Dell W1700 LCD Rev00
+ More Options
Posts
  • davetech
    • Dec 2006
    • 15
    #61
    Re: Dell W1700 LCD Rev00
    how about donating the old board for the betterment of the cause?
    dave
    • marketta
      • Nov 2007
      • 70
      #62
      he is true I have found the 4 broken transistors with the 2 fused and the 2 condensers 220/25volt broken
      the 4 transistors in Italy I don't succeed in finding them, that model is? 4600?
      help me
      thanks
      mario
      • marketta
        • Nov 2007
        • 70
        #63
        @Bob
        ciao sono Italiano
        sul mio dell si sono rotti 2 caps+2 fuse e 1 Q80
        Però sostituirò Q80+Q81+Q40+Q41 per essere piu tranquillo
        ditemi dove posso trovare il data sheet dei Transistor 4600?
        grazie
        mario
        • marketta
          • Nov 2007
          • 70
          #64
          @ Bob
          hi I am Italian
          on my dell 2 fused caps+2s and 1 Q80 are broken
          However I will replace Q80+Q81+Q40+Q41 to be calmer
          do tell me where I can find the date sheet of the Transistors 4600?
          thanks
          mario
          • kc8adu
            • Nov 2003
            • 8832
            • U.S.A!
            #65
            post a good close up pic of the board.
            maybe i can id the mfr of your mosfets.
            • marketta
              • Nov 2007
              • 70
              #66
              where do I find the 4600 MOSFET?
              THERE IS A SIMILAR
              thanks
              mario
              • gonzo0815
                • Feb 2006
                • 1600
                #67
                may be it is is a 2SC4600, but without a picture or the missing other markings no one can answer your question.
                • marketta
                  • Nov 2007
                  • 70
                  #68
                  YOU/HE/SHE IS CLIMBED ON ON AN INVERTER LAMPS AMBIT T501045.00
                  For A mONITOR/TV DELL W1700
                  • marketta
                    • Nov 2007
                    • 70
                    #69
                    And' an IC to 8 pins
                    • davetech
                      • Dec 2006
                      • 15
                      #70
                      not sure if ther are mosfets......
                      the manu facture has a symbol like this @ only the a is a capital A.
                      there are a few more #'s too
                      the stamp on the chip is listed below. there are no markings under the chip.
                      also the company that sales the replacement has a better rev. so i would bet that they know the part # that works.
                      @ 4600
                      BD313K
                      dave
                      • Spacedye69
                        • Nov 2005
                        • 698
                        • US
                        #71
                        P/N should be BD313K. Try just BD3xx search.
                        • marketta
                          • Nov 2007
                          • 70
                          #72
                          dear friends
                          I thank you I immensely now see the datasheet and I will make you know
                          thanks
                          Mario
                          • marketta
                            • Nov 2007
                            • 70
                            #73
                            you excuse but I think it is not him the BD 313k it is a CASE TO3
                            WHAT I LOOK FOR IS A DUAL LINE 8 PIN
                            THANKS
                            • gonzo0815
                              • Feb 2006
                              • 1600
                              #74
                              I know what you are looking for. It is probably a dual mosfet from a unknown producer.
                              I have seen similar an BD4661 in a Scaleo View C19-4.
                              I was not able to find a datasheet, but may be the following ones may fit:
                              http://pdf1.alldatasheet.co.kr/datas...F/IRF7389.html
                              But only guesswork from my part, w/o data sheet it is always a gamble.
                              • marketta
                                • Nov 2007
                                • 70
                                #75
                                perhaps this is what I look for
                                I thank you
                                mario
                                • leogetz2007
                                  • Nov 2007
                                  #76
                                  dave
                                  Well if put that way. I will donate it as long as I don't get stiffed with shipping charges and it will be donated as is. No complaints. Like I said before, I might have messed up one of the connectors when disassembling the unit and did not want to take a chance. Here typing on my NEW W1700 thanks a million I got it as junk and forked up the $80 at lcdparts.com.
                                  Thanks to all!
                                  • davetech
                                    • Dec 2006
                                    • 15
                                    #77
                                    Thanks to all!
                                    you stated that your board had buldging caps. this is different that the board i had, the caps on my boaed were not buldging at all. so the caps and fuses replacement should be all this board needs. if no one wants it , i will get it from you. the connector shouldn't be much of an issue. could you post a pic of it?
                                    also , i am glad that we all are working together on this......
                                    thanks
                                    dave
                                    • marketta
                                      • Nov 2007
                                      • 70
                                      #78
                                      @ Gonzo
                                      I have replaced the fused ones and the two condensers 220/25v
                                      I have turned on the monitor and the light of the power supply it quickly flashes because he/she sees a short-circuit
                                      in fact I have put an ohmmeter in parallel to the condensers and I read short-circuit
                                      I detach the 2 4600 (Q41 and Q80) and the short one there is not anymore.
                                      I deduce that it will need to also replace Q41 And Q80 however I don't succeed in finding them.
                                      I have decided to purchase the whole inverter on the site "LCD REPAIR LLC" to the price of 49,99$+16,50 $to send him/it in Italy and I will be surer
                                      Thanks to all of You
                                      Mario
                                      • marketta
                                        • Nov 2007
                                        • 70
                                        #79
                                        the first symptom of the defect of the Dell W1700 has been a red thin line to the center of the screen.
                                        after few months you/he/she is turned into a line black of 4mm. then to a following lighting you/he/she is quickly extinguished and all black has become.
                                        is you/he/she also happened to You?
                                        thanks
                                        • johnstof
                                          • Oct 2007
                                          #80
                                          Success
                                          I am happy to report that the replacement board T501045.00MSS from Moniserv fixed my monitor. I had replaced the caps and fuses but the fuses blew again. Moniserv told me they have a 30 return policy so if it did not fix my problem I could return it. So with the no risk (other than shipping costs) potential solution, I bought the board. It arrived very quickly and I now have my working monitor back. Thanks to all who helped.
                                          John
                                          • Bowline
                                            by Bowline
                                            06-11-2025, 10:13 AM
                                          • ttmi100x
                                            HANNSG Hi221 -- 2 secs to black feat. CCFL flicker & "burn" marks on power board
                                            by ttmi100x
                                            Greetings everyone,
                                            I have a HANNSG Hi221 monitor that exhibits two seconds to black issues (backlight goes off, display is still on as confirmed by shining a flashlight on it) with some additional oddities...
                                            The monitor failed on me with a standard "2 seconds to black" some time ago prompting me to initially replace most of the electrolytic capacitors (some of them were bulging/leaking).
                                            Things kinda sorta worked for a night, then the problem returned along with some flickering and "buzzing" noises.
                                            Upon closer inspection...
                                            07-31-2024, 06:36 PM
                                          • DanPoka
                                            by DanPoka
                                            02-15-2025, 05:05 AM
                                          • F R 2568
                                            Dell Latitude 5420 does not start (no post) need help to find the reason why
                                            by F R 2568
                                            Hello all,
                                            this is my first post, so if I make mistakes please do not hesitate to point them out, thank you in advance.
                                            I got a Dell Latitude 5420 (Service Tag: 7RFM6D3, Motherboard: GDF40 LA-491P Rev.: 2.0 (A01)) which does not start and I want to repair it. These are the symptoms:
                                            If the laptop is only connected to the AC adapter (battery removed):
                                            When I press the power button, the keyboard backlight and the display backlight are turning on. Caps key light is lightning, but key does not respond to pressing it.
                                            The power/battery...
                                            01-08-2025, 05:45 AM
                                          • diamon
                                            Looking for Dell Latitude 5520 / 5530 / 5540 RJ45 network connector replacement
                                            by diamon
                                            I have a Dell Latitude 5530 with a damaged RJ45 network connector. See the attached pictures.
                                            Have already searched on Farnell / Aliexpress / Ebay and had contact with several suppliers on Aliexpress and Ebay, but they cannot deliver this connector.
                                            Is there someone inside the EU, who has these connector(s) or perhaps defective motherboard(s) for these laptop models I have mentioned in the topic title.
                                            Pictures of these boards:
                                            Dell Latitude 5520 https://www.ebay.com/itm/256052956663
                                            Dell Latitude 5530 https://www.ebay.com/itm/125844181534
                                            Dell...
                                            02-28-2024, 12:51 PM
