Sony STR-DN1030 Distorted audio when Volume adjusted
  • R_J
    • Jun 2012
    • 9627
    Re: Sony STR-DN1030 Distorted audio when Volume adjusted
    If R709 was open, you need to look at how it would open, Q703 would short C~B so +59 volts was likely on the base. so I would check and compare the values of R707,706,708 and Q701,702, if they seem to be ok, the next path is through ic701
    • jason123
      • Oct 2015
      • 1154
      Actually... I think you're on to something. The datasheet for the MP1620 is cryptic, but it sure shows i got the wrong part. The MP1620 should have been -Y, but i seem to have gotten -P installed... -Y is on order. Hope that does it. I will keep you updated. Thank you!
      • CapLeaker
        Leaking Member
        • Dec 2014
        • 8352
        Yep, it's a dumb mistake that can very easily happen as not always folks are aware about the gain value (hfe).
        When I source replacement transistors with something else than stock, in one case I bought 25 pieces and matched a pair to the original spec on the working channel, then made another matched pair and exchanged the other channel too. I think the transistors also had to be backwards mounted, since the leg configuration was opposite, but that didn't matter, since there was no heat sink involved.
        So when you did the transistor pair (NPN and PNP), where they both having different gains, or just one transistor?
        • jason123
          • Oct 2015
          • 1154
          Sorry, I don't understand the question. I simply bought a pair on eBay, not sure matched or not, but I didn't notice the hfe rating. The current system on all channels, they seem to use -P option for MN2488, and -Y for MP1620
          Do I need to match these and if so what do I need to do? is it impedance measurement? I just ordered one MP1620-Y
          • R_J
            • Jun 2012
            • 9627
            These transistors are no longer manufactured by sanken, so who manufactured the ones you got?
            The Sony sub part number was 8-749-010-26 (MP1620-OPY-M) and 8-749-010-25 (MN2488-OPY-M)
            • CapLeaker
              Leaking Member
              • Dec 2014
              • 8352
              I had to match mine up, because the originals were not available for a long time (45 years) and the replacements I've chosen had a pretty wide hfe span. It's just an example I had to go through for one old amp I had to go through. I just hope this time you get the right ones.
              So the MN2488 is exact the same than it supposed to be? It's just the MP1620 that was / is wrong?
              • jason123
                • Oct 2015
                • 1154
                I am buying Sanken parts from Ebay.
                • jason123
                  • Oct 2015
                  • 1154
                  Yes, based on the markings on the part
                  • jason123
                    • Oct 2015
                    • 1154
                    When I try to see what these Sony Numbers translate to as far as manufacturer numbers, I see them listen as, for example: 8-749-010-26 is MP1620 with O, or Y, or P marking on the parts. All of these are very different hfe.
                    See:
                    https://www.genuinereplacementparts....kaAgdtEALw_wcB
                    https://www.unlimitedapplianceparts....-8-749-010-26/
                    https://www.amazon.com/-/es/Sony-OEM.../dp/B00FZXHHCQ
                    They treat these hfe differences as unimportant!
                    So is there a way to know what 8-749-010-26 is for a Sanken manufacturer number? which hfe is this number?
                    I'm going by the marking on the part I removed, which is Y. The one I erroneously installed is making P (less hfe.) I've ordered the Y. Do you think this is the smoking gun?
                    Y marking (the one use on all other channels as hfe range of 15,000 - 30,000
                    The P marking (the one I accidently installed) has hfe of 6,500-20,000
                    You'd think the distortion should not happen just because of this?
                    • CapLeaker
                      Leaking Member
                      • Dec 2014
                      • 8352
                      When replacing transistors volts on base / emitter is important. Hfe is important too. Depending on circuit, you might even want to match them! In this circuit I can see you don’t need a perfectly matched pair. But I really wouldn’t an NPN and PNP pair together that has a 100% difference in gain. I know of circuits where the Hfe on transistors went so low due to age, that the circuit stopped working as designed. But if I would measure the transistor in diode mode, I couldn’t tell the difference and things looked good. It only came about until I took the transistor out and started to measure hfe. Depending on circuit, yes, hfe does matter, specifically in parallel as one works harder than the other.
                      I’ve seen amps where the NPN and PNP pair were quite a bit off between them, but not like 100% off. That data sheet would suggest like 250% difference between that model what would be considered normal. Most other transistor data sheets do that too or even leave the maximum out. Look at a MJE15032.
                      If you want to shotgun things you’d need to replace a few resistors and a preamp stage too. If you really wanna know what’s going on and why, an oscilloscope is your best friend.
                      • jason123
                        • Oct 2015
                        • 1154
                        When replacing transistors volts on base / emitter is important. Hfe is important too. Depending on circuit, you might even want to match them! In this circuit I can see you don't need a perfectly matched pair. But I really wouldn't an NPN and PNP pair together that has a 100% difference in gain. I know of circuits where the Hfe on transistors went so low due to age, that the circuit stopped working as designed. But if I would measure the transistor in diode mode, I couldn't tell the difference and things looked good. It only came about until I took the transistor out and started to measure hfe. Depending on circuit, yes, hfe does matter, specifically in parallel as one works harder than the other.
                        I've seen amps where the NPN and PNP pair were quite a bit off between them, but not like 100% off. That data sheet would suggest like 250% difference between that model what would be considered normal. Most other transistor data sheets do that too or even leave the maximum out. Look at a MJE15032.
                        If you want to shotgun things you'd need to replace a few resistors and a preamp stage too. If you really wanna know what's going on and why, an oscilloscope is your best friend.
                        I'd love to know what's going on.. however with the stacked boards assembled it's fairly tough to probe the main board without shorting the heck out of everything. So that's the risk I'm trying to avoid. But I do have an Oscilloscope!
                        Are the smaller transistors and their associated resistors what you're referring to as "Pre-Amp"? resistor values were checked to be within tolerance so that leaves the 2 small-sig transistors? Anything in particular that I have to get, since the SONY part numbers don't have good manufacturer number cross-reference?
                        • CapLeaker
                          Leaking Member
                          • Dec 2014
                          • 8352
                          Fix that what you know isn’t right then go from there. I am not a shotgun fan as such.
                          • jason123
                            • Oct 2015
                            • 1154
                            Very unexpected, but i put the "new" part in and now i am getting protection error! Will swap main transistors between left and right and see if that follows the new Y MP1620
                            • jason123
                              • Oct 2015
                              • 1154
                              Ok swapped FR transistors to the problematic channel (FL) and distortion is still happening on FL. Resistor values are good. I dont have a way to test small BJTs. Should i replace all smaller BJTs? Any matching there?
                              • budwich
                                • Jul 2015
                                • 3097
                                Hopefully, you can get back to having the one working front channel (FR). IF so, before you go further in "tearing apart" your board / components, do some "simple resistance" checks. Unplug / disconnect the receiver from power. Get access to the main board as outlined in the SM (page 33/34) which shows the FR / FL. Choose "wisely" various points to compare a resistance measurement across the two different circuits... you aren't looking for "absolutes"... you are looking for "similar". Yes, I know you indicated you did an "impedance check" but that was likely at the outputs and was a "gross" check of the "entire circuit". The checks that you want to do now, are more "partitioned" to try isolate a group of components / portion of a circuit that you can then focus on specifics (individual components) there after. It might not show anything BUT something could readily pop out. It basically costs nothing other than a bit of time.
                                The reference points for the checks could be grounds or powering or even in / out lines depending where in the circuit you choose. The thing about doing this method is there is little to no danger in cause damage to the board / circuit (short, breaking track, etc) because nothing is being powered.
                                Study the circuit diagram to choose your points to isolate / test various sections that can be readily compared across the good and bad front channels. Make notes on what you observe from your meter and which test points you were using at the time.
                                Since you have "touched" some of the active component, that area might be your first focus.
                                Hope this helps.
                                • budwich
                                  • Jul 2015
                                  • 3097
                                  As an example of a possible check. do a resistance measurement to ground of the voltage outputs on the IC701 (page 34)... pins 2,3 and 13,14... these are signal outputs going to the subsequent components in the output stages. You can compare the meter readings / response to see if there is significant difference. Go from the result.
                                  Note: if you can't readily get at the IC points move along the diagram to a readily accessible area / component and measure there.
                                  • jason123
                                    • Oct 2015
                                    • 1154
                                    So, one additional observation that may mean something to you: when the system is playing, Volume level 1 for this FL channel is very high compared to the other channels that you can barely hear anything out of.
                                    Here is today's work:.. swapped main BJTs, Smaller pre-amp ILIMITER (Q702, and Q701) between the FR (Good) to FL. No change. FR still works fine, FL still has issues.
                                    Verified R707, R706, R709, R710 all comparable to FR and match values on schematic.
                                    Seems the only thing that remains unchecked:
                                    Post amp circuit and IC701
                                    Thoughts?
                                    • budwich
                                      • Jul 2015
                                      • 3097
                                      capacitor issue maybe. Again, the suggested resistance "probing" may point to an area of difference including ic701.
                                      additionally, with the "new observation", get your scope going. Feed in a 1khz tone of known value. Look at the resulting output characteristic.... voltage / frequency / appearance.
                                      • jason123
                                        • Oct 2015
                                        • 1154
                                        Started with impedance measurement around IC701. All impedance measurements were referenced to pin 7 (gnd). No significant differences between IC601. Some pins had caps so impedance was fluctuating... but similar to bad channel.
                                        Attempted 1khz sinewave input, however relays were not routing signals unless all boards were connected and that gives almost zero room to probe with 3 board stack.
                                        Finally went for the jugular and swapped ic701 with ic601. Problem remained on the FL channel. Checked resistor and cap values around the IC. All seem to check out.
                                        That leaves post amp circuit? Not sure how that could be it but i am new to this audio stuff so help is very much appreciated
                                        • budwich
                                          • Jul 2015
                                          • 3097
                                          I think you misunderstand what I was saying about the 1khz input. You mentioned that you have distortion in the original post. What does that mean? Further, you indicate that you have good sound out of all channels other than FL.... that means you are able to input sound somewhere and output it somewhere... so that is what I am asking you to do. Input a 1khz sound (from a computer file / cd disc / dvd audio setup disc... whatever). Look at that input on your scope to ensure that you are reading exactly what is being input (it should look like a nice sound wave with known frequency and voltage specification). Then look at the resulting output wave form on both a good channel and the bad channel. What characteristic is your scope showing.... that is what I am referring to. From that, this will tell us what the "distortion" that you are conveying... ie. voltage clipping, square wave, no wave, no set frequency, what.
                                          Further, the FL and R are only on ic701 so you likely only need to be concerned with those.
                                          Hopefully, your scope view of the output will provide more information to add to your observation about loudness of the bad versus others.
                                          Further note, that the tests suggested on IC701 were just samples... as mentioned, other strategic points can be used to compare across R and L circuits to look for differences.
                                          • crackedprint
                                            Sony HCD-HX80R Amplifier Volume Control Problem
                                            by crackedprint
                                            I have a strange fault on a Sony amplifier. The volume control varies the display from MIN, then 1 up to 30 and then MAX as expected. At MIN there is no sound. However, at 1 it is quite loud and increasing above 1 does not change the sound level.
                                            I have tried a Cold Reset as per the service manual.
                                            I have looked at the I2C clock and data to volume control chip IC501 (BD3499FV). Data is only sent to IC501 when the volume is set to MIN or 1. At any other setting no data is sent to IC501.
                                            I have looked all the way through the service manual and tried many online...
                                            01-21-2025, 12:18 PM
                                          • ajvpb
                                            Denon 3313CI Distorted Audio FL+FR
                                            by ajvpb
                                            Hobbyist repairman here so I've reached the end of my troubleshooting abilities. The audio out of the FL+FR speakers is very distorted and almost unintelligible. BUT! That only applies to digital audio; Analog plays through just fine. The distortion carries to headphones if those are plugged in with audio from a digital source. All other speaker channels play fine regardless of digital or analog.
                                            Previous experience with similar distorted audio has been bad resistors on the amp output - Could bad smd resistors on the hdmi board cause the same problem? My understanding...
                                            02-22-2023, 05:21 PM
                                          • samson7point1@yahoo.com
                                            Help troubleshooting an audio problem with an RCA SGT-250 CED Player
                                            by samson7point1@yahoo.com
                                            The Problem: This player has a toggle switch to select between Stereo, Mono R, and Mono L. Regardless of the setting it outputs the sound to both the L&R audio jacks. In the Mono R position, the audio output level is normal (from both the L and R audio output jacks), in the Stereo position the audio output is about half the volume, and in Mono L, it's about 3/4 the volume. Something about putting it into Stereo mode is causing the volume to drop significantly and I can't figure it out.
                                            The player processes the audio signal using two different reference frequencies. The "R"...
                                            04-30-2024, 11:22 AM
                                          • UserXP
                                            Vintage SONY Digital Clock Radio ICF-C12W no audio
                                            by UserXP
                                            Dear all,
                                            I have this old radio clock by Sony from the early 80s, I guess. The clock display works, but is dim, the function board appears to be OK - but the radio unit shows no signs of life. It doesn't produce a single noise, crack or anything from either FM or AM band. It's like it doesn't even power up.
                                            i opened the radio and it is full of some TRACON gray capacitors. They only have their negative strip printed, voltage and capacitace markings - no series, no temperature marking, nothing else.
                                            My question is, do you know of this brand of capacitors and how bad are...
                                            07-21-2025, 08:35 AM
                                          • karthur
                                            Vizio D65x-G4 Volume changes on its own
                                            by karthur
                                            On this Vizio D65x, the volume will change on its own. I don't mean like during commercials where the volume will increase. I mean its like the (+) volume button on the remote is pressed and the actual volume dialog is displayed on the screen going up. It will do this, then the volume may start going down. It might go all the way to "0"or it might stop at a different number, then start going back up. The whole time its doing this, the volume dialog is shown on the screen.
                                            It wont do it until it has been "ON" for 20 or 30 minutes, so it does seem to be heat related....
                                            06-05-2025, 08:13 AM
