Viewsonic VG-930M Repaired..
  • Solder Boy
    • Nov 2006
    • 178
    but I still have a minor issue with it. It had a single bloated cap on the board. Original symptom was that it wouldn't turn it on, blue light was on for half a second then out it went.
    Thought my camera had taken the back side of the power/inverter board but I guess not.. oops!
    Anyway I replaced the bulged cap, checked the other ones.. the rest seem okay except for the big filter cap. It's reading about 1.5 on the ESR meter. I'm used to seeing them big ones read 0.
    Replaced that cap, turned the LCD on and it stayed on.. except I get a bit of a ripple on either side of the screen..sort of like a cycle. I wouldn't call it a flicker per se. Unit was made in 2006.
    Would that big cap cause the ripple I see on the screen? TIA
    www.bcrelectronics.ca
  • Rtech
    • Jul 2010
    • 1095
    Re: Viewsonic VG-930M Repaired..
    I find the norm for the big cap is 0.1 to 0.4,on the ESR meter for Caps,rated between 100-120uF at 400v,so I think you need to change it long term anyway,as it will not get any better, and MAY solve the ripple as well.
    • retiredcaps
      • Apr 2010
      • 9271
      Just curious. Does your ESR meter check capacitance in addition to ESR?
      --- begin sig file ---
      --- end sig file ---
      • Solder Boy
        • Nov 2006
        • 178
        Hi no it doesn't unfortunately.. haven't been able to find a decent capacitance meter that I can afford, the ones I have seen around here don't quite cut it for what I do.
        I can't find one that will go up to 3300uf.. the only one I found was one that went to 20uf if that.
        If someone can point me in the right direction it would be a help, because I realize sometimes the ESR might be good but the capacitance is not good.
        • retiredcaps
          • Apr 2010
          • 9271
          Well seeing how there are only 6 caps on board and you already changed the bloated one and the big one, I would change the other 4 to see if the ripple goes away.
          I don't know if this will solve your problem or not, but changing 4 caps would cost less than $2 in parts.
          If you live in the USA, there are some brand name capacitance meters made by Meterman for $25 (on ebay).
          http://cgi.ebay.com/Meterman-CR50-Ca...item2eafa2c2f1
          This one goes up to 20mF (milli farad).
          • Solder Boy
            • Nov 2006
            • 178
            Thanks for the info.. I haven't replaced the big cap yet.. I guess I wasn't clear enough about that. I will take your advice about the other caps.
            As far as that meter goes I'm in Ontario Canada.. I will see if I can find a dealer up here. Not too keen on having UPS or whatever and ship it here ( they charge $50 for duty brokerage) and as a Canadian we're only allowed to import $20 before we get slapped with duty and taxes.
            • lucky13
              • Aug 2007
              • 412
              I would not fuss about the big 450V cap ATM.
              Change out the other 3 electrolytic caps with low ESRs cap too. If the ripple does not go away, it is likely your main board (logic board).
              There are a couple of regulator ICs on the main board. Check with DVM to see they are 3.3v and 1.8v outputs and not jumpy.
              • smason
                • 1652
                Depends on which UPS service. Normally I say "do not ship UPS" to anyone I'm ordering from.
                However, Digikey.ca uses (a bit expensive for small orders) a UPS service which is overnight, and $8.00 flat rate. NO brokerage fee, or duty, even though they ship from MN.
                My last order got placed on Monday at 2:00 PM, caps were on my desk Tuesday at 10:00 AM
                • chth96
                  Is it possible to test small ceramic disc capacitor with analogue meter?
                  by chth96
                  I read EBOOK of Testing Electronic Component and found that
                  "In order to test the small blue resin coated ceramic disk capacitor which has 104 50v specification,it is possible to test this small ceramic capacitor by making use of analogue meter.
                  Set to times 10Kohm that has 12v output from the probe to check disorder of ceramic capacitor.
                  It is not uncommon that testing result of digital capacitance meter is okay,But It show shorted reading when you check it with analogue meter."
                  Is it really possible to test small ceramic disc capacitor with analogue...
                  03-09-2024, 10:03 PM
                • jorpec
                  Changing the scale of an analog meter
                  by jorpec
                  Hi
                  I want to change the scale of an analog meter, to monitor the charge of an li-ion single cell, so the needle at the end would point 4.2 volts and the 0 on the meter would point 2.5 volts or so, i tried to add diodes or a zener in series with the meter but the changes of the ambient temperature also changes the voltage value on the meter
                  I wonder how i can accomplish this so the meter would be precise at any temperature ?
                  Thnaks
                  01-23-2023, 10:37 AM
                  How an incandescent light and a ESR meter ** friend**have a machine blowing fuses
                  by sam_sam_sam
                  About a month ago we had a transformer jumper wire that burned in two different places between two transformers caused over $200 thousand dollars worth of damage to VFD drives at least 10 of them and a memory card and quite a few power supply as well
                  Now we have most of the equipment that got damaged back up and running except a feeder that has issues and we are waiting for some parts for
                  Now we also have another piece of equipment that was blowing fuses on the 110 volt controller switch circuit with the ā€œEā€ stops and one switching power (24 volt) supply and a transformer...
                  12-14-2023, 07:45 PM
                • Antonynl
                  What are typical ripple voltages on a laptop motherboard?
                  by Antonynl
                  I have here a HP pavilion hp 15-cs2975nd with a 1.095v power supply that is driven by a FDMF3035. I do see about 80mV of ripple on my scope. I searched through the datasheet to find possible values of the ripple but I don't understand the datasheet well enough.
                  So I have two questions:
                  1) what is the typical ripple voltages of gpu/cpu on a laptop or pc mobo?
                  2) what would be the max ripple of a FDMF3035 that drives an output of 1.095V?
                  Would be nice to have a rule of thumb of say a percentage of the supply voltage to be an acceptable ripple voltage....
                  12-09-2022, 06:51 AM
                • lostone
                  Looking for help with a Viewsonic VP230mb where the backlight comes on only momentarily
                  by lostone
                  Hello, I came here after finding some similar questions asked on other monitors and hope someone here can help me get an ancient Viewsonic VP230mp (23" 4:3 LCD) back to working condition.
                  First a little background, I have a background in computer and electrical engineering, and I'm smart enough to know I know nothing about LCD displays and how they work. For this topic I'm as green as they come.
                  When the display is turned on the viewsonic logo displays in the uppper left for 2 seconds then the screen goes black, the power LED is green (on) and when a computer is connected...
                  05-19-2024, 11:40 AM
