Dell W1700 LCD Rev00
    Re: Dell W1700 LCD Rev00
    how about donating the old board for the betterment of the cause?
    dave
      he is true I have found the 4 broken transistors with the 2 fused and the 2 condensers 220/25volt broken
      the 4 transistors in Italy I don't succeed in finding them, that model is? 4600?
      help me
      thanks
      mario
        @Bob
        ciao sono Italiano
        sul mio dell si sono rotti 2 caps+2 fuse e 1 Q80
        PerĂ² sostituirĂ² Q80+Q81+Q40+Q41 per essere piu tranquillo
        ditemi dove posso trovare il data sheet dei Transistor 4600?
        grazie
        mario
          @ Bob
          hi I am Italian
          on my dell 2 fused caps+2s and 1 Q80 are broken
          However I will replace Q80+Q81+Q40+Q41 to be calmer
          do tell me where I can find the date sheet of the Transistors 4600?
          thanks
          mario
            post a good close up pic of the board.
            maybe i can id the mfr of your mosfets.
              where do I find the 4600 MOSFET?
              THERE IS A SIMILAR
              thanks
              mario
                may be it is is a 2SC4600, but without a picture or the missing other markings no one can answer your question.
                  YOU/HE/SHE IS CLIMBED ON ON AN INVERTER LAMPS AMBIT T501045.00
                  For A mONITOR/TV DELL W1700
                    And' an IC to 8 pins
                      not sure if ther are mosfets......
                      the manu facture has a symbol like this @ only the a is a capital A.
                      there are a few more #'s too
                      the stamp on the chip is listed below. there are no markings under the chip.
                      also the company that sales the replacement has a better rev. so i would bet that they know the part # that works.
                      @ 4600
                      BD313K
                      dave
                        P/N should be BD313K. Try just BD3xx search.
                          dear friends
                          I thank you I immensely now see the datasheet and I will make you know
                          thanks
                          Mario
                            you excuse but I think it is not him the BD 313k it is a CASE TO3
                            WHAT I LOOK FOR IS A DUAL LINE 8 PIN
                            THANKS
                              I know what you are looking for. It is probably a dual mosfet from a unknown producer.
                              I have seen similar an BD4661 in a Scaleo View C19-4.
                              I was not able to find a datasheet, but may be the following ones may fit:
                              http://pdf1.alldatasheet.co.kr/datas...F/IRF7389.html
                              But only guesswork from my part, w/o data sheet it is always a gamble.
                                perhaps this is what I look for
                                I thank you
                                mario
                                  dave
                                  Well if put that way. I will donate it as long as I don't get stiffed with shipping charges and it will be donated as is. No complaints. Like I said before, I might have messed up one of the connectors when disassembling the unit and did not want to take a chance. Here typing on my NEW W1700 thanks a million I got it as junk and forked up the $80 at lcdparts.com.
                                  Thanks to all!
                                    Thanks to all!
                                    you stated that your board had buldging caps. this is different that the board i had, the caps on my boaed were not buldging at all. so the caps and fuses replacement should be all this board needs. if no one wants it , i will get it from you. the connector shouldn't be much of an issue. could you post a pic of it?
                                    also , i am glad that we all are working together on this......
                                    thanks
                                    dave
                                      @ Gonzo
                                      I have replaced the fused ones and the two condensers 220/25v
                                      I have turned on the monitor and the light of the power supply it quickly flashes because he/she sees a short-circuit
                                      in fact I have put an ohmmeter in parallel to the condensers and I read short-circuit
                                      I detach the 2 4600 (Q41 and Q80) and the short one there is not anymore.
                                      I deduce that it will need to also replace Q41 And Q80 however I don't succeed in finding them.
                                      I have decided to purchase the whole inverter on the site "LCD REPAIR LLC" to the price of 49,99$+16,50 $to send him/it in Italy and I will be surer
                                      Thanks to all of You
                                      Mario
                                        the first symptom of the defect of the Dell W1700 has been a red thin line to the center of the screen.
                                        after few months you/he/she is turned into a line black of 4mm. then to a following lighting you/he/she is quickly extinguished and all black has become.
                                        is you/he/she also happened to You?
                                        thanks
                                          Success
                                          I am happy to report that the replacement board T501045.00MSS from Moniserv fixed my monitor. I had replaced the caps and fuses but the fuses blew again. Moniserv told me they have a 30 return policy so if it did not fix my problem I could return it. So with the no risk (other than shipping costs) potential solution, I bought the board. It arrived very quickly and I now have my working monitor back. Thanks to all who helped.
                                          John
