Dell E172fpb
    • 31304
    Re: Dell E172fpb
    they are mostly small - the small ones have a lower lifespan.
    • 226BWytics
      • Sep 2012
      • 9
      • Spain
      #562
      Re: Dell E172fpb
      So, to be clear, you recommend replacing all the caps from both boards, correct?
      Cheers.
        • 31304
        Re: Dell E172fpb
        always - it saves having to open it all over again in a few months to a year.
        • Bowline
          by Bowline
          06-11-2025, 10:13 AM
        • Akhlz001
          by Akhlz001
          09-20-2025, 07:15 PM
        • master3112
          by master3112
          07-29-2025, 01:55 PM
          Dell Thunderbolt Firmware
          by SMDFlea
          Dell thunderbolt firmware, extracted from dell firmware update exe. Padded to 1MB.
          Some models have a choice of 2 different firmwares, it depends on the dell SKU.
          The SKU is in brackets (****)
          EDIT: NVM65...
          01-26-2025, 06:22 AM
        • dell_sadness
          Dell Latitude 3440 - Service tag ending in 0001 - Locked!
          by dell_sadness
          BIOS password locked Dell Latitude 3440 (Service tag B4HNJX3)
          Have extracted the BIN and want to know how to rebuild a clean BIOS
          I have come across the 8F8C patcher but not sure if that would work in my case as the service tag ends in 0001.
          I tried it and although the log states it patched several mentions of 8F8C in the BIN, I haven't flashed it yet in case such a patch wouldn't work.
          Have also tried to extract a clean BIN file from Dell's .exe BIOS updates using 'Dell PFS Extractor', but not confidently; Ended up with a 25MB file instead of the same 32MB...
          11-12-2025, 02:54 PM
