Sony ICF-C12W Radio Clock schematics (power)
    • 30919
    Re: Sony ICF-C12W Radio Clock schematics (power)
    ok
    it's pins 41 and 42 on the chip need to be re-wired for 24 hour mode.
    41 would need to be disconnected and 42 would need to be jumpered to a different display pin.
    you cant use the buttons to switch between 12 and 24 hour mode
    • UserXP
      • Apr 2012
      • 322
      • Serbia
      #42
      Here it is, assembled and functional. After 40 years, it works and looks great!
      Thanks, everybody, for helping me out.
      When there is an 80' music hit on a local radio station played through this clock radio, it's like a time capsule.
      • UserXP
        • Apr 2012
        • 322
        • Serbia
        #43
        One more question. Is the transformet in this unit a center tap one, and would it be designated as 13V, 6,5-0-6,5?
        • eccerr0r
          Solder Sloth
          • Nov 2012
          • 8662
          There's a tap for the filament heater, does not appear to be center tapped however - off center tap...
          • UserXP
            • Apr 2012
            • 322
            • Serbia
            #45
            So finding a suitable 220-240VAC transformer with that specific output will be next to impossible?
            I found a 6-0-6 transformer which gives a total of 12V, so I hoped it would work. But it would be off-center, right? Would it work or would it over/undervolt some of the components and damage them?
            • eccerr0r
              Solder Sloth
              • Nov 2012
              • 8662
              Chances are if it's 12V center tapped, the center tap would be 6V and way too high for the heater.
              • UserXP
                • Apr 2012
                • 322
                • Serbia
                #47
                I didn't know there is a heating element inside. A heater?
                So, could a resistor be inserted between the center tap 6V output to drop the voltage to the required 5.2V?
                I guess the output voltage of the PT would also drop a bit after load is applied.
                I found several PTs at a local shop which are dual 6-0-6 volts, a total of 12V of various VA, power and current. They are all 220VAC 50Hz input.
                I tried leaving the clock radio running for almost six hours to test the clock. It works flawlessly after the Pin12 mod, but the rated 100W power converter I used became hot, even though it had just 5W of load applied. I wouldn't leave it running 24/7.
                Any thoughts on this power modification? Schematics suggest output should be 11V and 5.2V center tap. That would seem to be a 5.2-0-5.8 transformer, right?
                  • 30919
                  try looking for a "bell transformer", 4.5v - 0 - 4.5v
                  aka 9v centertapped.
                  • UserXP
                    • Apr 2012
                    • 322
                    • Serbia
                    #49
                    Bell transformers are what I looked for and found. The original PT is also of that type. It's the proper rating that needs to be selected.
                      • 30919
                      how big is the original one?
                      • UserXP
                        • Apr 2012
                        • 322
                        • Serbia
                        #51
                        It is small. Maybe 2.5x2.5x4cm roughly. The longest dimension is the base with holes for being fixed to the casing with two screws. Based on its small size, it is probably a 5W, 2x0.125A or so. I'm just guessing.
                        • eccerr0r
                          Solder Sloth
                          • Nov 2012
                          • 8662
                          Since you have the step down working, what is the voltage of the winding and tap?
                          • UserXP
                            • Apr 2012
                            • 322
                            • Serbia
                            #53
                            I will check with my multimeter. I followed the traces, black wire is A, red wires are C (half voltage) and D (full voltage). I see that black goes through a resistor to the first pin of the display marked as F. Is that the filament (heater) contact you were referring to?
                            • UserXP
                              • Apr 2012
                              • 322
                              • Serbia
                              #54
                              Could the marking T6-13CH on the original mean something like Transformer, center tap 6V, total voltage 13V, CHina? Maybe it's a 6-0-7, but Sony marked the two output voltages on it. In that case, a 6-0-6 12V transformer would provide the correct voltage for the 6V center tap, but slightly lower overall voltage (12V instead of 13V)?
                              The schematics also show the pin setup for the 24 hour mode. Pins 41 and 42 indeed need to go to different pins of the display, plus Pin18 to 11V connected. It looks tempting, but I would need to tear or break the leads and rewire the pins. It's just an idea, but the power transformer mod would be the priority, I don't mind the AM/PM symbols that much.
                              What are your thoughts on this PT label?
                              • R_J
                                • 9514
                                The original transformer is likely closer to a 10v CT, 5-0-5, this will give you around 13VDC. The AC voltage listed for the transformer is not the same as the DC voltage after it is rectified and filtered.
                                • UserXP
                                  • Apr 2012
                                  • 322
                                  • Serbia
                                  #56
                                  Thanks. If that's the case, then teplacing it wil be "go to eBay and search", which would bring Chinese sellers whose pictures of the products are usually generic/stock, plus the 50 day long shipping.
                                  The lowest dual output PTs I can find in a local electronics shop is 6-0-6. :/
                                  • eccerr0r
                                    Solder Sloth
                                    • Nov 2012
                                    • 8662
                                    Again you have a multimeter, measure the voltage, go from there. Don't want to hook up your filament and have it burn out, might well throw out the whole clock if this happens...
                                    • UserXP
                                      • Apr 2012
                                      • 322
                                      • Serbia
                                      #58
                                      I measured it.
                                      On the diagram, these wires are labelled:
                                      A for black
                                      C for one red wire
                                      D for the other red wire.
                                      The voltage between A and C is 5.7V.
                                      The voltage between A and D is 5.9V.
                                      The voltage between C and D is 11.7V.
                                      This is with load applied as the device turns the display on immediatelly after powering on.
                                      I suppose we need to achieve the 5.7 and 11.7 values (although, according to schematics, they should be slightly lower). But then again, it is powered through a step down converter, maybe it's not producing 110-120V precisely.
                                      Do these measurements help? Attached is the size of the transformer.
                                      • UserXP
                                        • Apr 2012
                                        • 322
                                        • Serbia
                                        #59
                                        This is measured exactly at the point the three output wires are soldered onto the PCB. The rotary switch was set to OFF, only the display switched on.
                                        • eccerr0r
                                          Solder Sloth
                                          • Nov 2012
                                          • 8662
                                          Well you got your answer now, go get something that matches when you feed it your desired input voltage and fits in the allotted space!
                                          • shelby5041
                                            clock radio / radio lifespan?
                                            by shelby5041
                                            hi
                                            ive got a modern digital clock radio approx 15yrs old
                                            my question is how long can a clock radio or a simple radio last ss farcas operating hours?
                                            since elec components have limited hour lifecspan i would imagine the radio or clock radio would eventually fail.
                                            the reason i ask is because i have my clock radio on radio function 24/7 for the past 7 years and its still working fine....i leave the radio on ..never turn off past 7years...thats approx 60000 hours
                                            it uses very little power just a few watts i would imagine that may have something...
                                            09-14-2024, 03:30 AM
                                          • littlejohn
                                            Emerson clock radio transformer
                                            by littlejohn
                                            Hello I have a Emerson research clock radio model CKS3516C and the transformer went out on it ,the label on the clock radio says 120VAC 6 watt backup battery DC 3v CR2430. the numbers on the transformer ST3591C-13SEN which I can't find anywhere for it. Can anyone please tell me the AC output voltage. Thanks
                                            08-30-2023, 07:13 PM
                                          • TinkerTron
                                            Schematic vs. Reality: Where Are the Resistors on My Sharp Clock Radio? Model FY-70CH
                                            by TinkerTron
                                            Hey everyone,
                                            I'm currently working on a mid-70s Sharp Electronic Digital Clock Radio, Model FY-70CH. I found the service manual online, printed it out, and have been studying it for a while. My main reasons for tackling this are: (1) I want to learn electronics and figured I'd start with something I had on hand, and (2) I want to fix its issues. Right now, the radio sounds awful, has about 5V DC at the speaker terminals, and the alarm time setting doesn't work. But I'm not asking how to fix these problems.
                                            Instead, here's what's been bugging me so far:
                                            The schematic...
                                            03-06-2025, 02:03 PM
                                          • mikey5791
                                            Sony CFS-5000S radio cassette player no FM reception
                                            by mikey5791
                                            Hi forum members,
                                            In the past i have had many helpful hints from generous forum members in diagnosing and solving issue related to most of my electrical things.
                                            Fyi, i have been keeping this unit of Sony radio cassette player as the cassette belting has worn off but the radio has been working fine before. Recently, out of a sudden i found out i can't get any radio reception at all (no signal from FM,MW or SW band) except some buzzing warp noise from the speakers.
                                            I opened the casing inside and checked for any dry solder, burned component or loose wires...
                                            02-24-2023, 03:48 AM
                                          • denisten
                                            Sony STR-DB870QS standby transformer
                                            by denisten
                                            Hi everyone, i am a newbie here and i hope i will find the help i need. I have the above mentioned receiver with standby transformer's primary coil damaged. I have searched the net without success to find any tech data about this transformer. I have only the Sony part number1-437-313-11 and TAM Malaysia M0126. I guess i could find replacement for it, but i need to know the secondary coil voltages and VA. It is 220v on the primary. It has 5 pins on the secondary, the outer two are not used and i have 6.5 ohms between pins 2and 4, 3,9 ohms between 2 and 3, and 3,6 ohms between 3 and 4. Can someone...
                                            04-14-2023, 03:24 AM
