Acer x193w with Darfon B092-XXX inverter - assistance needed! [lotsa pics!]
  • jetadm123
    • 2169
    #61
    Re: Acer x193w with Darfon B092-XXX inverter - assistance needed! [lotsa pics!]
    The pinout for the MP1008ES is on page 9.
    • jeffescortlx
      • May 2011
      • 40
      #62
      Thanks for the help.
      Turns out it has a open lamp.
      Panel model is M190PW01.
      Any way to trick the inverter circuit to ignor the bad one? It's not really worth buying a new panel for it.
        @jeff: You mean that the wire to the lamp is bad or lamp is worn out with blackened ends?
        • jeffescortlx
          • May 2011
          • 40
          #64
          It has a bad CCFL lamp, that will not light at all. The inverter goes into shut down once it knows it will not come on (over voltage on transformer secondary).
          I did find parts relativity cheap. But I've always wanted to do my own DIY LED conversion. So I think I'm going to use this as an opportunity to do just that.
          • timg11
            • Dec 2013
            I have this exact same monitor with the same inverter that just went bad.
            It started making a whining noise one day and the screen got very dim, then went out completely. When powering up now, I get the squeal from the inverter for a few seconds, then it shuts down.
            It's been a good monitor and I hate to trash it, so I'm having a look to see if there is any practical fix. I've taken it apart and have the inverter board accessible. The oscilloscope shows approx 24V DC and a flyback waveform (momentarily) on the primary of the CFL transformer. The high side secondaries are covered in glue and I haven't tried to probe them yet. The text on the topside of the board says those outputs are about 1KV.
            I don't have spare CFL tubes to swap out. Is there any way to measure the signal at the bottom end of the CFL tube (across the sense resistor) and determine if the problem is the tube or the inverter?
            I have gathered that I can't just unplug 3 of the 4 tubes and test them individually since there is an open-tube protection circuit.
            • selldoor
              Slow Learner
              • Dec 2010
              • 7870
              #66
              See budms signature files above - you can make a test bulb from a cfl.
              First test is usually the secondary resistance on the inverter transformer?
              If they are ok then it is on to bulbs and wiring.
              • Davi.p
                Hobbist Tech
                • Sep 2009
                • 4343
                • Italy - Milan
                #67
                One possible cause is ballast blue caps, is there a way to test lamps by disabling the protection, you must write here the marking on the inverter IC.
                • timg11
                  • Dec 2013
                  I did some investigating with the oscilloscope, and found that the power supply to the inverter (around 24-28 VDC) looked really bad when the inverter tried to start up:
                  (Note - probe type is not recognized by scope - multiply voltages by 10)
                  There shouldn't be that type of waveform on a power supply, so after considering the name of this forum, I inspected the capacitors (these were 220uF 35V - effectively in parallel because the inductor shown on the silkscreen was replaced with a jumper). They were a bit swollen, so I replaced them.
                  The originals were CapXon - I replaced them with Nichicon.
                  After that the DC going into the inverter was clean and the whining noise was gone, but the backlight still doesn't work.
                  Probing on the high side of the drive transistor going to the inverter transformer (collector? drain? ... don't know - I have not been able to find a schematic for the Darfon supply), I see a waveform run for a couple seconds and stop. This repeats 3 times, then stops and a yellow LED comes on in the switch panel.
                  Waveform at inverter drive (20uS/Div)
                  Waveform at inverter drive (50mS/Div)
                  So there is still something wrong that is shutting down the inverter after 3 tries starting up.
                  The inverter IC/Transistor (5 pin DPAK on back of board) is labeled:
                  NIKOS P2804ND56
                  U145J009B
                  The other IC in the inverter area (SOP package) is labeled B113715 FC27G P0810
                  • selldoor
                    Slow Learner
                    • Dec 2010
                    • 7870
                    #69
                    Pictures of your boards would help but you need to read posts 4/5 and test the
                    resistance on the secondary windings of the inverter transformers.
                    • Davi.p
                      Hobbist Tech
                      • Sep 2009
                      • 4343
                      • Italy - Milan
                      #70
                      that P/N for ic is maybe a fucking chinese unknown part... i don't find nothing..
                      • timg11
                        • Dec 2013
                        My board is identical to the photos in the first post <https://www.badcaps.net/forum/showpost.php?p=120538&postcount=1>.
                          Check the high voltage windings of the inverter transformers as suggested, DARFON is known for having bad inverter transformers, I replaced many of them.
                          • timg11
                            • Dec 2013
                            After looking at previous posts, the inverter IC is BIT3715, and the FET driver is P2804ND5G. The text on the parts was somewhat unreadable on my board, but based on previous posts, I'm pretty sure they are the same.
                            Next step is to test the transformer windings, but I'll have to get back to it in a few days.
                              You should make a couple of test lamps to help you narrow down the problem so you will not waste lots of time trying to fix the board if the board is not bad like this example here:
                              https://www.badcaps.net/forum/showth...t=33720&page=3
                              • zonaotaco
                                • Feb 2021
                                • venezuela
                                #75
                                buenas tardes mi nombre es marcos soy de venezuela... y estoy en este foro para ver si me pueden ayudar con un problema q tengo con mi monitor especificamente la fuente de poder modelo DARFON B092-XXX Quiere camiarlos con condensadorles y los retire para los estravie y quiera saber quien me puede ayudar con decir los voltales y uf q cada uno de ellos se los agradeceria....
                                  by momaka
                                  03-12-2025, 03:42 PM
                                • flibidy
                                  Magnum IA.100 Amplifier Switches on, No Output, Possible Input Side fault?
                                  by flibidy
                                  I have here a Magnum IA.100 which belongs to my parents.
                                  The unit powers on & when the relay kicks in, you get a pop from the speakers (this might sound weird but is usual behavior for this amp). However, you get nothing coming through it from any of the inputs & no pops and crackls from any of the controls.
                                  Because of the sound from the speaker when the amp turns on I have assumed that the output section probably works but I could be wrong & I'm not sure how to test that side of things further.
                                  What Ive done........
                                  01-01-2025, 01:26 PM
                                  Copy DMI info easily with Hex editing software and Macro script
                                  by SMDFlea
                                  Copying DMI information from an old bios to a new one is difficult for some members, often they have no experience with a hex editor,or some that have tried find it too hard.There is an option to make things easier for those members so that they don`t need to post their own bios backup for the DMI copying.
                                  Experienced bios modding members can help by posting in other threads the DMI offsets,macro script generated by the software and a download link to the software at softpedia mentioned in this guide,or post your macros in the comments here with a link to the bios request thread ....
                                  02-28-2023, 02:14 PM
                                • ZixuTech
                                  Dell XPS 15 9570 - LA-G341P - Power cycling after liquid damage and blown ISL88738
                                  by ZixuTech
                                  I am dealing with this LA-G341P, which had heavy liquid damage around the Audio board, Battery charging circuit. I went and cleaned liquid areas and left the audio board disconnected.
                                  It had blown PQ1900/02/3 as well as a trace on PU1900. I replaced all 4, and now it turns on and switches off. With a connected battery, it turns on and stays on for a while, even loading the system, then cuts off suddenly.
                                  Charger only - without a battery, the PQ201/PD200 area gets hot. I can see the chipset and CPU also warm up for a second trying to pull up to 2A, then cust off....
                                  10-22-2022, 10:33 PM
                                • b0n3v
                                  [Help]Reading EC - T14 G1 AMD with RT809h
                                  by b0n3v
                                  Hello everyone!
                                  I try to read the EC ITE/IT8300FN where the bios password is stored.
                                  The laptop is Lenovo T14 G1 AMD Ryzen 4650U, the MB is NM-C801.
                                  I can't read the chip with RT809H with ITE board and PFC cable. Might be I need to do something more to enable programing mode(SPI Enable?).
                                  I saw the post in another forum for T14s AMD (different MB but same EC configuration and pinouts) and one user successfully read and write the the same chip with SVOD3.
                                  Some details what i did:
                                  Battery and CMOS battery is unplugged.
                                  I click Read and then...
                                  05-15-2023, 04:02 AM
