are the symptoms:
                                            If the laptop is only connected to the AC adapter (battery removed):
                                            When I press the power button, the keyboard backlight and the display backlight are turning on. Caps key light is lightning, but key does not respond to pressing it.
                                            The power/battery...
                                            01-08-2025, 05:45 AM
                                          • diamon
                                            Looking for Dell Latitude 5520 / 5530 / 5540 RJ45 network connector replacement
                                            by diamon
                                            I have a Dell Latitude 5530 with a damaged RJ45 network connector. See the attached pictures.
                                            Have already searched on Farnell / Aliexpress / Ebay and had contact with several suppliers on Aliexpress and Ebay, but they cannot deliver this connector.
                                            Is there someone inside the EU, who has these connector(s) or perhaps defective motherboard(s) for these laptop models I have mentioned in the topic title.
                                            Pictures of these boards:
                                            Dell Latitude 5520 https://www.ebay.com/itm/256052956663
                                            Dell Latitude 5530 https://www.ebay.com/itm/125844181534
                                            Dell...
                                            02-28-2024, 12:51 PM
                                          • lalle-
                                            Dell G5 SE 5505 - "Invalid memory installed" after BIOS update.
                                            by lalle-
                                            Hello!
                                            I have a problem with a Dell G5 SE 5505 laptop that I hope someone can give me a few pointers on.
                                            [OK, it's not really a laptop, I'm running the motherboard on my desktop with only cooling, RAM and an M2 drive attached.]
                                            I had some performance issues, so I decided to update my BIOS from 1.7.0 to the latest version, 1.20.0.
                                            The computer restarted and the update dit not want to continue without a battery connected, even though I used dell's method of bypassing this requirement.
                                            I tried updating to a custom BIOS from Reddit user Satori_Nori https://www...
                                            08-11-2024, 02:01 PM
